Use "bounded" in scheme or not to use?
Like Tree1Likes
  • 1 Post By immortality
Old   June 11, 2013, 17:20
Default Use "bounded" in scheme or not to use?
immortality's Avatar
Ehsan
immortality is on a distinguished road
Hi
I have read that page in openfoam.org about the change in 2.2.0 version and adding bounded to time and div schemes.but haven't understood that I need to use bounded in time and dive terms or not certainly.
I use now fvScheme as:
fluxScheme      Kurganov;
ddtSchemes
    default         bounded CrankNicolson .5;
    //ddt(rho)        CrankNicolson .5;
    //ddt(rhoU)       CrankNicolson .5;
    //ddt(rhoE)       Euler;
    //ddt(rho,U)      Euler;
    //ddt(rho,e)      Euler;
    //ddt(rho,h)      Euler;
    //ddt(rho,omega)  Euler;
    //ddt(rho,k)      Euler;
    //ddt(rho,gas)    Euler;
gradSchemes
    default         none;
    grad(U) Gauss linear;
    grad(rho) Gauss linear;
    grad(rhoU) Gauss linear;
    grad((1|psi)) Gauss linear;
    grad(e) Gauss linear;
    grad((1|thermo:psi)) Gauss linear;
    grad(h) Gauss linear;
    grad(sqrt(((Cp|Cv)*(1|psi)))) Gauss linear;
    grad(sqrt(((Cp|Cv)*(1|thermo:psi)))) Gauss linear;
    grad(T) Gauss linear;
    grad(omega) Gauss linear;
    grad(k) Gauss linear;
    grad(gas) Gauss linear;
divSchemes
    default none;
    div(tauMC) Gauss linear;
    div(phi) bounded Gauss linearUpwindV;
    div(phi,omega) bounded Gauss linearUpwind grad(omega);
    div(phi,k) bounded Gauss linearUpwind grad(k);
    div(phi,gas) Gauss limitedLimitedLinear 1 0 1;
    div(phi,epsilon) bounded Gauss linearUpwind grad(epsilon);
laplacianSchemes
    default         none;
    laplacian(muEff,U) Gauss linear corrected;
    laplacian(alphaEff,e) Gauss linear corrected;
    laplacian(alpha,e) Gauss linear corrected;
    laplacian(k,T) Gauss linear corrected;
    laplacian(DepsilonEff,omega) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DomegaEff,omega) Gauss linear corrected;
    laplacian(alphaEff,h) Gauss linear corrected;
    laplacian(muEff,gas) Gauss linear corrected;
interpolationSchemes
    default none;
    reconstruct(rho) vanLeer;
    reconstruct(U) vanLeerV;
    reconstruct(T) vanLeer;
    interpolate(rho) linear;
    interpolate(U) linear;
    interpolate(rhoU) linear;
    interpolate(muEff) linear;
    interpolate(tauMC) linear;
snGradSchemes
    default none;
    snGrad(U) corrected;
is it true? my case is compressible and unsteady like a shock tube.
thank anybody helps for clarification.
Ramzy1990 likes this.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 13:29
AUSM scheme ? Central Scheme boling Main CFD Forum 7 January 7, 2016 03:41
When to use upwind or central differencing schemes? quarkz Main CFD Forum 6 August 19, 2011 04:24
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 02:50
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 12:21
