post-processing utility R: no files are saved |
July 31, 2024, 07:10 |
Zeno Brighenti
Rep Power: 3 |
Hi there!
Apologize for this silly question. A lot of people had the same issue in the past but all the topics i've read did not bring me to any valid solution. I have to estimate the Reynolds stress tensor from a KomegaSST time variant compressible simulation (rhoPimpleFoam) whose results are saved on my laptot. I'm currently using OpenFOAMv10. Following this guide: https://www.openfoam.com/documentati...nceFields.html i modified my /system/controlDict as follows: Code:
turbulenceFields1 { // Mandatory entries (unmodifiable) type turbulenceFields; libs (fieldFunctionObjects); // Mandatory entries (runtime modifiable) // Either field or fields entries fields (R devRhoReff); field R; } Code:
rhoPimpleFoam -postProcess -func turbulenceFields Code:
Time = 0.005s Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } Creating thermophysical transport model Selecting thermophysical transport type RAS Selecting default RAS thermophysical transport model unityLewisEddyDiffusivity Creating field dpdt Creating field kinetic energy K No MRF models present No fvModels present No fvConstraints present turbulenceFields turbulenceFields: no fields requested to be stored Last edited by Il_Briga; August 14, 2024 at 04:41. |
July 31, 2024, 08:30 |
#2 | |
Yann
Rep Power: 27 |
You have several things mixed up. Lets try to clarify. When you are using this command: Code:
rhoPimpleFoam -postProcess -func turbulenceFields When using this predefined function, you need to pass the list of fields you want to process as an argument. This is why you are getting this message in your log: Quote:
rhoPimpleFoam -postProcess -func "turbulenceFields(R devRhoReff)" Code:
rhoPimpleFoam -postProcess I hope this helps, Yann |
September 22, 2024, 06:24 |
Zeno Brighenti
Rep Power: 3 |
Hi Yann,
Apologize for my late reply. I have been very busy lately. I hope i'm not doing necroposting. Thank you so much for your reply. Yeap, you gave me a precious hand to clarify several concepts. One last question then i close the topic: in your opinion is better to recover the R stress tensor starting from a K-epsilon or a K-omega simulation (same mesh, same BC, etc..)? Should it be the same? Thank you very much. |
post processing working error | albus04*-* | FLUENT | 1 | February 28, 2022 10:00 |
retaining files and getting contours in post processing transient simulation | Mounarah | Main CFD Forum | 5 | October 7, 2021 12:18 |
Post Processing Results: Ansys Workbench 18.2 - Fluent - CFD Post - Porous Body | onlycfd | FLUENT | 0 | April 28, 2021 23:41 |
Ansys Post processing | ano999 | ANSYS | 1 | May 27, 2011 16:24 |
NO model vs post processing in coal combustion,CFX | sakalido | CFX | 1 | April 15, 2011 14:07 |
