Total pressure and mass flow boundary condition at inlet
Like Tree3Likes
  • 2 Post By bscphil
  • 1 Post By Tushar@cfd
Old   May 6, 2013, 17:17
Default Total pressure and mass flow boundary condition at inlet
bscphil's Avatar
Phillip
bscphil is on a distinguished road
Dear Foamer's,
i've some problems with my boundary conditions for a internal flow through a diffuser and the outflow in atmosphere.
For my case i must set the inlet total pressure + the inlet mass flow rate, because the diffuser is after an rotor/stator stage, which drops the total pressure to e.g. 101325 Pa + 680 Pa. The mass flow rate through the stage is constant e.g. 11.75 kg/s. The flow should be expanding to atmospheric static pressure e.g. 101325 Pa. Ok, this are the main restrictions...
My first attempt was for a incompressible RANS simulation with "simpleFoam":
  • inlet:
    • p: zeroGradient
    • U: fixedValue = 96.8m/s (plug profile)
      or U: flowRateInletVelocity = 11.75kg/s (plug profile)
  • walls:
    • p: zeroGradient
    • U: fixedValue = 0m/s
  • atmosphere:
    • p: fixedValue = 101325 Pa
    • U: zeroGradient
This attempt calculates the right mass flow rate, but the total pressure was wrong (101325 Pa + ~5500 Pa).
My second attempt was:
  • inlet:
    • p: totalPressure = 101325 Pa + 680 Pa
    • U: zeroGradient
  • walls:
    • p: zeroGradient
  • atmosphere:
    • U: zeroGradient
This attempt calculates the right total pressure at inlet, but the wrong mass flow rate (~5.5 kg/s).
My third attempt was:
  • inlet:
    • U: flowRateInletVelocity = 11.75kg/s
  • walls:
    • p: zeroGradient
  • atmosphere:
    • U: zeroGradient
This attempt crashes after some iteration.
My fourth attempt was:
  • inlet:
    • U: pressureInletVelocity
  • walls:
    • p: zeroGradient
  • atmosphere:
    • U: zeroGradient
This calculates very high mass flow rates.
Summary: i could not find out which boundary conditions are exactly right to set total pressure and mass flow rate (or velocity) at the inlet.
I hope somebody with some experience in a similar problem can help me, thanks and sorry for my poor english.
(the attached picture is a overview of the region)
bscphil is offline   Reply With Quote
Old   May 28, 2013, 01:44
T. Chourushi
Tushar@cfd is on a distinguished road
Originally Posted by bscphil View Post
Dear Foamer's,
  • inlet:
    • p: zeroGradient
  • walls:
    • p: zeroGradient
  • atmosphere:
    • U: zeroGradient
  • inlet:
    • U: zeroGradient
  • walls:
    • p: zeroGradient
  • atmosphere:
    • U: zeroGradient
  • inlet:
  • walls:
    • p: zeroGradient
  • atmosphere:
    • U: zeroGradient
  • inlet:
  • walls:
    • p: zeroGradient
  • atmosphere:
    • U: zeroGradient
Good one... first attempt seems to be the best practice in case of diffusing problems, but don't know how come your Total pressure is varying a lot.. Are you able to reach convergence??
raj kumar saini likes this.
Tushar@cfd is offline   Reply With Quote
Old   April 19, 2015, 08:56
Question change flow rate to static pressure
Ali hassan
Ali hassan is on a distinguished road
Hello everyone, I am doing validation for previous article about CNG mixer, my problem is using outlet static pressure instead of out flow because they ANSYS fluent don't allow to use out flow if I use inlet pressure, so, is there any one can help me to get static pressure from mass flow rate? Thanks
Ali hassan is offline   Reply With Quote
Old   July 9, 2017, 15:39
mrwan
mrwan is on a distinguished road
dear
i think the first attempt is the best but u v confusion about the area at inlet
mrwan is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
