May 23, 2012, 07:09 |
1D turbulence test case
Luca M.
Hello everyone,
I'm doing uncertainty quantification and I need to run 1D test case simulations. I'd like to know if openFoam is a good solver for a 1D channel flow turbulence k-epsilon model solution. I'm supposed to use fluent, but it doesn't have monodimensional solution right? Is there a better software for monodimensional simulations, or do you think that the best thing would be to write a solver? Thanks in advance, Luca |
June 14, 2012, 06:02 |
Luca M.
I'm sorry, I'll try to explain.
I'm running a turbulent channel flow test case on Fluent but Fluent doesn't accept 1D domain and I need to add 3 knots in the streamwise direction and to set a periodic condition, so at the end I get 3xnumber of 1D elements. Does Openfoam or other solvers allow you to set a 1D domain for this case (I need k-eps standard model as Fluent)? I'm running about 2000 simulations so it would be really less expensive! So maybe if I don't find anything I should write a solver?! But I don't have enough experience to do it fast =P Is it clear now? Thanks in advance! |
June 14, 2012, 10:00 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Luca,
It's a bit ironic, because if it were not for the spammer, I wouldn't even had noticed your thread. Additionally, it's good that you've detailed more your question. Hopefully someone will be able to answer you. Best regards, Bruno
April 9, 2015, 07:24 |
November 6, 2016, 05:36 |
Freedom
Rep Power: 13 |
Anyone has experience with the 1D simulation with OF?
November 7, 2016, 04:52 |
Olivier
Rep Power: 18 |
hello,
Yes, you can do 1D: just use empty BC for front, back and side, and just set BC on bottom/top. Work well for me. But turbulence k-e simulation on 1D seem .. original ! regards, Olivier |
November 7, 2016, 05:25 |
#7 | |
Freedom
Rep Power: 13 |
In your case, it is the non-reacting fluid flow or reacting one? I do not know whether the 1D flame can be simulated by OF. Best regards, Xu |
November 7, 2016, 05:27 |
Olivier
Rep Power: 18 |
hello,
In my case it was a plasma simulation, so similar to a reacting solver. regards, Olivier |
November 7, 2016, 05:29 |
#9 |
Freedom
Rep Power: 13 |
Thanks, I should have a try!
May 20, 2019, 07:38 |
#10 |
arya123xyz
Rep Power: 11 |
Sir, can you post the test case you tried in OF ?
channel flow, test cases, turbulence model |
Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 07:35 |
How to find standard store-seperation test case? | peter.zhao | Main CFD Forum | 6 | March 6, 2015 12:31 |
SimpleFoam case with SpalartAllmaras turbulence model implemented | nedved | OpenFOAM Running, Solving & CFD | 2 | November 30, 2014 23:43 |
Test Case: Laminar Flow Between Rotating Concentric Cylinders | ebertmp | OpenFOAM | 4 | December 3, 2012 12:54 |
Help Required With Simple Test Case | steph79 | OpenFOAM Pre-Processing | 4 | August 3, 2010 08:45 |
