inlet pressure is higher than outlet pressure for fan
Like Tree2Likes
  • 1 Post By maddalena
  • 1 Post By nash
Old   November 14, 2012, 13:22
Default inlet pressure is higher than outlet pressure for fan
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
Dear Foamers,
I am running simulation using MRFSimpleFoam solver, the simulation has been done. But now i am comparing the results with experimental result.
the simulation result shows that inlet pressure is higher than outlet pressure.
I am not able to figure out the mistake in my case.
I have attached the U and P file for your consideration, please have a look and help to get it solved.
Thanks for your time and help,
Sivakumar
sivakumar is offline   Reply With Quote
Old   November 16, 2012, 11:15
maddalena's Avatar
maddalena
maddalena will become famous soon enough
some observations:
1) before asking help, this is a must-read thread: http://www.cfd-online.com/Forums/ope...-get-help.html
2) your solver is incompressible, thus a uniform 0 value should be used. Relative pressure matters.
3) Is your U defined in agreement with the coordinate system? i.e. should the flow go in positive X direction?
mad
samningoo likes this.
maddalena is offline   Reply With Quote
Old   November 16, 2012, 12:36
sivakumar selvaraju
Hi Maddalena,
Thanks for the link, I am using MRFSimpleFoam,
Its a passage of axial flow fan,
I have defined velocity in x direction (i am not sure about this condition , how good it is)
I hope the defined pressure is fine. other boundary conditions are good I think.
the convergence not going beyond 0.001.
I have attached the figure, please have a look.
I have tried different schemes still the residual plot is same.
I have attached P and U, please have a look.
if you dont mind please give me you email id I will send my case for your consideration.
Thank you for your help and time,
Sivakumar
File Type: jpg Screenshot from 2012-10-30 10:38:16.jpg (26.2 KB, 96 views)
Old   May 17, 2013, 13:14
Dogan
dogan is on a distinguished road
hi,
i have the same problem. I am running a centrifugal pump simulation with MRFSimpleFoam. i checked my BC's, but i couldn't find the problem. it supposed to be low pressure in the inlet (suction), and high pressure in the outlet, but the results are showing the opposite.
here is the U:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 1.485);
boundaryField
Wall_0
type fixedValue;
value uniform (0 0 0);
Dummy_4
type cyclicGgi;
//inletValue $internalField;
value $internalField;
Inlet_7
type fixedValue;
value uniform (0 0 1.485);
Wall_8
type fixedValue;
Dummy_10
type cyclicGgi;
Dummy_11
type cyclicGgi;
Dummy_12
type cyclicGgi;
Dummy_13
type cyclicGgi;
Dummy_14
type cyclicGgi;
Dummy_15
type cyclicGgi;
Dummy_16
type cyclicGgi;
Dummy_17
type cyclicGgi;
Dummy_18
type cyclicGgi;
Dummy_19
type cyclicGgi;
Dummy_20
type cyclicGgi;
Dummy_21
type cyclicGgi;
Dummy_24
type cyclicGgi;
Dummy_25
type cyclicGgi;
Dummy_26
type cyclicGgi;
Dummy_27
type cyclicGgi;
Wall_30
type fixedValue;
Inlet_31
type fixedValue;
Wall_32
type fixedValue;
Dummy_38
type cyclicGgi;
Wall_39
type fixedValue;
Wall_48
type fixedValue;
Outlet_61
type zeroGradient;
Dummy_GGI_1
type cyclicGgi;
Dummy_GGI_2
type cyclicGgi;
Interface_22_23
type cyclicGgi;
Interface_28_29
type cyclicGgi;
Interface_36_37
type cyclicGgi;
Interface_40_41
type cyclicGgi;
Dummy_2_6_9
type cyclicGgi;
Dummy_33_34_35
type cyclicGgi;
and the p:
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
Wall_0
type zeroGradient;
Dummy_4
type cyclicGgi;
Dummy_10
type cyclicGgi;
Dummy_11
type cyclicGgi;
Dummy_12
type cyclicGgi;
Dummy_13
type cyclicGgi;
Dummy_14
type cyclicGgi;
Dummy_15
type cyclicGgi;
Dummy_16
type cyclicGgi;
Dummy_17
type cyclicGgi;
Dummy_18
type cyclicGgi;
Dummy_19
type cyclicGgi;
Dummy_20
type cyclicGgi;
Dummy_21
type cyclicGgi;
Dummy_24
type cyclicGgi;
Dummy_25
type cyclicGgi;
Dummy_26
type cyclicGgi;
Dummy_27
type cyclicGgi;
Wall_30
type zeroGradient;
Inlet_31
type zeroGradient;
Wall_32
type zeroGradient;
Dummy_38
type cyclicGgi;
Wall_39
type zeroGradient;
Wall_48
type zeroGradient;
Outlet_61
type fixedValue;
Dummy_GGI_1
type cyclicGgi;
Dummy_GGI_2
type cyclicGgi;
Interface_22_23
type cyclicGgi;
Interface_28_29
type cyclicGgi;
Interface_36_37
type cyclicGgi;
Interface_40_41
type cyclicGgi;
Dummy_2_6_9
type cyclicGgi;
Dummy_33_34_35
type cyclicGgi;
Inlet_7
type zeroGradient;
Wall_8
type zeroGradient;
//value $internalField
van you see what the problem is?
dogan is offline   Reply With Quote
Old   December 9, 2013, 06:55
nash is on a distinguished road
Hi everyone,
i experience the same thing when i try to simulate the centrifugal fan.
here is my BC for p and U
U;
[internalField   uniform (0 0 0);
boundaryField
  "rotor.*"
      type            fixedValue;
  "gehaeuse.*"
      type            fixedValue;
      value        uniform (0 0 0) ;
  ebene
      type            fixedValue;
  outlet
      type            inletOutlet;
      inletValue      uniform (0 0 0);
  inlet
      type            flowRateInletVelocity;
      volumetricFlowRate $flowRate;
      value           uniform $inletFlow;
  rohr
      type            fixedValue;
"interface.*"
      type            cyclicAMI;
p;
boundaryField
  "rotor.*"
      type            zeroGradient;
 "gehaeuse.*"
      type            zeroGradient;
  ebene
      type            zeroGradient;
  inlet
      type zeroGradient;
      value    uniform 0;
  outlet
      type fixedMean;
     meanValue 0;
     value uniform 0;
  rohr
      type            zeroGradient;
 "interface.*"
      type            cyclicAMI;
the flow direction is okay from inlet to outlet and the rotation in the mrf is right as well.
the only thing that seems not right is the pressure in inlet is higher than that of outlet.
anyone can help me?
thank you.
regards,
nash
nash is offline   Reply With Quote
Old   December 9, 2013, 09:30
sivakumar selvaraju
Hi There,
Check your stagger angle, how is your torque, is it fine?
if you get less pressure raise and more torque, then there could be a problem with root stagger angle.
Thanks,
Sivakumar
Old   December 9, 2013, 09:35
Originally Posted by sivakumar View Post
Hi There,
Thanks,
Sivakumar
im using OF 2.2.0
how can i check the stagger angle as well as torque?
thank you for your help sivakumar
regards,
nash
-btw did you managed to solve the problem of having the higher pressure inlet than that of outlet?
Old   December 9, 2013, 09:50
sivakumar selvaraju
root stagger angle, you need to check your design properties.
to check the torque, copy and paste the function in your controlDict file
functions
forces
type forces;
functionObjectLibs ("libforces.so");
outputControl timeStep;
outputInterval 10;
patches (fan);
// pname p;
// Uname U;
rhoName rhoInf;
log true;
rhoInf 1.20; // density of the fluid
CofR (0 0 0);
run the simulation again, then check the torque.
Thanks,
Sivakumar
Old   December 9, 2013, 10:09
after running the simulation i got this for the forces output
forces output:
    forces(pressure,viscous)((-0.00468209 -0.00186217 -0.00295491),(0.00320589 -0.00866709 -0.00189832))
    moment(pressure,viscous)((4.12521e-06 -1.51542e-05 -0.000171072),(4.11675e-05 2.99142e-05 0.000155277))
how can i analyse them?
about the stagger angle, i think it is ok since it was constructed from the real fan.
Old   December 9, 2013, 10:26
sivakumar selvaraju
Check with your experimental torque, I think your torque is zero.
so you need to check your angle.
Old   December 9, 2013, 10:42
i will check it then.
but in your case, what is the problem that you were facing and how you overcome it?
thanks,
nash
Old   December 9, 2013, 13:56
i dont have the data
-nash-
Old   December 11, 2013, 09:57
i check my boundary conditions and compare them with the test case from the single channel pump with the mrf.
i cant see any much difference between them. however the pressure i get at inlet is lower than that of at outlet. i have check my mrf dict (fvOption) everything is fine.
so anyone can help me how to solve this ?
channelPumpCase
FoamFile
    version 2.0;
    format binary;
    root "/wrk6/mauvinen/wrkOpenFOAM/caseStorage";
    case "tubePumpWF";
    instance "0";
    local "";
    class volVectorField;
    object U;
boundaryField
    impellerWall
        type            fixedValue;
    inletDuct
        type            fixedValue;
    inlet
        type            fixedValue;
        value           uniform (0 0 3.407);
    impellerRim
        type            fixedValue;
    voluteWall
        type            fixedValue;
    outletDuct
        type            fixedValue;
    outlet
        type            zeroGradient;
   insideGGI
         type        ggi;
  outsideGGI
         type        ggi;
FoamFile
    version 2.0;
    format binary;
    case "tubePumpWF";
    instance "0";
    local "";
    class volScalarField;
    object p;
internalField   uniform 500;
boundaryField
    impellerWall
        type            zeroGradient;
    inletDuct
        type            zeroGradient;
    inlet
        type            zeroGradient;
    impellerRim
        type            zeroGradient;
    voluteWall
        type            zeroGradient;
    outletDuct
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 500;
   insideGGI
         type        ggi;
  outsideGGI
         type        ggi;
MyCase
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      p;
#include "include/initialConditions_q10_p132_5"
internalField   uniform 0 ;
boundaryField
  "rotor.*"
      type            zeroGradient;
 "gehaeuse.*"
      type            zeroGradient;
  ebene
      type            zeroGradient;
  inlet
      type zeroGradient;
      value    uniform 0;
  outlet
      type fixedMean;
     meanValue 0;
     value uniform 0;
  rohr
      type            zeroGradient;
 "interface.*"
      type            cyclicAMI;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      U;
boundaryField
  "rotor.*"
      type            fixedValue;
  "gehaeuse.*"
      type            fixedValue;
  ebene
      type            fixedValue;
  outlet
      type            inletOutlet;
  inlet
  rohr
      type            fixedValue;
"interface.*"
      type            cyclicAMI;
Old   December 12, 2013, 17:22
hi everyone its me again..
i know no one is replying to my question, but i will keep posting
so far i have done a simulation of radial fan with elongated cylinder lenght about 10 times of of the inlet diameter. The outlet is a semi hemisphere. But then i got pressure inlet higher than that of at outlet. So this is totally wrong. Fan should increase the pressure outlet.
So my next step is to change the inlet as semi hemsphere and for the outlet i just extend the end of the housing in about 10 times of the outlet (housing) diameter.
i will inform you guys about the result tomorrow. 2 variations of BC i will implement are assigning pressure difference between inlet and outlet, and assigning flowrate (maybe at outlet)
if anyone has suggestion, please feel free to post here. I hope i can get a good result and share this with others and helping each other.
thank you
regards,
nash
Old   December 16, 2013, 10:58
just a litte mistake from the mrf Definition in fvOption
in nonRotatingPatches
i just actually need to add AMI patches. Any rotating walls should not be added in nonRotatingPatches.
my inlet pressure is now lower than that of outlet.
hope this would help other fan simulator
ruikeradity1 likes this.
Old   April 24, 2016, 04:35
Fluidflow
cfdesf1990 is on a distinguished road
Hello
I know this is an old post but I have the same problem. I am simulating a centrifugal fan using Ansys CFX. Based on the results, the inlet pressure is higher than outlet pressure although the difference magnitude is what I expected from the experimental data. I mean, the pressure difference in experimental data is 1000 pa and when I calculate average total pressure difference between outlet and inlet it is -1000 pa. So what's wrong with that?
Regards
cfdesf1990 is offline   Reply With Quote
Old   December 30, 2017, 15:16
Aaditya Maharashtra
ruikeradity1 is on a distinguished road
I am doing simulation of axial flow fan using MRFsimplefoam and also gets results like inlet pressure is more than outlet pressure
ruikeradity1 is offline   Reply With Quote
Boundary Conditions: Pressure Inlet, Velocity Outlet BigPapi34 OpenFOAM Running, Solving & CFD 4 August 2, 2014 12:39
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 01:11
Help ASAP! pressure inlet & outlet engahmed FLUENT 0 June 13, 2010 16:33
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
