Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
postProcess: How to compute -grad?
Like Tree2Likes
  • 1 Post By Yann
  • 1 Post By reverseila
Old   July 26, 2024, 12:02
Default postProcess: How to compute -grad?
Ali B.
reverseila is on a distinguished road
Dear all,
With postProcess -func "grad(V)" -latestTime I can compute the gradient of V (electric potential), for the latest written iteration (for a steady state simulation). However, how can I compute the multiply gradient of a field by -1?
The problem is I cannot use the following:
--> FOAM FATAL IO ERROR: (openfoam-2312)
Wrong token type - expected word, found on line 0: label -1
I'm trying to transfer the calculation of electric field from the steady state solver to one time calculation of a gradient with postProcess after simulation is done.
I would also like to give the resulting field a name. For example, when I compute grad(magSqr(V))it produces a field with the name: grad(magSqr(V)). I want to give it the name EdotGradE.
$FOAM_API: 2312
reverseila is offline   Reply With Quote
Old   July 29, 2024, 09:58
Ali B.
To restate my problem in a simpler way, how to multiply a field by a scalar?
I think OpenFOAM foundation has a `scale` function object but it seems that OpenFOAM-ESI does not have any way to do that, as far I know.
Old   July 30, 2024, 10:24
Yann
Yann will become famous soon enoughYann will become famous soon enough
In the OpenCFD branch, have a look at the reference and exprFields function objects.
Regards,
Yann
reverseila likes this.
Yann is offline   Reply With Quote
Old   August 2, 2024, 17:46
Ali B.
Thank you Yann!
I think that will do it. I will use it in the future (I wrote a new solver just for that in last few days).
Yann likes this.
postprocess
StarCCMS+ on AWS Parallel Cluster not distributing workload across multiple nodes dwagoner STAR-CCM+ 3 May 25, 2021 03:39
Drag Coefficient Gradient: 0 in 2d adjoint optimization tomp1993 SU2 Shape Design 11 August 1, 2019 16:14
postProcess functionality in openFOAM 4 bullmut OpenFOAM Post-Processing 23 July 21, 2017 10:11
Compute Cluster with diskless compute nodes Pauli Hardware 0 October 6, 2015 17:48
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
