ill defined primitive entry 'boundary'
Like Tree1Likes
  • 1 Post By nimasam
Old   January 29, 2013, 13:12
Unhappy ill defined primitive entry 'boundary'
Francisco Angel
francisco.angel is on a distinguished road
Hello, Im trying to create my first geometry in open foam and for that edited the blockMeshDict file from the cavity tutorial to this:
convertToMeters 1;
vertices
(0,-0.25,0)
(0.25,0,0)
(0,0.25,0)
(-0.25,0,0)
(0,-0.25,0.1)
(0.25,0,0.1)
(0,0.25,0.1)
(-0.25,0,0.1)
(0,-0.25,1)
(0,0.25,1)
(0.25,0,1)
(0,-0.05,1)
(0.05,0,1)
(0,0.05,1)
(-0.05,0,1)
(0,-0.05,1.20)
(0.05,0,1.20)
(0,0.05,1.20)
(-0.05,0,1.20)
blocks
hex (0 1 2 3 8 9 10 11) (20 20 30) simpleGrading (1 1 1)
hex (12 13 14 15 16 17 18 19 20) (10 10 20) simpleGrading (1 1 1)
edges
arc 0 2 (0.25,0,0)
arc 2 0 (-0.25,0,0)
arc 4 6 (0.25,0,0.1)
arc 6 4 (-0.25,0,0.1)
arc 8 10 (0,0.25,1)
arc 10 8 (0,-0.25,1)
arc 12 14 (0.05,0,1)
arc 14 12 (-0.05,0,1)
arc 16 18 (0.05,0,1.2)
arc 18 16 (-0.05,0,1.2)
boundary
pared
type wall;
faces
(0 1 2 3)
(4 6 10 8)
(6 4 8 10)
(8 9 13 12)
(9 10 14 13)
(10 11 15 14)
(11 8 12 15)
salida
type patch;
faces
(0 2 6 4)
(2 0 4 6)
(16 17 18 19)
mergePatchPairs
Im triying to construct a cylindrical geometry with inflow in top and outflow in the bottom section. I read about axial symmetry but I was triying to construct in the simpler way possible to start.
The error console gives is:
Create time
Creating block mesh from
"/home/francisco/Escritorio/horno/constant/polyMesh/blockMeshDict"
--> FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'boundary' on line 63 and ending at line 94"
file: /home/francisco/Escritorio/horno/constant/polyMesh/blockMeshDict at line 94.
From function primitiveEntry::readEntry(const dictionary&, Istream&)
in file lnInclude/IOerror.C at line 132.
FOAM exiting
In my actual knowledge the error is totally obscure for me.
francisco.angel is offline   Reply With Quote
Old   January 29, 2013, 19:46
Retired Super Moderator
Bruno Santos
Greetings Francisco and welcome to the forum!
Please use the "[CODE]" markers for isolating source code... in advanced editing mode, it's the "#" button
Now, the error tells you that the problem starts at "boundary", so let's look at what "boundary" defines:
boundary
    pared
        type wall;
        faces
                (0 1 2 3)
                (4 6 10 8)
                (6 4 8 10)
                (8 9 13 12)
                (9 10 14 13)
                (10 11 15 14)
                (11 8 12 15)
    salida
        type patch;
        faces
            (0 2 6 4)
            (2 0 4 6)
            (16 17 18 19)
Notice the sudden drop in the list between "pared" and "salida"?
It should be something like this (in bold are the lines that were added):
boundary
    pared
        type wall;
        faces
                (0 1 2 3)
                (4 6 10 8)
                (6 4 8 10)
                (8 9 13 12)
                (9 10 14 13)
                (10 11 15 14)
                (11 8 12 15)
    salida
        type patch;
        faces
            (0 2 6 4)
            (2 0 4 6)
            (16 17 18 19)
If you don't want to keep designing meshes for blockMesh using text only, try SwiftBlock: http://openfoamwiki.net/index.php/Contrib/SwiftBlock
Best regards,
Bruno
Old   January 30, 2013, 09:58
Francisco Angel
Thanks for the answer, after your response I continue work in the file but still getting errors, I was capable of catching a couple ( ,'s in vertices definition, bad definition of arcs). Following recomendation of another post I try to construct the geometry by parts to isolate the error. Succesfully construct the inferior part, now when I try to add the intermediate part I obtain an error I im incapable of repair. Please help.
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
        (0      -0.25   0       )     //0
        (0.25   0       0       )     //1
        (0      0.25    0       )       //2
        (-0.25  0       0       )       //3
        (0      -0.25   0.1     )       //4
        (0.25   0       0.1     )       //5
        (0      0.25    0.1     )       //6
        (-0.25  0       0.1     )       //7
        (0      -0.25   1       )       //8
        (0.25    0      1       )       //9
        (0      0.25    1       )       //10
        (-0.25  0       1       )       //11
blocks
edges
        arc 0 1 (0.17678 -0.17678 0)
        arc 1 2 (0.17678 0.17678  0)
        arc 2 3 (-0.17678 0.17678 0)
        arc 3 0 (-0.17678 -0.17678 0)
        arc 4 5 (0.17678 -0.17678 0.1)
        arc 5 6 (0.17678 0.17678  0.1)
        arc 6 7 (-0.17678 0.17678 0.1)
        arc 7 4 (-0.17678 -0.17678 0.1)
        arc 8 9 (0.17678 -0.17678 1)
        arc 9 10 (0.17678 0.17678  1)
        arc 10 11 (-0.17678 0.17678 1)
        arc 11 8 (-0.17678 -0.17678 1)
boundary
 entrada
type patch;
faces
(8 9 10 11)
 salida
        type patch;
        faces
            (0 1 5 4)
            (1 2 6 5)
            (2 3 7 6)
            (3 0 4 7)
    pared
        type wall;
        faces
                (0 1 2 3)
                (4 5 9 8)
                (5 6 10 9)
                (6 7 11 10)
                (7 4 9 11)
mergePatchPairs
This is the message from blockMesh
Create time
Creating curved edges
Creating topology blocks
Creating topology patches
Creating block mesh topology
--> FOAM FATAL ERROR:
face 0 in patch 1 does not have neighbour cell face: 4(0 1 5 4)
From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::error::abort() in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Foam:olyMesh::facePatchFaceCells(Foam::List<Foam ::face> const&, Foam::List<Foam::List<int> > const&, Foam::List<Foam::List<Foam::face> > const&, int) const in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#3 Foam:olyMesh::setTopology(Foam::List<Foam::cellS hape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, int&, int&, Foam::List<Foam::cell>&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#4 Foam:olyMesh:olyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::PtrList<Foam::dictionary> const&, Foam::word const&, Foam::word const&, bool) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#5 Foam::blockMesh::createTopology(Foam::IOdictionary const&, Foam::word const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libblockMesh.so"
#6 Foam::blockMesh::blockMesh(Foam::IOdictionary const&, Foam::word const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libblockMesh.so"
in "/opt/openfoam211/platforms/linuxGccDPOpt/bin/blockMesh"
#8 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Abortado
Old   January 30, 2013, 10:02
Bruno Santos
Hi Franscisco,
I can't test your file right now. But in the meantime, I forgot to mention a feature that can assist you in debugging the "blockMeshDict" file - run paraFoam like this:
paraFoam -block
It will show you how conceptually the mesh will look like.
Best regards,
Bruno
Old   January 30, 2013, 14:16
Francisco Angel
thanks again for the answer, with the command you indicated I was capable of debugg the error, almost all the errors reported were in the end caused for creting combinations of blocks and faces that can cause and element of the discretization could end being in two boundary conditions.
Based on geometry of another thread I divided my domain in more blocks to allow each of the faces being the complete side of one block.
More code but now I undertand more the logic of the program.
Thanks again for the time dedicated to answer me.
Old   December 10, 2013, 12:03
Default ill defined primitiveEntry at boundary
Dhaval Shiyani
cfdjunkie is on a distinguished road
Hello guys,
Sorry to keep on this error but I am trying to run a blockMeshDict file for a cylindrical domain with multiple inlet faces.
 // blockMesh :  Block mesh description file
FoamFile
version  2.0;
format   ascii;
root     "";
case     "";
instance "";
local    "";
class dictionary;
   convertToMeters 1;
    //0.3048m column diameter
    //0.5017m length
   vertices
    ( 0.0762 0.0  0.0762) // Vertex LowerOuterSquare0 = 0
    ( 0.0381 0.0 0.0762) // Vertex LowerOuterSquare1 = 1
    ( 0.0 0.0 0.0762) // Vertex LowerOuterSquare2 = 2
    (-0.0381 0.0 0.0762) // Vertex LowerOuterSquare3 = 3
    (-0.0762 0.0  0.0762) // Vertex LowerOuterSquare4 = 4
    (-0.0762 0.0 0.0381) // Vertex LowerOuterSquare5 = 5
    (-0.0762 0.0 0.0) // Vertex LowerOuterSquare6 = 6
    (-0.0762 0.0 -0.0381) // Vertex LowerOuterSquare7 = 7
    (-0.0762 0.0 -0.0762) // Vertex LowerOuterSquare8 = 8
    (-0.0381 0.0 -0.0762) // Vertex LowerOuterSquare9 = 9
    ( 0.0 0.0 -0.0762) // Vertex LowerOuterSquare10 = 10
    ( 0.0381 0.0 -0.0762) // Vertex LowerOuterSquare11 = 11
    ( 0.0762 0.0 -0.0762) // Vertex LowerOuterSquare12 = 12
    ( 0.0762 0.0 -0.0381) // Vertex LowerOuterSquare13 = 13
    ( 0.0762 0.0 0.0) // Vertex LowerOuterSquare14 = 14
    ( 0.0762 0.0 0.0381) // Vertex LowerOuterSquare15 = 15
    ( 0.14079924078089 0.0 0.0583209550292597) // Vertex BottomCircle16 = 16
    ( 0.107763073549542 0.0 0.107763073356118) // Vertex BottomCircle17 = 17
    ( 0.0583209550292597 0.0 0.14079924078089) // Vertex BottomCircle18 = 18
    ( 0.0 0.0 0.1524) // Vertex BottomCircle19 = 19
    (-0.0583209550292597 0.0 0.14079924078089) // Vertex BottomCircle20 = 20
    (-0.107763073549542 0.0 0.107763073356118) // Vertex BottomCircle21 = 21
    (-0.14079924078089 0.0 0.0583209550292597) // Vertex BottomCircle22 = 22
    (-0.1524 0.0 0.0) // Vertex BottomCircle23 = 23
    (-0.14079924078089 0.0 -0.0583209550292597) // Vertex BottomCircle24 = 24
    (-0.107763073549542 0.0 -0.107763073356118) // Vertex BottomCircle25 = 25
    (-0.0583209550292597 0.0 -0.14079924078089) // Vertex BottomCircle26 = 26
    ( 0.0 0.0 -0.1524) // Vertex BottomCircle27 = 27
    ( 0.0583209550292597 0.0 -0.14079924078089) // Vertex BottomCircle28 = 28
    ( 0.107763073549542 0.0 -0.107763073356118) // Vertex BottomCircle29 = 29
    ( 0.14079924078089 0.0 -0.0583209550292597) // Vertex BottomCircle30 = 30
    ( 0.1524 0.0 0.0) // Vertex BottomCircle31 = 31
    ( 0.0762 0.5017  0.0762) // Vertex UpperOuterSquare32 = 32
    ( 0.0381 0.5017 0.0762) // Vertex UpperOuterSquare33 = 33
    ( 0.0 0.5017 0.0762) // Vertex UpperOuterSquare34 = 34
    (-0.0381 0.5017 0.0762) // Vertex UpperOuterSquare35 = 35
    (-0.0762 0.5017 0.0762) // Vertex UpperOuterSquare36 = 36
    (-0.0762 0.5017 0.0381) // Vertex UpperOuterSquare37 = 37
    (-0.0762 0.5017 0.0) // Vertex UpperOuterSquare38 = 38
    (-0.0762 0.5017 -0.0381) // Vertex UpperOuterSquare39 = 39
    (-0.0762 0.5017 -0.0762) // Vertex UpperOuterSquare40 = 40
    (-0.0381 0.5017 -0.0762) // Vertex UpperOuterSquare41 = 41
    ( 0.0 0.5017 -0.0762) // Vertex UpperOuterSquare42 = 42
    ( 0.0381 0.5017 -0.0762) // Vertex UpperOuterSquare43 = 43
    ( 0.0762 0.5017 -0.0762) // Vertex UpperOuterSquare44 = 44
    ( 0.0762 0.5017 -0.0381) // Vertex UpperOuterSquare45 = 45
    ( 0.0762 0.5017 0.0) // Vertex UpperOuterSquare46 = 46
    ( 0.0762 0.5017 0.0381) // Vertex UpperOuterSquare47 = 47
    ( 0.14079924078089 0.5017 0.0583209550292597) // Vertex TopCircle48 = 48
    ( 0.107763073549542 0.5017 0.107763073356118) // Vertex TopCircle49 = 49
    ( 0.0583209550292597 0.5017 0.14079924078089) // Vertex TopCircle50 = 50
    ( 0.0 0.5017 0.1524) // Vertex TopCircle51 = 51
    (-0.0583209550292597 0.5017 0.14079924078089) // Vertex TopCircle52 = 52
    (-0.107763073549542 0.5017 0.107763073356118) // Vertex TopCircle53 = 53
    (-0.14079924078089 0.5017 0.0583209550292597) // Vertex TopCircle54 = 54
    (-0.1524 0.5017 0.0) // Vertex TopCircle55 = 55
    (-0.14079924078089 0.5017 -0.0583209550292597) // Vertex TopCircle56 = 56
    (-0.107763073549542 0.5017 -0.107763073356118) // Vertex TopCircle57 = 57
    (-0.0583209550292597 0.5017 -0.14079924078089) // Vertex TopCircle58 = 58
    ( 0.0 0.5017 -0.1524) // Vertex TopCircle59 = 59
    ( 0.0583209550292597 0.5017 -0.14079924078089) // Vertex TopCircle60 = 60
    ( 0.107763073549542 0.5017 -0.107763073356118) // Vertex TopCircle61 = 61
    ( 0.14079924078089 0.5017 -0.0583209550292597) // Vertex TopCircle62 = 62
    ( 0.1524 0.5017 0.0) // Vertex TopCircle63 = 63
    ( 0.0381 0.0 0.0381) // Vertex LowerInnerSquare64 = 64
    ( 0.0 0.0 0.0381) // Vertex LowerInnerSquare65 = 65
    (-0.0381 0.0 0.0381) // Vertex LowerInnerSquare66 = 66
    (-0.0381 0.0 0.0) // Vertex LowerInnerSquare67 = 67
    (-0.0381 0.0 -0.0381) // Vertex LowerInnerSquare68 = 68
    (0.0 0.0 -0.0381) // Vertex LowerInnerSquare69 = 69
    (0.0381 0.0 -0.0381) // Vertex LowerInnerSquare70 = 70
    (0.0381 0.0 0.0) // Vertex LowerInnerSquare71 = 71
    ( 0.0381 0.5017 0.0381) // Vertex UpperInnerSquare72 = 72
    ( 0.0 0.5017 0.0381) // Vertex UpperInnerSquare73 = 73
    (-0.0381 0.5017 0.0381) // Vertex UpperInnerSquare74 = 74
    (-0.0381 0.5017 0.0) // Vertex UpperInnerSquare75 = 75
    (-0.0381 0.5017 -0.0381) // Vertex UpperInnerSquare76 = 76
    (0.0 0.5017 -0.0381) // Vertex UpperInnerSquare77 = 77
    (0.0381 0.5017 -0.0381) // Vertex UpperInnerSquare78 = 78
    (0.0381 0.5017 0.0) // Vertex UpperInnerSquare79 = 79
    (0.0 0.0 0.0) // Vertex Origin80 = 80
    (0.0 0.5017 0.0) // Vertex OriginTop81 = 81
   blocks
    //Square block1
    hex (4 3 66 5 36 35 74 37) (5 5 30) simpleGrading (1 1 1)
    //Square block2
    hex (3 2 65 66 35 34 73 74) (5 5 30) simpleGrading (1 1 1)
    //Square block3
    hex (2 1 64 65 34 33 72 73) (5 5 30) simpleGrading (1 1 1)
    //Square block4
    hex (1 0 15 64 33 32 47 72) (5 5 30) simpleGrading (1 1 1)
    //Square block5
    hex (
       5 66 67 6
       37 74 75 38
    (5 5 30)
    //Square block6
    hex (
       66 65 80 67
       74 73 81 75
    (5 5 30)
    //Square block7
    hex (
       65 64 71 80
       73 72 79 81
    (5 5 30)
    //Square block8
    hex (
       64 15 14 71
       72 47 47 79
    (5 5 30)
    //Square block9
    hex (
       6 67 68 7
       38 75 76 39
    (5 5 30)
    //Square block10
    hex (
       67 80 69 68
       75 81 77 76
    (5 5 30)
    //Square block11
    hex (
       80 71 70 69
       81 79 78 77
    (5 5 30)
    //Square block12
    hex (
       71 14 13 70
       79 46 45 78
    (5 5 30)
    //Square block13
    hex (
       7 68 9 8
       39 76 41 40
    (5 5 30)
    //Square block14
    hex (
       68 69 10 9
       76 77 42 41
    (5 5 30)
    //Square block15
    hex (
       69 70 11 10
       77 78 43 42
    (5 5 30)
    //Square block16
    hex (
       70 13 12 11
       78 45 44 43
    (5 5 30)
    //slice1
    hex (
         19 2 3 20
         51 34 35 52
    (5 5 30)
    //slice2
    hex (
         20 3 4 21
         52 35 36 53
   (5 5 30)
   //slice3
   hex (
        21 3 4 22
        53 36 37 54
   (5 5 30)
   //slice4
   hex (
        22 5 6 23
        54 37 38 55
   (5 5  30)
   //slice5
   hex (
        23 6 7 24
        55 38 39 56
   (5 5  30)
   //slice6
   hex (
        24 7 8 25
        56 39 40 57
   (5 5  30)
   //slice7
   hex (
        25 8 9 26
        57 40 41 58
   (5 5  30)
   //slice8
   hex (
        26 9 10 27
        58 41 42 59
   (5 5  30)
   //slice9
   hex (
        27 10 11 28
        59 42 43 60
   (5 5  30)
   //slice10
   hex (
        28 11 12 29
        60 43 44 61
   (5 5  30)
   //slice11
   hex (
        29 12 13 30
        61 44 45 62
   (5 5  30)
   //slice12
   hex (
        30 13 14 31
        62 45 46 63
   (5 5  30)
   //slice13
   hex (
        31 14 15 16
        63 46 47 48
   (5 5  30)
   //slice14
   hex (
        16 15 0 17
        48 47 32 49
   (5 5  30)
   //slice15
   hex (
        17 0 1 18
        49 32 33 50
   (5 5  30)
   //slice16
   hex (
        18 1 2 19
        50 33 34 51
   (5 5  30)
   //create arcs 1/16th the size of the circle
   edges
    arc 16 17 ( 0.126715968971897 0  0.0846689034268966)
    arc 17 18 ( 0.0846689034268966 0  0.126715968971897)
    arc 18 19 ( 0.0297317650417222 0  0.149471676740123)
    arc 19 20 (-0.0297317650417222 0  0.149471676740123)
    arc 20 21 (-0.0846689034268966 0  0.126715968971897)
    arc 21 22 (-0.126715968971897 0  0.0846689034268966)
    arc 22 23 (-0.149471676740123 0  0.0297317650417222)
    arc 23 24 (-0.149471676740123 0 -0.0297317650417222)
    arc 24 25 (-0.126715968971897 0 -0.0846689034268966)
    arc 25 26 (-0.0846689034268966 0 -0.126715968971897)
    arc 26 27 (-0.0297317650417222 0 -0.149471676740123)
    arc 27 28 ( 0.0297317650417222 0 -0.149471676740123)
    arc 28 29 ( 0.0846689034268966 0 -0.126715968971897)
    arc 29 30 ( 0.126715968971897 0 -0.0846689034268966)
    arc 30 31 ( 0.149471676740123 0 -0.0297317650417222)
    arc 31 16 ( 0.149471676740123 0  0.0297317650417222)
    arc 48 49 ( 0.126715968971897 0.5017  0.0846689034268966)
    arc 49 50 ( 0.0846689034268966 0.5017  0.126715968971897)
    arc 50 51 ( 0.0297317650417222 0.5017  0.149471676740123)
    arc 51 52 (-0.0297317650417222 0.5017  0.149471676740123)
    arc 52 53 (-0.0846689034268966 0.5017  0.126715968971897)
    arc 53 54 (-0.126715968971897 0.5017  0.0846689034268966)
    arc 54 55 (-0.149471676740123 0.5017  0.0297317650417222)
    arc 55 56 (-0.149471676740123 0.5017 -0.0297317650417222)
    arc 56 57 (-0.126715968971897 0.5017 -0.0846689034268966)
    arc 57 58 (-0.0846689034268966 0.5017 -0.126715968971897)
    arc 58 59 (-0.0297317650417222 0.5017 -0.149471676740123)
    arc 59 60 ( 0.0297317650417222 0.5017 -0.149471676740123)
    arc 60 61 ( 0.0846689034268966 0.5017 -0.126715968971897)
    arc 61 62 ( 0.126715968971897 0.5017 -0.0846689034268966)
    arc 62 63 ( 0.149471676740123 0.5017 -0.0297317650417222)
    arc 63 48 ( 0.149471676740123 0.5017  0.0297317650417222)
   boundary
    inlet1
    type wall;
    faces
     (17 16 48 49)
    inlet2
    type wall;
    faces
     (18 17 49 50)
    inlet3
    type wall;
    faces
     (19 18 50 51)
    inlet4
    type wall;
    faces
     (20 19 51 52)
    inlet5
    type wall;
    faces
     (21 20 52 53)
    inlet6
    type wall;
    faces
     (22 21 53 54)
    inlet7
    type wall;
    faces
     (23 22 54 55)
    inlet8
    type wall;
    faces
     (24 23 55 56)
    inlet9
    type wall;
    faces
     (25 24 56 57)
    inlet10
    type wall;
    faces
     (26 25 57 58)
    inlet11
    type wall;
    faces
     (27 26 58 59)
    inlet12
    type wall;
    faces
     (28 27 59 60)
    inlet13
    type wall;
    faces
     (29 28 60 61)
    inlet14
    type wall;
    faces
     (30 29 61 62)
    inlet15
    type wall;
    faces
     (31 30 62 63)
    inlet16
    type wall;
    faces
     (16 31 63 48)
    hotPlate
    type wall;
    faces
     (16 15 0 17)
     (17 0 1 18)
     (18 1 2 19)
     (19 2 3 20)
     (20 3 4 21)
     (21 4 5 22)
     (22 5 6 23)
     (23 6 7 24)
     (24 7 8 25)
     (25 8 9 26)
     (26 9 10 27)
     (27 10 11 28)
     (28 11 12 29)
     (29 12 13 30)
     (30 13 14 31)
     (31 14 15 16)
     (15 64 1 0)
     (64 65 2 1)
     (65 66 3 2)
     (66 5 4 3)
     (14 71 64 15)
     (71 80 65 64)
     (80 67 66 65)
     (67 6 5 66)
     (13 70 71 14)
     (70 69 80 71)
     (69 68 67 80))
     (68 7 6 67)
     (12 11 70 13)
     (11 10 69 70)
     (10 9 68 69)
     (9 8 7 68)
    outlet
    type wall;
    faces
     (48 47 32 49)
     (49 32 33 50)
     (50 33 34 51)
     (51 34 35 52)
     (52 35 36 53)
     (53 36 37 54)
     (54 37 38 55)
     (55 38 39 56)
     (56 39 40 57)
     (57 40 41 58)
     (58 41 42 59)
     (59 42 43 60)
     (60 43 44 61)
     (61 44 45 62)
     (62 45 46 63)
     (63 46 47 48)
     (47 72 33 32)
     (72 73 34 33)
     (73 74 35 34)
     (74 37 36 35)
     (46 79 72 47)
     (79 81 73 72)
     (81 75 74 73)
     (75 38 37 74)
     (45 78 79 46)
     (78 77 81 79)
     (77 76 75 81)
     (76 39 38 75)
     (44 43 78 45)
     (43 42 77 78)
     (42 41 76 77)
     (41 40 39 76)
mergePatchPairs
However when I run blockMesh on this file I get the same ill defined primitiveEntry at boundary error,
esi-comp@esicomp01:~/OpenFOAM/dhaval222/run/SteadyState/TestCase16part$ blockMesh
|  \\    /   O peration     | Version:  2.2.2                                 |
Build  : 2.2.2-9240f8b967db
Exec   : blockMesh
Date   : Dec 10 2013
Time   : 10:45:05
Host   : "esicomp01"
PID    : 24267
Case   : /home/esi-comp/OpenFOAM/dhaval222/run/SteadyState/TestCase16part
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
    "/home/esi-comp/OpenFOAM/dhaval222/run/SteadyState/TestCase16part/constant/polyMesh/blockMeshDict"
"ill defined primitiveEntry starting at keyword 'boundary' on line 458 and ending at line 692"
file: /home/esi-comp/OpenFOAM/dhaval222/run/SteadyState/TestCase16part/constant/polyMesh/blockMeshDict at line 692.
FOAM exiting
After reviewing this thread it seems to me that this is because of any syntax errors in the boundary condition definitions of the dict file. But after going through the blockMeshDict, I cannot for the life of me figure out any syntax errors that I have made.
Can I please get some help with this error? May be a second eye.
Thanks in advance!
Regards,
Dhaval
cfdjunkie is offline   Reply With Quote
Old   December 10, 2013, 12:45
Dhaval Shiyani
Hey guys,
Got it. There is one extra parenthesis in the hotPlate/faces section.
Please don't waste your time to reply to the previous thread.
Thanks a lot!
Dhaval
Old   June 12, 2016, 06:28
Fatemeh
fatemehfarshi62 is on a distinguished road
Hi every one!
I have a similar problem too. I have checked all my blockMeshdict file but no result
some of my typical blocks are as following:
hex (104 105 131 130 208 209 235 234) (20 80 10) simpleGrading (
1
(0.1 0.15 0.5)
(0.8 0.7 1)
(0.1 0.15 2)
2
) //b11lfp
hex (52 53 79 78 26 27 105 104) (20 36 8) simpleGrading (
1
(0.125 0.222 0.5)
(0.75 0.556 1)
(0.125 0.222 2)
2
) //b11bmc
hex (26 27 105 104 182 183 209 208) (20 36 10) simpleGrading (
1
(0.125 0.222 0.5)
(0.75 0.556 1)
(0.125 0.222 2)
2
) //b11smc
hex (0 1 27 26 156 157 183 182) (20 80 10) simpleGrading (
1
(0.1 0.15 0.5)
(0.8 0.7 1)
(0.1 0.15 2)
2
) //b11rfp
hex (105 106 132 131 209 210 236 235) (30 80 10) simpleGrading (
2
(0.1 0.15 0.5)
(0.8 0.7 1)
(0.1 0.15 2)
2
) //b12lfp
hex (53 54 80 79 27 28 106 105) (30 36 8) simpleGrading (
2
(0.125 0.222 0.5)
(0.75 0.556 1)
(0.125 0.222 2)
2
) //b12bmc
hex (27 28 106 105 183 184 210 209) (30 36 10) simpleGrading (
2
(0.125 0.222 0.5)
(0.75 0.556 1)
(0.125 0.222 2)
2
) //b12smc
hex (1 2 28 27 157 158 184 183) (30 80 10) simpleGrading (
2
(0.1 0.15 0.5)
(0.8 0.7 1)
(0.1 0.15 2)
2
) //b12rfp
but I face this error:
"ill defined primitiveEntry starting at keyword 'blocks' on line 299 and ending at line 1753"
can any one please please tell me what to do?
thanks!
fatemehfarshi62 is offline   Reply With Quote
Old   June 13, 2016, 03:39
Nima Samkhaniani
nimasam is on a distinguished road
it usually happens when the file misses ) or } or ] or ;
check them
Adolf likes this.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 14, 2016, 01:26
Fatemeh
Dear Dr. Samkhaniani,
Thanks a lot for you kind reply. I have checked my file several times but no result
I have attached my blockMesh file. Would you please please take a look at it?
thanks again and again and best regards.
Old   June 14, 2016, 04:04
Nima Samkhaniani
add the whole case file here
Old   April 19, 2018, 04:16
AliG
axjjienn is on a distinguished road
Check that all your boundary definitions have spaces between the scalar or vector values...I have had that problem before.
axjjienn is offline   Reply With Quote
Old   May 21, 2018, 22:16
Default i have same problem,can anyone help me?
  #13
zein elserfy
zeinelserfy is on a distinguished road
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
field p tolerance 1e-05
field U tolerance 1e-05
field nuTilda tolerance 1e-05
Reading field p
"ill defined primitiveEntry starting at keyword 'exit*' on line 29 and ending at line 57"
file: /home/zels496/OpenFOAM-in-Box-18.02/OpenFOAM-dev/tutorials/incompressible/simpleFoam/airFoil2D/airfoiltry/0/p at line 57.
From function void Foam:rimitiveEntry::readEntry(const Foam::dictionary&, Foam::Istream&)
in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 189.
FOAM exiting
that is the error message ,the p file is shown below
| \\ / O peration | Version: dev |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type freestreamPressure;
exit
top
bottom
aerofoil
type zeroGradient;
front
type empty;
back
type empty;
zeinelserfy is offline   Reply With Quote
Old   July 17, 2021, 21:24
Unhappy same error with "blocks"
  #14
Lauren Meaders
lmeaders is on a distinguished road
I get the following error when I attempt to run my blockMeshDict file. Please let me know if you see any bugs in my code. I made sure there was a space between simpleGrading and (
Please note that that the shape I am creating is a square cylinder within a rectangular wind tunnel. I have sliced it in half along the x axis as it is symmetric so i am only modeling the upper half.
"/home/lmeaders/OpenFOAM/lmeaders-7/run/project/cavity/squarecyl/system/blockMeshDict"
"ill defined primitiveEntry starting at keyword 'blocks' on line 75 and ending at line 171"
file: /home/lmeaders/OpenFOAM/lmeaders-7/run/project/cavity/squarecyl/system/blockMeshDict at line 171.
in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 185.
FOAM exiting
My code:
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 7
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 0.01;
vertices
// botttom left block -0.5<z<0.5
(-25 0 0.5) // v0
(-1 0 0.5)// v1
(-1 0.5 0.5) // v2
(-25 0.5 0.5) //v3
(-25 0 -0.5) // v12
(-1 0 -0.5)// v13
(-1 0.5 -0.5) // v14
(-25 0.5 -0.5) //v15
// Top Left block
// v3 v2
(-1 10 0.5) // v4
(-25 10 0.5) //v5
// v15 v14
(-1 10 -0.5) // v16
(-25 10 -0.5) //v17
// center block
// v2
(1 0.5 0.5) // v9
(1 10 0.5) // v11
// v4
// v14
(1 0.5 -0.5) // v21
(1 10 -0.5) // v23
// v16
// bottom right
(1 0 0.5) // v6
(65 0 0.5) // v7
(65 0.5 0.5) // v8
// v9
(1 0 -0.5) // v18
(65 0 -0.5) // v19
(65 0.5 -0.5) // v20
// v21
// top right
// v9 v8
(65 10 0.5) // v10
// v 11
// v21 v20
(65 10 -0.5) // v22
// v23
blocks
// bottom left
hex(0 1 2 3 12 13 14 15) (60 30 1) simpleGrading (1 1 1)
// top left
hex(3 2 4 5 15 14 16 17) (60 30 1) simpleGrading (1 1 1)
// center
hex(2 9 11 4 14 21 23 16) (60 30 1) simpleGrading (1 1 1)
// bottom right
hex(6 7 8 9 18 19 20 21) (60 30 1) simpleGrading (1 1 1)
// top right
hex(9 8 10 11 21 20 22 23) (60 30 1) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(0 3 15 12)
(3 5 17 15)
outlet
type patch;
faces
(7 8 10 19)
(8 10 22 20)
wall
type wall;
faces
(5 4 16 17)
(4 11 23 16)
(11 10 22 23)
(0 1 13 12)
(6 7 19 18)
obstacle
type wall;
faces
(2 14 13 1)
(14 21 9 2)
(18 6 9 21)
frontAndBack
type empty;
faces
(0 1 2 3)
(3 2 4 5)
(2 9 11 4)
(6 7 8 9)
(9 8 10 11)
(12 13 14 15)
(15 14 16 17)
(14 21 23 16)
(18 19 20 21)
(21 20 22 23)
mergePatchPairs
lmeaders is offline   Reply With Quote
Old   July 18, 2021, 02:52
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You need a space between hex and ( .
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   September 8, 2022, 06:44
  #16
anonymous
Quincy is on a distinguished road
Dear foamers please i need your help. i am trying to renumber a mesh around an airfoil. i used gmsh. after checking the mesh on the terminal, its ok. as i try to renumber the mesh in openfoam, i get the following message.
"ill defined primitiveEntry starting at keyword 'airfoil' on line 45 and ending at line 63"
file: /home/quincy/Desktop/openfoamtuto/0/p at line 63.
in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 168.
FOAM exiting
here also is the p file i am being directed to
\\ / A nd | Version: 8
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
object p;
boundaryField
left
freestreamValue uniform 0;
outlet
top
type zeroGradient;
bottom
type zeroGradient;
airfoil surface
type zeroGradient;
front
type empty;
back
type empty;
Quincy is offline   Reply With Quote
Old   September 8, 2022, 07:11
Yann
Yann will become famous soon enoughYann will become famous soon enough
I think your problem is related to this:
airfoil surface
type zeroGradient;
You cannot have whitespaces in a patch name.
Cheers,
Yann
Yann is offline   Reply With Quote
blockmesh, boundary file., ill defined
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 06:58
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
how to give boundary conditions:-calculated type of primitive boundary field suniljain OpenFOAM Running, Solving & CFD 1 March 20, 2010 01:19
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
