heat flux coefficient with wallHeatTransfCoeff |
December 22, 2022, 04:48 |
Joao Coelho
Rep Power: 5 |
I am trying to validate the wallHeatTransfCoeff utility in OpenFOAM v9, using rhoPimpleFoam for a forced convection. My case is a cylindrical pipe with 20mm diameter, 250mm long (to achive L/d > 10). The fluid used is defined by constant rho, transport properties and cp (it is supposed to simulate Liquid oxygen @74 bar and with T=102K). Here goes the thermophysical properties given as input; Code:
thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleInternalEnergy; } mixture { specie { molWeight 32; } thermodynamics { Cp 1686; Cv 877; Hf 0; } transport { mu 160e-06; Pr 1.91; } equationOfState { rho 1103; } } The boundary conditions are the following: Code:
U
Regarding the utility, I added the following to the controlDict Code:
h_coef { type wallHeatTransferCoeff; libs ("libfieldFunctionObjects.so"); model kappaEff; //... patches (".*Wall"); rho 1103; Cp 1686; Pr 1.91; Prt 0.85; executeControl timeStep; writeControl writeTime; } kappaEff is computed as follow htc = rho * Cp ( nu/Pr + nu_t/Pr_t)
Being so, I have achieved some results that are out of the order of magnitude of the Dittus-Boelter equation (valid for L/D>10, for Re>10000, which is the case). I also tried an approach using the Calculator in paraview, where I use the result output wallHeatFlux (also addded in the controlDict but out of the scope for this post) and divide by the difference of the wall (which is given as input in the boundary condition) and bulk temperatures (which can be approximated to the inlet temperature): h=q / (T_wall - T_bulk)
Why does the option using the simulation wall heat flux differ so much from the automatic computation of the heat transfer coefficient? Does anyone understand what might be the problem? Has anyone successfully used (and possibly validate) this wallHeatTransfCoeff utility? Last edited by jcoelho5; December 22, 2022 at 05:06. Reason: corrected typo |
February 16, 2023, 05:59 |
Nico
Rep Power: 6 |
Hey, i have a pretty similar problem right now, if not the same. So far i also found that the wallHeatTransferCoefficient is way too inaccurate. I unfortunately have no idea to resolve this. I would stick to manually compute the heat transfer coefficient, since your results at least are of similar magnitude of the results given by the dittus boelter equation.
However may i ask you if you ever had problems with the wall temperatures? In my simulation the temperature difference given by t_wall-t_bulk is way to low to even come close to the temperature difference i can calculate backwards from the dittus boelter equation. However and the temperature difference between in and outlet is correct with regards to the heat given by Q = mdot*cp*(t_outlet - t_inlet). In conclusion the convection modelling in OpenFoam is quite strange. And the wallHeatTransferCoeffcient also. Did you ever resolve your issue? |
February 16, 2023, 07:21 |
Joao Coelho
Rep Power: 5 |
No, unfortunately I haven't solve this problem.
Regarding the wall temperature, I forced it to be the 200K specifically for it to have a "significant" temperature difference with the bulk. It was just a (failed) validation case. |
February 21, 2023, 04:14 |
Nico
Rep Power: 6 |
Hi, just as a follow up. I solved the problem by switching to k-omega SST for my simulation my results now match dittus boelter, that i used as a reference. The HTC calculation of openFoam still proved to be wrong, however i was able to achieve 1% difference to dittus boelter with just better wall treatment from a k-omega model.
February 21, 2023, 06:09 |
#5 | |
Joao Coelho
Rep Power: 5 |
February 21, 2023, 06:13 |
Nico
Rep Power: 6 |
Yes, it was done manually. The functionObject still prints out a plain wrong value. Either way i have a better gut feeling regarding the manual computation, since I at least know what is happening there.
Have you made any progress? |
February 21, 2023, 06:25 |
Joao Coelho
Rep Power: 5 |
Ok, good enough!
No, no progress. Not only I had to focus on other things, but also I did not know what else to do... Thanks anyways for you input. Still helpful |
February 21, 2023, 06:38 |
Nico
Rep Power: 6 |
By the way: I also added an entrance area to the pipe based on correlation that uses the reynolds number (l_entrance = 1.359*Diameter*Re^0.25) and after that a portion that matches L/D = 10. Your case sounds pretty much like mine and the temperature evolution along the pipe wall differs quite much between the entrance and the developed region.
Hope you can solve your problem soon! |
What are the best settings for a channel flow simulation? | Ashkan Kashani | CFX | 3 | October 13, 2022 21:36 |
Heat Transfer Coefficient for Heat Flux = 0 W/m^2 | CellZone | ANSYS | 0 | June 14, 2022 07:37 |
Simulating constant heat flux value at solid-solid boundary | Y27 | STAR-CCM+ | 6 | September 8, 2020 09:56 |
Heat Flux at Internal walls or Fluid Solid Interface | Mahi | CFX | 3 | October 1, 2012 02:18 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
