Time varying surfaceNormalFixedValue BC with codeStream
Like Tree1Likes
  • 1 Post By gschaider
Old   March 28, 2013, 11:31
Default Time varying surfaceNormalFixedValue BC with codeStream
Francois Beaubert
francois is on a distinguished road
Dear Foamers,
I would like to change the value of the surfaceNormalFixedValue inlet velocity according to the current time step.
I want to build a simple ramped inlet condition using the surfaceNormalFixedValue BC
But I got stuck when I want to access the current time step using codeStream.
My code is as follows:
"Inlet"
        type surfaceNormalFixedValue;
        uBegin   -0.0011968512;
        uEnd   -0.023937024;
        it0  50;
        iter #calc "runTime.time().value()";
        refValue uniform  #calc "max($uEnd,$uBegin + (($uEnd-$uBegin)/$it0)*$iter)";
I got the following error message:
: In function ‘void Foam::codeStream_511e83c811264e2205bc04185da775a50640cef3(Foam::Ostream&, const Foam::dictionary&)’:
:0:8: error: ‘runTime’ was not declared in this scope
make: *** [Make/linux64GccDPOpt/codeStreamTemplate.o] Error 1
Any idea to obtain the current time step with #CodeStream ?
Thank you very much
Regards
Francois
francois is offline   Reply With Quote
Old   March 29, 2013, 04:55
Francois Beaubert
I've tried with
this->db().time().value()
without more luck
Old   April 5, 2013, 15:19
Assistant Moderator
Bernhard Gschaider
Originally Posted by francois View Post
I've tried with
without more luck
"this" is a patchField. So my guess is that you have to get the patch first. Something like
this->patch().mesh().time().value()
but my memory is notoriously bad with that kind of things and I'll have to look it up in Doxygen anytime. That's why I wrote me groovyBC and write something like
type groovyBC;
variables (
        "uBegin=-0.0011968512;"
        "uEnd=-0.023937024;"
        "it0=50;"
valueExpression "normal()*max(uEnd,uBegin+((uEnd-uBegin)/it0)*time())";
(I like to keep my cases and my coding separate)
One note: getting the time seems like quite a common task to me. I'd suggest that you guys do a collection of this and similar snipplets (possibly on the Wiki) for the coded-way. This way I will stop bothering anyone with "come to the dark side, Luke"-postings
kkpal likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
Problem with FloatingObject Leech OpenFOAM Running, Solving & CFD 10 March 29, 2012 16:24
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
