Unable to find turbulence model in the database |
mitb
Rep Power: 0 ![]() |
Hi I am using denseParticleFoam solver to simulate 2 phase flows and I want to calculate th wallshearStress, using the denseParticleFoam -postProcess -func wallShearStress but whenever I start I get this error
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application denseParticleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 2.0; deltaT 2.5e-5; writeControl adjustableRunTime; writeInterval 0.1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 1.00; functions { wallShearStress { type wallShearStress; libs ("libfieldFunctionObjects.so"); executeControl timeStep; writeControl outputTime; } /* fieldAverage { type fieldAverage; writeControl outputTime; timeStart 0; fields ( wallShearStress { mean on; prime2Mean off; base time; } ); libs ("libfieldFunctionObjects.so"); }*/ } and the error i get is Code:
Starting time loop wallShearStress wallShearStress: processing all wall patches --> FOAM FATAL ERROR: Unable to find turbulence model in the database From function virtual bool Foam::functionObjects::wallShearStress::execute() in file wallShearStress/wallShearStress.C at line 210. FOAM exiting Thanks |
mitb
M
Rep Power: 12 ![]() |
[GUIDE] Switching turbulence model to SpalartAllmaras | gabrielfelix | OpenFOAM Running, Solving & CFD | 1 | March 24, 2022 20:19 |
How to make a code parallel? | Bruno Machado | Fluent UDF and Scheme Programming | 15 | May 27, 2016 09:18 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 00:52 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
