Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
post-processing utility R, calculating Reynolds stress tensor
Like Tree13Likes
  • 1 Post By volker
  • 2 Post By chegdan
  • 1 Post By rajeshkunwar
  • 3 Post By johnkh
  • 2 Post By canopus
  • 3 Post By Jess80
  • 1 Post By Jess80
Old   February 3, 2010, 06:35
Default post-processing utility R, calculating Reynolds stress tensor
Volker Tritschler
volker is on a distinguished road
I experienced a problem when using the post-processing utility R to evaluate the Reynolds stress tensor based on a compressible simulation using a kEpsilon turbulence model. The Reynolds stress tensor is needed as initialization for a RSM simulation.
The problem I experienced is basically related to the compressible nature of my simulation and it seems that the R-utility is written exclusively for incompressible flows (makes use of transportProperties file).
I searched already the forum without success.
Does anybody have a suggestion how to resolve that issue?
I'm happy about any idea.
Greets, Volker
maphd likes this.
volker is offline   Reply With Quote
Old   February 28, 2010, 14:02
Stefan
SD@TUB is on a distinguished road
Hello Volker,
reading in Doxygen --> base class for incompressible turbulence models, i guess that R just work for incompressible turbulent calcualtions so far.
I tried some sampling with your mentioned tool and i'm a little confused, 'cause i get six columns for the reynolds stress tensor in my output file!
Could you/someone explain me the columns? In Doxygen i can't find the source of the utility R!
For future development of post-processing tools it would be useful to include an obvious header to the produced output files.
Regards,
/Stefan
SD@TUB is offline   Reply With Quote
Old   April 13, 2011, 13:46
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Originally Posted by SD@TUB View Post
Hello Volker,
Regards,
/Stefan
I know this is old, but I thought I would answer anyway.
You only have 6 components because you have a symmetric tensor Rxx, Ryy, Rzz, Rxy, Rxz, Ryz. that means that Rxy=Ryx, Rxz=Rzx, and Ryz=Rzy.
chegdan is offline   Reply With Quote
Old   May 2, 2013, 00:39
Rajesh Kumar
rajeshkunwar is on a distinguished road
Hi Volker,
I am also facing the same problem while getting Reynolds stress. Did u solve this issue? If yes, please post the solution so that others can also get benefited.
Regards
Rajesh
rajeshkunwar is offline   Reply With Quote
Old   May 2, 2013, 09:40
Daniel P. Combest
You can make a custom tool to calculate R for compressible cases. To create a compressible turbulence model you will need to read in:
    Info<< "Creating turbulence model\n" << endl;
    autoPtr<compressible::turbulenceModel> turbulence
        compressible::turbulenceModel::New
            rho,
            U,
            phi,
            thermo
So you will need a thermo object to pass to the constructor. Basically, you will have to look at a compressible solver (e.g. rhoPimpleFoam) and add things like a compressible phi, thermo from basiPsiThermo, etc. Most of these changes are in the createFields.H file in the R utility....but I suggest you make your own utility separately called something like "Rcompressible". Additioanlly, you will have to change some entries in the Make/Options file to let the compiler know where to search for these new "compressible" classes. Hope this helps.
mgg and charmc like this.
Old   May 2, 2013, 14:09
Rajesh Kumar
Thanks Mr. Daniel for your help.
I have created the utility for computing Reynolds stresses for compressible solver.
Regards
Rajesh
charmc likes this.
Old   July 20, 2013, 11:14
charmc is on a distinguished road
Dear Rajesh:
As a newer to openfoam ! Can you write more detail about how to
creat the utility for computing Reynolds stresses for compressible solver ?
Thank you !
charmc is offline   Reply With Quote
Old   February 19, 2014, 18:16
Question
flames is on a distinguished road
Hello there,
In openfoam, what is the order of the components in Reynolds stress tensor? For example, the Reynolds stress is (1,2, 3, 4, 5, 6), how these 6 components corresponds to the Rxx, Ryy ......? Thank you in advance!
flames
flames is offline   Reply With Quote
Old   March 27, 2014, 00:37
John Khoo
johnkh is on a distinguished road
Rxx, Rxy, Rxz, Ryy, Ryz and Rzz correspond to R(0), R(3), R(4), R(1), R(5) and R(2) respectively.
johnkh is offline   Reply With Quote
Old   April 14, 2014, 12:32
maphd is on a distinguished road
I have a question: is there a way to read Reynolds stresses directly from Fluent? If you could help me on this, I really appreciate it.
Thanks,
maphd is offline   Reply With Quote
Old   July 30, 2014, 06:14
Jens
jensi_t is on a distinguished road
Hey maphd,
you can use the fluentDataToFoam utility, but you have to adapt it bacause Reynolds Stresses are missing:
    //Reynolds stresses
    if (fields.found(128) || fields.found(129) || fields.found(130) || fields.found(131) || fields.found(132) || fields.found(133))
        Info << "Converting reynolds-stresses field" << endl;
        volSymmTensorField R
            IOobject
                "R",
                mesh.time().timeName(),
                mesh,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            mesh,
            dimensionedSymmTensor("zero", dimensionSet(0, 2, -2, 0, 0, 0, 0), symmTensor::zero)
        if (fields.found(128))
            R.replace
                symmTensor::XX,
                fdc.convertField
                    "UU",   // field name
                    128,           // fluent Unit number
                    dimensionedScalar("zero", dimensionSet(0, 2, -2, 0, 0, 0, 0), 0)
        if (fields.found(129))
            R.replace
                symmTensor::YY,
                fdc.convertField
                    "VV",   // field name
                    129,           // fluent Unit number
        if (fields.found(130))
            R.replace
                symmTensor::ZZ,
                fdc.convertField
                    "WW",   // field name
                    130,           // fluent Unit number
        if (fields.found(131))
            R.replace
                symmTensor::XY,
                fdc.convertField
                    "UV",   // field name
                    131,           // fluent Unit number
        if (fields.found(132))
            R.replace
                symmTensor::YZ,
                fdc.convertField
                    "VW",   // field name
                    132,           // fluent Unit number
        if (fields.found(133))
            R.replace
                symmTensor::XZ,
                fdc.convertField
                    "UW",   // field name
                    133,           // fluent Unit number
        R.write();
epsilon as well as i remember
        if (fields.found(6))
        Info << "Converting dissipation rate field" << endl;
        fdc.convertField
            "epsilon",   // field name
            6,     // fluent Unit number
            dimensionedScalar("zero", dimensionSet(0, 2, -3, 0, 0, 0, 0), 0)
        )().write();
Last edited by jensi_t; August 4, 2014 at 12:52. Reason: I think i mixed the fields up sorry. Now it should work
jensi_t is offline   Reply With Quote
Old   January 17, 2016, 09:28
Default Listing order of output of R utility
  #12
SM
canopus is on a distinguished road
Thanks to JohnKhoo and to make it clear-
Output files obtained by executing R utility (and those obtained by running sample on it) list Reynolds stresses in order of
respectively.
and for viewing in paraview the same corresponds to
respectively.
abas.rahmani86 and Gerhard like this.
canopus is offline   Reply With Quote
Old   July 23, 2017, 06:13
Ali
abas.rahmani86 is on a distinguished road
hi guys
I want to know how i can extraction reynolds stress tensor from k-e model theorically?
tnx
abas.rahmani86 is offline   Reply With Quote
Old   January 19, 2018, 12:16
Default Relation between Reynolds stress tensor and k (turbulent kinetic energy)
  #14
Jessica Guichard
Jess80 is on a distinguished road
know that k, the turbulent kinetic energy par unity of mass, can be calculated with
k=1/2 (U'x^2+U'y^2+U'z^2 ) where U'x, U'y and U'z are the fluctuating components of velocity in the x, y and z directions.
whereas R is a symmetric tensor with the following components:
Rxx Rxy Rxz
Rxy Ryy Ryz
Rxz Ryz Rzz
and with Rxx=U'x^2
Rxy=0 if isotropic turbulence (same in all directions), otherwise Rxy=Temporal Average (U’x*U’y)
Rxz=0 if isotropic turbulence (same in all directions) , otherwise Rxz=Temporal Average (U’x*U’z)
Ryy=U'y^2
Ryz=0 if isotropic turbulence (same in all directions), otherwise Ryz=Temporal Average (U’y*U’z)
Rzz=U'z^2
If Rxy=Rxz=Ryz=0, k=0.5*(Rxx+Ryy+Rzz)
The other way around you have to make the assumption that turbulence is isotropic, that is Rxx=Ryy=Rzz and Rxy=Rxz=Ryz=0 and therefore Rxx=2k/3.
Hope this helps.
aow, abas.rahmani86 and tomjo like this.
Jess80 is offline   Reply With Quote
Old   January 23, 2018, 08:14
Default Corrections to post above
  #15
Jessica Guichard
After searching the OpenFOAM code, I finally found the piece of code that indicates how R is calculated.
It is in the file named eddyViscosity.C and can be consulted at this link: https://www.openfoam.com/documentati...8C_source.html
At line 117: ((2.0/3.0)*I)*tk() - (nut_)*dev(twoSymm(fvc::grad(this->U_)))
When calculating R with the k- ε model, the code for the calculation of the value of nut can be found in kEpsilon.C, line 42 (https://www.openfoam.com/documentati...8C_source.html)
this->nut_ = Cmu_*sqr(k_)/epsilon_;
abas.rahmani86 likes this.
Old   June 19, 2019, 07:26
Default Switcheroo in R-Field?
  #16
Marcio is on a distinguished road
Hey guys,
after searching for the Order of the Reynolds Stress file R in OF to compare wirh ParaView I found a switcheroo in the last posts. I mean this post explicitly:
respectively.
respectively.
Can somebody else confirm it? The order I saw comparing OF 5.0 and ParaView 5.6 is following:
Rxx , Rxy , Rxz , Ryy , Ryz and Rzz |OpenFoam
R(0), R(3), R(5), R(1), R(4) and R(2) |ParaView
I used the Calculator to extract the Scalar-values for every R-value and compared it to a corresponding line in the turbulenceProperties_R-file
Marcio is offline   Reply With Quote
Old   November 5, 2019, 04:16
FoamingSimon is on a distinguished road
Originally Posted by Marcio View Post
Hey guys,
I get the same results, using OF 7 and Paraview 5.6.0, when extracting data and comparing these with Paraview plots.
FoamingSimon is offline   Reply With Quote
Old   May 21, 2020, 18:36
Reviewer #2
randolph is on a distinguished road
Seems legit with OpenFOAM v1912 and Paraview 5.6.3
randolph is offline   Reply With Quote
Old   July 6, 2024, 13:15
ARG
Masoud Rvn
ARG is on a distinguished road
Seems to be true for OpenFOAM2312 and ParaView 5.12.0-RC3
ARG is offline   Reply With Quote
Reynolds Stress Boundary Conditions tstorm FLUENT 0 July 27, 2009 15:44
Post processing - Wall shear stress Carlo Siemens 1 March 4, 2009 08:35
Questions about the Reynolds stress model empirer2002 Main CFD Forum 1 January 5, 2006 08:37
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 12:59
