Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
ParaFoam problem with mesa drivers - paraviewopenfoam510
Like Tree2Likes
  • 1 Post By kakila
  • 1 Post By edaymo
Old   February 19, 2024, 11:13
Default ParaFoam problem with mesa drivers - paraviewopenfoam510
Eric Daymo
edaymo is on a distinguished road
Anyone else having problems with mesa drivers suddenly crashing paraview installed with paraviewopenfoam510 ? This is happening for me on multiple machines.
I don't know the root cause, but in case this helps you, if I overwrite the mesa directory in /opt/paraviewopenfoam510 (Ubuntu 22.04) with the mesa directory from paraviewopenfoam56 (installed with openfoam 9) I can run paraview in OpenFOAM11 again.
Hopefully there is an official fix, or maybe someone has a more elegant fix, but this quick fix kept me going this morning...
Cheers,
Eric
edaymo is offline   Reply With Quote
Old   February 22, 2024, 10:34
Juan Pablo Carbajal
kakila is on a distinguished road
Same here, I posted the issue here:
https://askubuntu.com/questions/1504...latest-updates
The latest update introduces the issue, likely a problem with the symbolic links.
edaymo likes this.
kakila is offline   Reply With Quote
Old   March 25, 2024, 06:54
Juan Pablo Carbajal
As written in the answers to that post:
A workaround this issue is to deactivate GL on paraview. The following way of invoking paraFoam (or paraview) should do the trick:
ParaView_GL="" paraFoam
However this stopped working. When there will be a patch for paraFoam using the latest paraview? 5.12 doesn't have the issue
Where is the place to post that question to the developers of OpenFOAM?
Old   March 25, 2024, 07:51
Eric Daymo
I think you already posted the bug report to the right place: https://bugs.openfoam.org/view.php?id=4056 . As of right now there is no reply to your bug report.
The workaround I posted above is still working for me (copying the mesa directory from paraviewopenfoam56 to paraviewopenfaom510). I have not yet tried compiling paraView/paraFoam on my own to fix this problem, but that would probably be my next step if the workaround I wrote about here ever fails.
kakila likes this.
openfoam, paraview, paraviewopenfoam510
[OpenFOAM] Visualization problem on ParaFoam Rider ParaView 10 June 27, 2016 11:19
[OpenFOAM] Problem with spaces in paraFoam execution chrisb2244 ParaView 1 November 9, 2013 16:06
[OpenFOAM] Post processing problem in Xfce desktop environment using paraFoam tariq ParaView 4 July 8, 2013 11:09
[blockMesh] Problem with arc edge, arc doesen't appear in ParaFoam A.A. OpenFOAM Meshing & Mesh Conversion 2 September 4, 2012 08:01
Graphics problem in ParaFoam Tarak OpenFOAM 0 October 28, 2010 20:10
