Guilherme
Rep Power: 10 ![]() |
I was able to calculate the vorticity of my model. I can view it in ParaView. However, when I try to create an iso-surface, it does not appear for selection. Does anyone know the reason? Thanks. *OpenFOAM 9 |
Shravan
Rep Power: 9 ![]() |
The reason you don't see your vorticity for selection is because only scalars are available for creating the iso-surface. Quick solution: Use the "Calculator" and save the individual components of the vorticity as scalars (e.g. Vorticity_X, Vorticity_Y and Vorticity_Z). Now use the "Contour" filter and then you should have your vorticity available. Thanks |
bug, openfoam9, paraview, postprocess |
[snappyHexMesh] Surface layers do not merge | mc6421 | OpenFOAM Meshing & Mesh Conversion | 3 | December 5, 2023 03:00 |
[OpenFOAM] Is This A bug for Paraview 4.1.0 64bit | yym2014 | ParaView | 11 | May 5, 2020 21:35 |
[snappyHexMesh] Surface triangulation using snappyHexMesh | shaileshbg | OpenFOAM Meshing & Mesh Conversion | 4 | October 17, 2019 04:42 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[OpenFOAM] A bug in paraview ? | jbf | ParaView | 0 | September 8, 2009 06:14 |
