Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Changing magUInf does not affect lift calculation
Like Tree1Likes
  • 1 Post By Counterdoc
Old   October 8, 2022, 05:27
Question Changing magUInf does not affect lift calculation
Marius
Counterdoc is on a distinguished road
I am currently simulating a s1223 airfoil and want to test it at different speeds. My first test was with magUInf = 22.22 and this was the result for the lift: -112,908 N
So the second try was to change the magUInf in the forceCoeffs file to 36.11. After running everything again I still get the same lift of -112,908 N. Is there something that I am missing?
I run:
blockMesh
surfaceFeatureExtract
decomposePar
mpirun -np 8 snappyHexMesh -overwrite -parallel
reconstructParMesh -constant
rm -rf processor*
rm -rf 0
mv 0.orig 0
decomposePar
mpirun -np 8 simpleFoam -parallel
reconstructPar -latestTime
My calculation is done in Paraview using GenerateSurfaceNormals and calculate the force with
(p*Normals-wallShearStress)*1.225
and using IntegrateVariables of course.
My forceCoeffs file looks like that:
|  \\    /   O peration     | Version:  v2206                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
forceCoeffs1
    type            forceCoeffs;
    libs            (forces);
    writeControl    timeStep;
    timeInterval    1;
    log             yes;
    patches         (clio3rs);
    rho             rhoInf;      // Indicates incompressible
    rhoInf          1;           // Required when rho = rhoInf
    liftDir         (0 0 1);
    dragDir         (1 0 0);
    CofR            (3.5 0 0);  // Axle midpoint on ground
    pitchAxis       (0 1 0);
    magUInf         22.22;        // 80 km/h
    lRef            0.2;        // chord length
    Aref            0.28;        // Aref=(airfoil chord length)*(length in the spanwise direction of your 2D domain)
binField1
    type                    binField;
    libs                    (fieldFunctionObjects);
    binModel                singleDirectionUniformBin;
    fields                  (forceCoeff);
    patches                 (clio3rs);
    decomposePatchValues    true;
    CofR                    ${..forceCoeffs1.CofR};
    binData
        nBin        20;          // output data into 20 bins
        direction   (1 0 0);     // bin direction
        cumulative  yes;
Any ideas?
Thank you!
Cheers,
Marius
Counterdoc is offline   Reply With Quote
Old   October 10, 2022, 06:27
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hi Marius,
forceCoeffs is used to compute aerodynamic coefficients (drag coefficient Cd, lift coefficient Cl, etc...) in a file in the postProcessing directory. It does not have any effect on the simulation, it is only a post-processing function. You can also use the forces function object to report forces right from OpenFOAM instead of computing it in ParaView.
If you want to change the flow velocity in the simulation, you need to update the velocity boundary condition in 0/U file.
Cheers,
Yann
Yann is offline   Reply With Quote
Old   October 10, 2022, 06:29
Marius
Hi Yann,
thanks a lot for your answer. I just updated the U file and now everything is fine.
Cheers,
Marius
Yann likes this.
airfoil, forcecoeffs, lift and drag, maguinf
Lift and drag coefficient calculation Lowt3ch FLUENT 1 March 5, 2018 12:04
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 08:18
Wrong Drag and Lift Coefficient when changing AoA inspiron FLUENT 1 November 27, 2013 14:00
Changing inflow velocity direction deteriorates lift and drag ziggo FLUENT 3 July 24, 2013 09:39
Thin foil analsis (sail) - Lift Coeff Problem Kelvin CFX 3 December 22, 2008 17:22
