HelyxOS problem while reading an STL file
Like Tree1Likes
  • 1 Post By chegdan
Old   October 7, 2012, 07:32
Default HelyxOS problem while reading an STL file
Oleksy Armas
HelyxOS is on a distinguished road
Hello all!
I have problems with HelyxOS....Do you know how to fix such problem...
I have put in terminal command (recommended by wyldcat) for VTK issue:
ln -s $MPI_ARCH_PATH/lib/libmpi.so $MPI_ARCH_PATH/lib/libmpi.so.0
After this, VTK worked good (I have made BOX on view , but after STL file loaded HELYX-OS crashed...
It crashes after every attempt to load an STL ASCII File
ubuntu@ubuntu:~/Desktop/Engys/HelyxOS/v1.0.0$ ./helyxOS.sh
java -Xms128m -Xmx1024m -jar ./lib/HelyxOS.jar
vtkHybridJava NOT loaded: /home/ubuntu/Desktop/Engys/HelyxOS/v1.0.0/ext/libvtkHybridJava.so.5.10.0: libmpi.so.1: nie można otworzyć pliku obiektu dzielonego: Nie ma takiego pliku ani katalogu
java.lang.UnsatisfiedLinkError: /home/ubuntu/Desktop/Engys/HelyxOS/v1.0.0/ext/libvtkHybridJava.so.5.10.0: libmpi.so.1: nie można otworzyć pliku obiektu dzielonego: Nie ma takiego pliku ani katalogu
    at java.lang.ClassLoader$NativeLibrary.load(Native Method)
    at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1807)
    at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1732)
    at java.lang.Runtime.loadLibrary0(Runtime.java:823)
    at java.lang.System.loadLibrary(System.java:1028)
    at eu.engys.helyx.vtk.VTKUtil.loadLibrary(VTKUtil.java:96)
    at eu.engys.helyx.vtk.VTKUtil.LoadAllNativeLibraries(VTKUtil.java:72)
    at eu.engys.helyx.gui.Launcher.main(Launcher.java:44)
Make sure the search path is correct:
/home/ubuntu/Desktop/Engys/HelyxOS/jre/lib/amd64/server:/home/ubuntu/Desktop/Engys/HelyxOS/jre/lib/amd64:/home/ubuntu/Desktop/Engys/HelyxOS/jre/../lib/amd64:./ext:./../jre/lib/amd64/xawt:/opt/paraviewopenfoam3120/lib/paraview-3.12:/opt/openfoam211/platforms/linux64GccDPOpt/lib/openmpi-system:/opt/ThirdParty-2.1.1/platforms/linux64GccDPOpt/lib/openmpi-system:/usr/lib/openmpi/lib:/home/ubuntu/OpenFOAM/ubuntu-2.1.1/platforms/linux64GccDPOpt/lib:/opt/site/2.1.1/platforms/linux64GccDPOpt/lib:/opt/openfoam211/platforms/linux64GccDPOpt/lib:/opt/ThirdParty-2.1.1/platforms/linux64GccDPOpt/lib:/opt/openfoam211/platforms/linux64GccDPOpt/lib/dummy:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
ubuntu@ubuntu:~/Desktop/Engys/HelyxOS/v1.0.0$ sudo ln -s $MPI_ARCH_PATH/lib64/libmpi.so $MPI_ARCH_PATH/lib64/libmpi.so.0
ln: tworzenie dowiązania symbolicznego `/usr/lib/openmpi/lib64/libmpi.so.0': Nie ma takiego pliku ani katalogu
ubuntu@ubuntu:~/Desktop/Engys/HelyxOS/v1.0.0$ sudo ln -s $MPI_ARCH_PATH/lib64/libmpi.so $MPI_ARCH_PATH/lib64/libmpi.so.1
ln: tworzenie dowiązania symbolicznego `/usr/lib/openmpi/lib64/libmpi.so.1': Nie ma takiego pliku ani katalogu
ubuntu@ubuntu:~/Desktop/Engys/HelyxOS/v1.0.0$ ln -s $MPI_ARCH_PATH/lib/libmpi.so $MPI_ARCH_PATH/lib/libmpi.so.1
ln: tworzenie dowiązania symbolicznego `/usr/lib/openmpi/lib/libmpi.so.1': Brak dostępu
ubuntu@ubuntu:~/Desktop/Engys/HelyxOS/v1.0.0$ sudo ln -s $MPI_ARCH_PATH/lib/libmpi.so $MPI_ARCH_PATH/lib/libmpi.so.1
WRITE: blockMeshDict -> /home/ubuntu/Desktop/NC/newCase/system/blockMeshDict
WRITE: snappyHexMeshDict -> /home/ubuntu/Desktop/NC/newCase/system/snappyHexMeshDict
WRITE: controlDict -> /home/ubuntu/Desktop/NC/newCase/system/controlDict
WRITE: fvSchemes -> /home/ubuntu/Desktop/NC/newCase/system/fvSchemes
WRITE: fvSolution -> /home/ubuntu/Desktop/NC/newCase/system/fvSolution
WRITE: decomposeParDict -> /home/ubuntu/Desktop/NC/newCase/system/decomposeParDict
Stl.addBox(): box min [0.0, 0.0, 0.0], max [2.0, 2.0, 1.0]
VolumeRefinementBuilder.buildVolumeDictionary()
box
    mode inside;
    levels 0;
STLUtils.copyToTriSurface() /home/ubuntu/Desktop/NC/newCase/constant/triSurface/lambo_gallardo_Poizia.stl
*** glibc detected *** java: double free or corruption (out): 0x00007fe5cdd1ea80 ***
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x78a8f)[0x7fe5d5c19a8f]
/lib/x86_64-linux-gnu/libc.so.6(cfree+0x73)[0x7fe5d5c1d8e3]
/lib/x86_64-linux-gnu/libc.so.6(fclose+0x155)[0x7fe5d5c08235]
./ext/libvtkIO.so.5.10(_ZN12vtkSTLReader11RequestDataEP14vtkInformationPP20vtkInformationVectorS3_+0x2b6)[0x7fe5c5122f86]
./ext/libvtkFiltering.so.5.10(_ZN12vtkExecutive13CallAlgorithmEP14vtkInformationiPP20vtkInformationVectorS3_+0x55)[0x7fe5c7ef9515]
./ext/libvtkFiltering.so.5.10(_ZN23vtkDemandDrivenPipeline11ExecuteDataEP14vtkInformationPP20vtkInformationVectorS3_+0x4e)[0x7fe5c7eeca7e]
./ext/libvtkFiltering.so.5.10(_ZN23vtkDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3_+0x158)[0x7fe5c7eee4d8]
./ext/libvtkFiltering.so.5.10(_ZN32vtkStreamingDemandDrivenPipeline14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3_+0x1ea)[0x7fe5c804b18a]
./ext/libvtkFiltering.so.5.10(_ZN23vtkDemandDrivenPipeline10UpdateDataEi+0x9e)[0x7fe5c7eec71e]
./ext/libvtkFiltering.so.5.10(_ZN32vtkStreamingDemandDrivenPipeline6UpdateEi+0xaf)[0x7fe5c804b99f]
[0x7fe5c8e06d6e]
======= Memory map: ========
40000000-40009000 r-xp 00000000 00:11 71346                              /home/ubuntu/Desktop/Engys/HelyxOS/jre/bin/java
40108000-4010a000 rwxp 00008000 00:11 71346                              /home/ubuntu/Desktop/Engys/HelyxOS/jre/bin/java
40e7f000-442d6000 rwxp 00000000 00:00 0                                  [heap]
bae00000-be770000 rwxp 00000000 00:00 0
be770000-c0000000 rwxp 00000000 00:00 0
c0000000-c5560000 rwxp 00000000 00:00 0
c5560000-eaab0000 rwxp 00000000 00:00 0
eaab0000-ed550000 rwxp 00000000 00:00 0
ed550000-100000000 rwxp 00000000 00:00 0
7fe5bd5be000-7fe5bd5bf000 rwxs 180183000 00:05 5655                      /dev/dri/card0
7fe5bd7a8000-7fe5bd994000 rwxs 1804cc000 00:05 5655                      /dev/dri/card0
7fe5bd994000-7fe5bdb80000 rwxs 180d4a000 00:05 5655                      /dev/dri/card0
7fe5bdb80000-7fe5bdf61000 rwxs 00000000 00:04 1736716                    /SYSV00000000 (deleted)
7fe5bdf61000-7fe5bdf77000 r-xp 00000000 00:11 96202                      /home/ubuntu/Desktop/Engys/HelyxOS/jre/lib/amd64/libdcpr.so
7fe5bdf77000-7fe5be079000 ---p 00016000 00:11 96202                      /home/ubuntu/Desktop/Engys/HelyxOS/jre/lib/amd64/libdcpr.so
7fe5be079000-7fe5be091000 rwxp 00018000 00:11 96202                      /home/ubuntu/Desktop/Engys/HelyxOS/jre/lib/amd64/libdcpr.so
7fe5be44a000-7fe5be44d000 ---p 00000000 00:00 0
7fe5be44d000-7fe5be54b000 rwxp 00000000 00:00 0
7fe5be54b000-7fe5be54d000 rwxs 180348000 00:05 5655                      /dev/dri/card0
7fe5be54d000-7fe5be55d000 rwxs 180332000 00:05 5655                      /dev/dri/card0
7fe5be55e000-7fe5be55f000 rwxs 180320000 00:05 5655                      /dev/dri/card0
7fe5be562000-7fe5be563000 rwxs 18031c000 00:05 5655                      /dev/dri/card0
7fe5be565000-7fe5be566000 rwxs 180319000 00:05 5655                      /dev/dri/card0
7fe5be569000-7fe5be56a000 rwxs 180317000 00:05 5655                      /dev/dri/card0
7fe5be571000-7fe5be574000 ---p 00000000 00:00 0
7fe5be574000-7fe5be672000 rwxp 00000000 00:00 0
7fe5be672000-7fe5be699000 r-xp 00000000 00:11 1980                       /lib/x86_64-linux-gnu/libexpat.so.1.5.2
7fe5be699000-7fe5be899000 ---p 00027000 00:11 1980                       /lib/x86_64-linux-gnu/libexpat.so.1.5.2
7fe5be899000-7fe5be89b000 r-xp 00027000 00:11 1980                       /lib/x86_64-linux-gnu/libexpat.so.1.5.2
7fe5be89b000-7fe5be89c000 rwxp 00029000 00:11 1980                       /lib/x86_64-linux-gnu/libexpat.so.1.5.2
7fe5be89c000-7fe5be996000 r-xp 00000000 00:11 3389                       /usr/lib/dri/libglsl.so
7fe5be996000-7fe5beb95000 ---p 000fa000 00:11 3389                       /usr/lib/dri/libglsl.so
7fe5beb95000-7fe5beb9d000 r-xp 000f9000 00:11 3389                       /usr/lib/dri/libglsl.so
7fe5beb9d000-7fe5beb9f000 rwxp 00101000 00:11 3389                       /usr/lib/dri/libglsl.so
7fe5beb9f000-7fe5beba0000 rwxp 00000000 00:00 0
7fe5beba0000-7fe5bedb8000 r-xp 00000000 00:11 3384                       /usr/lib/dri/libdricore.so
7fe5bedb8000-7fe5befb8000 ---p 00218000 00:11 3384                       /usr/lib/dri/libdricore.so
7fe5befb8000-7fe5befc2000 r-xp 00218000 00:11 3384                       /usr/lib/dri/libdricore.so
7fe5befc2000-7fe5befc5000 rwxp 00222000 00:11 3384                       /usr/lib/dri/libdricore.so
7fe5befc5000-7fe5befd5000 rwxp 00000000 00:00 0
7fe5befd5000-7fe5bf312000 r-xp 00000000 00:11 3371                       /usr/lib/dri/r600_dri.so
7fe5bf312000-7fe5bf512000 ---p 0033d000 00:11 3371                       /usr/lib/dri/r600_dri.so
7fe5bf512000-7fe5bf529000 r-xp 0033d000 00:11 3371                       /usr/lib/dri/r600_dri.so
7fe5bf529000-7fe5bf530000 rwxp 00354000 00:11 3371                       /usr/lib/dri/r600_dri.so
7fe5bf530000-7fe5bf57e000 rwxp 00000000 00:00 0
7fe5bf57e000-7fe5bf581000 ---p 00000000 00:00 0
7fe5bf581000-7fe5bf67f000 rwxp 00000000 00:00 0
7fe5bf67f000-7fe5bf682000 ---p 00000000 00:00 0
7fe5bf682000-7fe5bf780000 rwxp 00000000 00:00 0
7fe5bf780000-7fe5bf783000 ---p 00000000 00:00 0
7fe5bf783000-7fe5bf881000 rwxp 00000000 00:00 0
7fe5bf881000-7fe5bf884000 ---p 00000000 00:00 0
7fe5bf884000-7fe5bf982000 rwxp 00000000 00:00 0
7fe5bf982000-7fe5bf989000 r-xp 00000000 00:11 96168                      /home/ubuntu/Desktop/Engys/HelyxOS/jre/lib/amd64/libnio.so
7fe5bf989000-7fe5bfa88000 ---p 00007000 00:11 96168                      /home/ubuntu/Desktop/Engys/HelyxOS/jre/lib/amd64/libnio.so
7fe5bfa88000-7fe5bfa8a000 rwxp 00006000 00:11 96168                      /home/ubuntu/Desktop/Engys/HelyxOS/jre/lib/amd64/libnio.so
7fe5bfa8a000-7fe5bfa9d000 r-xp 00000000 00:11 96167                      /home/ubuntu/Desktop/Engys/HelyxOS/jre/lib/amd64/libnet.so
7fe5bfa9d000-7fe5bfb9e000 ---p 00013000 00:11 96167                      /home/ubuntu/Desktop/Engys/HelyxOS/jre/lib/amd64/libnet.so
7fe5bfb9e000-7fe5bfba1000 rwxp 00014000 00:11 96167                      /home/ubuntu/Desktop/Engys/HelyxOS/jre/lib/amd64/libnet.so
7fe5bfba1000-7fe5bfba4000 ---p 00000000 00:00 0
7fe5bfba4000-7fe5bfca2000 rwxp 00000000 00:00 0
7fe5bfca2000-7fe5bfca5000 ---p 00000000 00:00 0
7fe5bfca5000-7fe5bfda3000 rwxp 00000000 00:00 0
7fe5bfda3000-7fe5bfde1000 r-xp 00000000 00:11 96556                      /home/ubuntu/Desktop/Engys/HelyxOS/v1.0.0/ext/libvtkParallelJava.so.5.10.0
7fe5bfde1000-7fe5bfee1000 ---p 0003e000 00:11 96556                      /home/ubuntu/Desktop/Engys/HelyxOS/v1.0.0/ext/libvtkParallelJava.so.5.10.0
7fe5bfee1000-7fe5bfee2000 rwxp 0003e000 00:11 96556                      /home/ubuntu/Desktop/Engys/HelyxOS/v1.0.0/ext/libvtkParallelJava.so.5.10.0
7fe5bfee2000-7fe5bfee5000 ---p 00000000 00:00 0
7fe5bfee5000-7fe5bffe3000 rwxp 00000000 00:00 0
7fe5bffe3000-7fe5bffe6000 ---p 00000000 00:00 0
7fe5bffe6000-7fe5c00e4000 rwxp 00000000 00:00 0
7fe5c00e4000-7fe5c015d000 r-xp 00000000 00:11 96176                      /home/ubuntu/Desktop/Engys/HelyxOS/jre/lib/amd64/libfontmanager.so
7fe5c015d000-7fe5c025c000 ---p 00079000 00:11 96176                      /home/ubuntu/Desktop/Engys/HelyxOS/jre/lib/amd64/libfontmanager.so./helyxOS.sh: line 124: 18069 Przerwane               (core dumped) ${JAVA} ${LOCALEFLAG} ${JFLAG} ${XFLAG} ${HELYXJAR} ${HELYXARG} ${VERBOSITY_LEVEL} $@ 1>&2
HelyxOS is offline   Reply With Quote
Old   October 9, 2012, 06:37
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
can you load your STL file in Paraview?
chegdan is offline   Reply With Quote
Old   October 14, 2012, 15:28
Red face
kjw
Krzysztof Wołosz
kjw is on a distinguished road
Hello and Welcome in my first post in the forum.
I have also a problem during the STL ASCII import into the Helyx OS. The crash looks the same as mentioned above. And answering the Dan's question: Yes, I can load the STL file in the Paraview and everything looks good.
Some answers may be given when the file presented in the example http://www.youtube.com/watch?v=yJbFnFzDLqo
could be available (ahmed_body.stl).
Regards
Christopher
kjw is offline   Reply With Quote
Old   October 15, 2012, 07:06
Daniel P. Combest
Regards
Christopher
What is the result of the command
locale
and also, what is the character in your STL file that is used to separate the decimal numbers i.e. is it 3.14159 or 3,14159?
Old   October 16, 2012, 04:01
kjw
Krzysztof Wołosz
Good question was the answer. I had polish locales set and when I changed it to english everything is correct and works fine.
Regards
locale
Old   October 16, 2012, 06:58
Daniel P. Combest
Excellent! This happens to be a VTK problem that is not completely fixed in the VTK distribution. Another possible solution is to change your decimal separator to a "," in your STL file instead of changing your language settings.
Regards
Mariusz likes this.
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 15:22
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
