Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Plotting a result while a simulation is running
Like Tree1Likes
  • 1 Post By tomf
Old   May 26, 2022, 07:41
Default Plotting a result while a simulation is running
mohammad
mohammad is on a distinguished road
Hi everyone,
I know that PyFoamPlotRunner shows the residuals while a file is running.
However, I'm trying to plot the AreaAverage of pressure at the inlet of a domain while the simulating is running.
I have calculated the surface average within the "controlDict" by:
inletAvePressure
type surfaceFieldValue;
libs (fieldFunctionObjects);
enabled yes;
writeControl timeStep;
writeInterval 1;
log yes;
writeFields no;
regionType patch;
name inlet;
operation areaAverage;
weightField phi;
fields ( p );
Could anybody let me know how to plot this value during the run?
Best,
mohammad is offline   Reply With Quote
Old   May 30, 2022, 09:48
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Mohammad,
If you run on any modern version of OpenFOAM this will probably work from the command line:
foamMonitor postProcessing/inletAvePressure/0/surfaceFieldValue.dat
Please note that the 0 assumes you started the monitor and the simulation from time=0.
foamMonitor -h
shows the usage.
Running in the background can be useful.
Hope this helps,
Best Regards,
Tom
mohammad likes this.
tomf is offline   Reply With Quote
Old   May 30, 2022, 10:42
mohammad
Originally Posted by tomf View Post
Hi Mohammad,
foamMonitor -h
shows the usage.
Hope this helps,
Best Regards,
Tom
Thanks Tom for your great help.
For future readers:
I was also able to use the "gnuplot" in a new terminal to read the results from the "log" file.
Best
Old   May 31, 2022, 09:13
Vivio is on a distinguished road
Hi mohammad,
Another thing you can do, if you're using PyFoam, is to create a file called "customRegexp" in the run directory, containing a regular expression to parse the log for the quantity you want to plot. PyFoamPlotRunner will pick up the regular expression automatically and plot your result live alongside the residuals.
Best regards,
Vivio
Vivio is offline   Reply With Quote
plotting result, simultaneous, while running
[Workbench] Current result file may not contain requested result data zhizhuo ANSYS Meshing & Geometry 0 December 13, 2017 05:18
Can not get correct result in inducer simulation by pimpleDyMFoam zxzx OpenFOAM Running, Solving & CFD 1 February 19, 2017 03:43
Different Result between FLUENT and CFD Post free.man FLUENT 0 February 10, 2017 00:20
How to display the whole result of a periodic model via one period result? dixylo FLUENT 2 February 23, 2012 05:11
Read Result Files or User Defined Result Aquilaris ANSYS 0 February 9, 2011 06:25
