Inlet and Outlet b.c. based on mass flux
Like Tree1Likes
  • 1 Post By Hale
Old   June 19, 2013, 10:01
Default Inlet and Outlet b.c. based on mass flux
Hale
Hale is on a distinguished road
Hi foamers,
I'm trying to model a dropshaft (using interFoam solver) that contains
  • constant water flow at the inlet.
  • also constant water flow at the outlet which is equal to the fraction of water that is dropped.
I tried with
  • Inlet
    • U: type fixedValue;
      value uniform (-0.05 0 0);
    • P: type zeroGradient;
  • Outlet
    • U: type zeroGradient;
    • P: type fixedValue;
      value uniform 0;
These boundary conditions give some wrong results.
  1. Inlet: I calculated the velocity based on the constant water discharge. As I can see from the results the water has the expected velocity but the water level at (1) does not remain constant. The water level decreases as it drops down.
  2. Outlet: I constructed the U-shaped form so the water at location (2) is in balance with outlet so when the water drops the corresponding flux will go out from the outlet and therefore the water level would be constant at location (2). But it seems like the outlet boundary condition sucks the water and therefore I won't have constant water level at location (2) shown in figure below.
Figure below shows the set-up and the inlet/outlet boundaries.
Is there any way to define the boundaries based on mass flux? if yes how can I apply it to my case. I really appreciate any help and idea.
Hale is offline   Reply With Quote
Old   August 9, 2013, 01:13
India
mayank.dce2k7 is on a distinguished road
Hi Hale,
Did you find any solution to your problem. I am stuck on the same problem i.e applying boundary conditions based on mass flux?
Regards,
Mayank
mayank.dce2k7 is offline   Reply With Quote
Old   August 9, 2013, 03:26
Hale
Originally Posted by mayank.dce2k7 View Post
Hi Hale,
Regards,
Mayank
Hi Mayank,
yes I solved the problem. If you only want to define a boundary condition based on the mass flux then I recommend that you calculate the corresponding velocity (Q=U*A -> U = Q/A) and use the following for velocity and pressure
velocity
    inFlow
        type            fixedValue;
        value           uniform (xx 0 0);   // define the velocity
pressure
    inFlow
        type            buoyantPressure;
        value           uniform 0;
This boundary condition gives a uniform velocity at the inlet. There is also another boundary condition where you directly can define the mass flux:
velocity
    inFlow
        type            flowRateInletVelocity;
        flowRate        xx;  // here you define the mass flux
        value           uniform (0 0 0);
pressure
    inFlow
        value           uniform 0;
This boundary condition gives the desired mass flux through the specified boundary but the velocity is not necessarily uniform. I'm not so sure about this boundary condition therefore I recommend you the first one.
If you want to know the mass flux through the boundaries then add this function to your controlDict
functions
    inletFlux
        type            faceSource;
        functionObjectLibs ("libfieldFunctionObjects.so");
        outputControl   outputTime;
        log             true;
        // Output field values as well
        valueOutput     false;
        source          patch;
        sourceName      waterFlow;   // write the name of the boundary
        operation       sum;
        fields
            rho phi alpha1     //define the quantities you want to be printed
    outletFlux
        $inletFlux;
        sourceName      outlet;
Remember that you should define your geometry in such a way that y=0 at the outlet otherwise it produces negative pressure. I had this problem with the previous post.
Hope this helps you
dasa likes this.
boundary condition, constant height, interfoam
mass flow inlet and pressure outlet with target mass flow rate Zigainer FLUENT 13 October 26, 2018 06:58
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 13:30
Boudaries for bouynat driven flow with additional mass flux at inlet Charon CFX 2 April 27, 2013 09:02
Net mass flow inlet vs outlet Nigui28 FLUENT 1 August 12, 2011 11:09
Mass flow inlet B.C. at exit... Jack Keays FLUENT 2 October 6, 2000 09:39
