reconstructPar | Getting time folder names as integers instead of times |
July 15, 2022, 05:33 |
Ahsan
Rep Power: 6 |
Hello Everyone,
I hope everyone is having a good day. I wanted to ask if there is any way through which we can generate the time folders as integers, without manually renaming the time folders. I ask this because I have two codes running in integration. Where OpenFOAM produces time steps as 0.05, 0.1, 0.15, 0.2, 0.25, ... The other code is producing the corresponding steps as 1, 2, 3, 4, 5, ... So the problem is, when I load the .foam file in ParaView and the VTKs from the other code, they do not sync correctly due to the difference in time names. Is there any way I can generate the folder names as integers, or to force ParaView to correspond: OpenFOAM --> External Code 0.05 --> 1 0.1 --> 2 0.15 --> 3 0.2 --> 4 and so on... |
July 18, 2022, 05:47 |
I think the ParaView filter Temporal Shift Scale may be what you need. Best Regards, Tom |
July 19, 2022, 04:12 |
Thanks a bunch!!!
Ahsan
Rep Power: 6 |
openfoam, paraview, postprocess, reconstuctpar, time steps |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 7, 2024 23:17 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
