Non-planar initial free surface with setFields |
Johan Roenby
Rep Power: 21 ![]() |
I want to share a problem I've had and its solution:
I am running interFoam in a 3D wave tank, initially setting the water surface to be completely planar at y=0 using setFields, e.g. with a system/setFieldsDict containing: boxToCell { box (-1e10 -1e10 -1e10) (1e10 0 1e10); fieldValues ( volScalarFieldValue alpha1 1 ); } I have noted that this sometimes gives rise to small holes in the initial horizontal surface like the ones shown in the first attached picture. The explanation is that my blockMesh generated mesh has cells with centres lying just around y=0 plus/minus round-off errors. The rings in the water set up by these holes can make the solver run very slow initially. The obvious solution is to replace the line: box (-1e10 -1e10 -1e10) (1e10 0 1e10); in system/setFieldsDict with something like: box (-1e10 -1e10 -1e10) (1e10 0.00001 1e10); (Depending on your grid resolution, of course) which for me resultet in the completely planar initial free surface shown in the 2nd attached picture. Hope this is useful to others as well. Johan |
blockmesh, interfoam, setfields, setfieldsdict |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
