Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
InterFoam freeSurface area calculation with sampleSurface
Like Tree3Likes
  • 3 Post By PrzemekPL
Old   December 28, 2007, 07:32
Default Dear Forum Wish you all a v
jaswi is on a distinguished road
Dear Forum
Wish you all a very nice day.
I am using interFoam and for the post processing i need the surface area of the free surface.
Using sampleSurface i could extract the isoSurface. Didn't know it was so easy !!!!! :-)
This is how the sampleDict looks
interpolationScheme cellPointFace;
surfaceFormat foamFile;
surfaces
interpolatedIsoSurface
name gammaSurface;
field gamma;
value 0.5;
fields
gamma
As a result i have the faces and points which correspond to this surface. Using the able given dict with the
surfaceFormat vtk;
I could see the surface in paraFoam.
I sense that with points and faces available one can for sure calculate the area of this surface.
Please share if someone knows about a utility or tool in openFoam to take the next step.
Wishing you all Happy Holidays
Jaswinder
jaswi is offline   Reply With Quote
Old   December 28, 2007, 10:38
Default Can't Paraview calculate the a
Mattijs Janssens
mattijs is on a distinguished road
Can't Paraview calculate the area?
mattijs is offline   Reply With Quote
Old   December 28, 2007, 16:29
Default Hi Mattijs Thanks for your
Hi Mattijs
Thanks for your reply.
I tried various options under the filter section of paraview but couldn't get the job done.
The isoSurface option in paraview shows the free surface corresponding to gamma lying in the interval [0,1] but no where i could find an option which could calculate its area.
It seems from your question that it must be quite easy to do that. please give some tips where to look for or which filter does that.
Best Regards
Jaswinder
Old   December 29, 2007, 09:57
Default Try selecting the 'foamFile' t
Mattijs Janssens
Try selecting the 'foamFile' type (sampleSurface/surfaceWriters/foamFile/foamFile.C).
Read in your pointField from an IFstream of the "points" file. Read in a faceList from the "faces" file. Sum all areas:
scalar area = 0;
forAll(faces, i)
area += faces[i].mag(points);
Old   December 29, 2007, 12:42
Default It is very interesting to find
vof_user
asaha is on a distinguished road
It is very interesting to find the area of free surface, though I have never thought of it before doing with interFoam. I would appreciate giving details how to implement this.
asaha is offline   Reply With Quote
Old   December 29, 2007, 15:14
Default Hi Mattijs Thanks once agai
Hi Mattijs
Thanks once again for your reply.
Will try it and probably will need some more help if i would get some compiling errors.
Best Regards
Jaswinder
Old   June 26, 2008, 15:40
Default Jaswinder, I have created a
Scott Ford
saf5029 is on a distinguished road
Jaswinder,
I have created a sampleSurfaceDict 100% identical to yours, and when I execute it, my files for
sampleSurface/15/gammaSurface/scalarField/gamma
sampleSurface/15/gammaSurface/points and
sampleSurface/15/gammaSurface/faces
merely look like this:
0()
Did you ever experience this sort of issue?? If so can you provide any insight??
saf5029 is offline   Reply With Quote
Old   December 9, 2009, 04:52
P.M.Bronow
PrzemekPL is on a distinguished road
Hi Jaswinder and other OF users,
Did you manage to calculate freeSurace area?
I'm dealing with the same problem now.
I'm using OF1.6
I understand Jaswinders way of thinking (first post in this thread) but I can't follow mattijs tips.
Could anyone give me and other users more tips regarding to the freeSurface area calculation.
Thanks
Przemek
PrzemekPL is offline   Reply With Quote
Old   December 10, 2009, 09:57
Hi Przemek
Please insert this into your code and it shall give you the correct free surface area.
(this code snippet is available courtesy of Eugene De Villiers)
volScalarField gradGamma
= mag(fvc::grad(gamma));
scalar totalSurfaceArea
= sum(gradGamma.internalField()*mesh.V());
For parallel runs, change sum to gSum. For a simple check for validation, try calculating area of circle or rectangle for cylindrical and cube geometries. In that way you will see that this formulation does gives you a very accurate calculation for surface area.
Hope that helps
Best Regards
jaswi
Old   December 10, 2009, 12:07
P.M.Bronow
Hi Jaswi,
Thank you for your answer!!
I'll apply your code before next simulation.
This will give me area of the whole free surface but I need also to measure free surface area only in some particular locations.
I just found how to make it in paraview without any additional coding.
I write it here for others, hope this will help someone
Step by step, how to measure free surface area in paraview:
  1. Use Contour tool to plot free surface.
  2. Use Clip to show only interesting for you part of the domain and free surface which has to be measured.
  3. Use Integrate Variables tool. Table with data should appear. In table change Attribute from Point Data to Cell Data and you should see Area in one of the columns. This is what you are looking for
Alternative way:
  2. Use Clip to show only interesting you part of the domain and free surface which has to be measured.
  3. Export Data to .VRML format which can be imported in some graphical software. I've imported it in Rhinoceros and used it to measure area of the free surface.
Greetings
Przemek
Calculating Interface Area with InterFoam gopala OpenFOAM Running, Solving & CFD 28 December 23, 2021 03:51
What is the Finite Area Methodamphow to do the FAM calculation in FOAM waynezw0618 OpenFOAM Running, Solving & CFD 5 April 24, 2015 09:35
Frontal area calculation Stefan CFX 1 June 12, 2006 22:03
Numerical calculation interFoam never finishes unoder OpenFOAM Running, Solving & CFD 9 October 18, 2005 06:00
area volume calculation fundamentals Ankur Kulkanri Main CFD Forum 0 September 10, 2003 13:00
