Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to check Heat Balance in heat transfer like mass balance for flow
Like Tree2Likes
  • 1 Post By mahendra
  • 1 Post By mahaputra
Old   November 13, 2008, 08:37
Default Dear Foamers hello ! Is the
Mahendra
mahendra is on a distinguished road
Is there any utility to check heat balance in heat transfer cases like we check mass balance for flow using "calcMassFlow" utiliy?
Thanks,
Mahendra.
aamev likes this.
mahendra is offline   Reply With Quote
Old   November 21, 2008, 04:50
Default Hello People ! No replies f
Mahendra
Hello People !
No replies for the above post???
Regards,
Mahendra
Old   November 28, 2008, 01:21
Default hi, At least a comment on t
Mahendra
hi,
At least a comment on the above topic?????
Mahendra.
Old   December 3, 2008, 05:53
Default Hi Mahendra, There is a uti
Kati Laakkonen
kati is on a distinguished road
Hi Mahendra,
There is a utility wallHeatFlux, but like the name says, it's only for walls, not for inlets and outlets. There was a problem with such calculation on inlet/outlet boundaries, but I don't remember exactly what - maybe something with the face normal direction? I suppose you can add an estimation to the utility using flux and enthalpy on boundaries, and try to interpret the result.
Regards,
Kati
kati is offline   Reply With Quote
Old   December 3, 2008, 06:13
Default I forgot to mention the utilit
Kati Laakkonen
I forgot to mention the utility is written for hCombustionThermo. Replace hCombustionThermo with hThermo, if you are not using combustion models. You'll also need to add [patchi] to the if statement, i.e.
if (typeid(mesh.boundary()) == typeid(wallFvPatch))
becomes
if (typeid(mesh.boundary()[patchi]) == typeid(wallFvPatch))
Then recompile.
Regards,
Kati
Old   December 4, 2008, 02:05
Default Dear Kati, I really appreci
Mahendra
Dear Kati,
I really appreciate for responding, I will try your suggestion and let you know about it.
Thanks,
Mahendra.
Old   April 25, 2009, 09:57
Nugroho Adi
mahaputra is on a distinguished road
becomes
Then recompile.
Regards,
Kati
Dear Katti
i modified some scripts in the wallHeatFlux post processing utilities
without change the hCombustionThermo , it successed to compile
but, when i changed the files, followed your instruction, i got these following errors:
simulation15@user-laptop:~/OpenFOAM/OpenFOAM-1.5-dev/applications/utilities/postProcessing/wall/wallHeatFlux$ wclean
simulation15@user-laptop:~/OpenFOAM/OpenFOAM-1.5-dev/applications/utilities/postProcessing/wall/wallHeatFlux$ wmake
Making dependency list for source file wallHeatFlux.C
SOURCE=wallHeatFlux.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/simulation15/OpenFOAM/OpenFOAM-1.5-dev/src/finiteVolume/lnInclude -I/home/simulation15/OpenFOAM/OpenFOAM-1.5-dev/src/turbulenceModels/RAS -I/home/simulation15/OpenFOAM/OpenFOAM-1.5-dev/src/thermophysicalModels/specie/lnInclude -I/home/simulation15/OpenFOAM/OpenFOAM-1.5-dev/src/thermophysicalModels/combustion/lnInclude -I/home/simulation15/OpenFOAM/OpenFOAM-1.5-dev/src/thermophysicalModels/basic/lnInclude -IlnInclude -I. -I/home/simulation15/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/simulation15/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/wallHeatFlux.o
In file included from wallHeatFlux.C:68:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:1: error: type/value mismatch at argument 1 in template parameter list for ‘template<class T> class Foam::autoPtr’
createFields.H:1: error: expected a type, got ‘hThermo’
createFields.H:2: error: invalid type in declaration before ‘(’ token
createFields.H:3: error: ‘template<class MixtureType> class Foam::hThermo’ used without template parameters
createFields.H:6: error: base operand of ‘->’ is not a pointer
createFields.H:16: error: base operand of ‘->’ is not a pointer
createFields.H:131: error: ‘thermo’ cannot be used as a function
createFields.H:6: warning: unused variable ‘h’
make: *** [Make/linuxGccDPOpt/wallHeatFlux.o] Error 1
i change:
header of wallHeatFlux.C :
#include "fvCFD.H"
//#include "hCombustionThermo.H"
#include "hThermo.H"
#include "compressible/RASModel/RASModel.H"
#include "wallFvPatch.H"
and
createField.H becomes :
autoPtr<hThermo> thermo // autoPtr<hCombustionThermo> thermo
hThermo::New(mesh) // hCombustionThermo::New(mesh)
const volScalarField& h = thermo->h();
is there something missed?
please give me help
thanks
aamev likes this.
mahaputra is offline   Reply With Quote
Old   May 4, 2009, 05:47
Assistant Moderator
Bernhard Gschaider
Originally Posted by mahaputra View Post
Dear Katti
The problem is that hThermo is a template. Instead of hThermo change to basicThermo (the superclass of hThermo and hCombustionThermo) and it compiles. Should work, too, but I havn't tested that
Bernhard
Old   July 28, 2009, 04:56
Linh.Hoang is on a distinguished road
Dear Foamers,
I changed the Utility wallHeatFlux as mentioned. I´ve got no errors while compiling, but when i tried to use it on my case (impinging jet on a flat plate)
i´ve got following errors:
Selecting RAS turbulence model kEpsilon
#0 Foam::error::printStack(Foam::Ostream&) in "/user/hi141/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/user/hi141/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 Foam::compressible::RASModels::kEpsilon::kEpsilon( Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo&) in "/user/hi141/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#4 Foam::compressible::RASModel::adddictionaryConstru ctorToTable<Foam::compressible::RASModels::kEpsilo n>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo&) in "/user/hi141/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#5 Foam::compressible::RASModel::New(Foam::GeometricF ield<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo&) in "/user/hi141/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libcompressibleRASModels.so"
#6 main in "/user/hi141/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/wallHeatFlux2"
#7 __libc_start_main in "/lib/libc.so.6"
#8 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/user/hi141/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/wallHeatFlux2"
Floating point exception (core dumped)
Any suggestions whats wrong?
Linh
Linh.Hoang is offline   Reply With Quote
Old   July 28, 2009, 09:38
Assistant Moderator
Bernhard Gschaider
Originally Posted by Linh.Hoang View Post
Dear Foamers,
#0 Foam::error:rintStack(Foam::Ostream&) in "/user/hi141/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
Linh
The problem happens while the k-epsilon-model is initialized. Did that case ever successfully run? I doubt it, because everything points to the world-famous "k or epsilon are defined as 0 somewhere (internal field or boundary) and therefor we get a division by 0"-problem that is discussed elsewhere on the forum
Bernhard
Old   July 28, 2009, 09:59
Hello Bernhard,
thanks for your thoughts.
my case run sucessfully and even the velocity and Temperature looks fine for me. For k and epsilon i´ve got zeroGradient at walls and outlet and for inlet and internalfield a fixed Value. (k=0.19 and epsilon= 8).
That seems right for me. Any other suggestions why it doesen't work?
Linh
Old   July 28, 2009, 14:03
Assistant Moderator
Bernhard Gschaider
Hello Bernhard,
Linh
No idea. I say what I always say in that situation: "Run your stuff in the Debug-Version. This will give the line-number where it happens" Everything else is guesswork
Old   February 8, 2012, 06:28
johannes k.
schalinski is on a distinguished road
ik now, its quite an old thread..but one question:
i've got quite a similar problem, my machine says:
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.019224, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0170779, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0153836, No Iterations 1
DILUPBiCG: Solving for h, Initial residual = 0.514064, Final residual = 0.00679162, No Iterations 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 9.81448e-05, No Iterations 558
DICPCG: Solving for p, Initial residual = 0.205988, Final residual = 2.04897e-05, No Iterations 142
DICPCG: Solving for p, Initial residual = 0.0258002, Final residual = 2.46229e-06, No Iterations 454
time step continuity errors : sum local = 0.0268867, global = 6.52206e-05, cumulative = 6.52206e-05
rho max/min : 2 2
DILUPBiCG: Solving for omega, Initial residual = 0.999982, Final residual = 0.0668744, No Iterations 2
bounding omega, min: -1369.7 max: 7.94188e+07 average: 420.946
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.0661276, No Iterations 1
ExecutionTime = 743.84 s ClockTime = 751 s
Time = 2
DILUPBiCG: Solving for Ux, Initial residual = 0.147725, Final residual = 0.0122156, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 0.285303, Final residual = 0.00314927, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 0.361735, Final residual = 0.0197595, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.426434, Final residual = 0.0386005, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.999999, Final residual = 23.1811, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.833482, Final residual = 0.00709432, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.847285, Final residual = 0.0412215, No Iterations 1001
time step continuity errors : sum local = 9009.91, global = -26.1803, cumulative = -26.1803
rho max/min : 2 2
DILUPBiCG: Solving for omega, Initial residual = 0.99807, Final residual = 0.0959366, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 0.724922, Final residual = 0.0287185, No Iterations 1
ExecutionTime = 2472.43 s ClockTime = 2487 s
Time = 3
DILUPBiCG: Solving for Ux, Initial residual = 0.300673, Final residual = 0.0115287, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.449886, Final residual = 0.0417425, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.446248, Final residual = 0.0391038, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.397656, Final residual = 0.0197622, No Iterations 19
DICPCG: Solving for p, Initial residual = 0.949759, Final residual = 0.000545524, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.0981401, Final residual = 9.80824e-06, No Iterations 908
DICPCG: Solving for p, Initial residual = 0.121937, Final residual = 1.19824e-05, No Iterations 748
time step continuity errors : sum local = 5.62326, global = -0.28192, cumulative = -26.4622
rho max/min : 2 0.001
DILUPBiCG: Solving for omega, Initial residual = 0.494972, Final residual = 0.038501, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 0.551354, Final residual = 0.0213688, No Iterations 1
ExecutionTime = 4078.91 s ClockTime = 4101 s
Time = 4
DILUPBiCG: Solving for Ux, Initial residual = 0.676072, Final residual = 0.0333149, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.624142, Final residual = 0.0401927, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.605495, Final residual = 0.0382899, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.0459921, No Iterations 2
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/libc.so.6"
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::calculate() in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::correct() in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/rhoSimpleFoam"
#6 __libc_start_main in "/lib/libc.so.6"
but i've checked all my variables...none is zero!
You're talking about the debug mode, can anyone please help me and tell me what i have to do to run the solver (rhosimplefoam) in debug mode??
Would be great!!
schalinski is offline   Reply With Quote
Old   February 8, 2012, 09:02
Olivier
olivierG is on a distinguished road
hello,
I you gess your rho min was too small, or even negative. (see you log).
Try relax for T, and check if all is correct with your thermo setting.
regards,
olivier
olivierG is offline   Reply With Quote
Old   February 8, 2012, 10:58
johannes k.
Originally Posted by olivierG View Post
hello,
regards,
olivier
Ok, thanks for helping, but......what does all that mean?my rho min is 0.001..is that too small?? and what about relax for T, where do i have to do these settings. and the thermo settings? where do i find them? what do i have to write there??
But again...thanks much for help
Old   February 8, 2012, 11:19
Olivier
in system/fvSolution, check if you have set rhoMin and rhoMax.
And if the solver still crash, check (always in fvSolution) the relaxationFactors for h and rho: try a lower value at first, and when all goes well, you can reset to the initial value on the fly.
regards,
olivier
Problem of heat balance in Coal Boiler simulation DG FLUENT 9 December 25, 2008 21:57
Heat balance problem heam FLUENT 0 February 20, 2008 13:52
Heat balance in radiation simulation Rivera Phoenics 1 January 6, 2006 18:51
Is my mass flow considered as balance? MT Main CFD Forum 2 October 25, 2005 14:44
Heat and mass balance problem Laurent FLUENT 2 October 15, 2002 11:52
