April 7, 2022, 02:00 |
Not obtaining temperature contours
Amal Chummar
Rep Power: 5 |
Hello Guys,
I am quite new to openfoam and was trying a turbulent heat transfer case. I edited the blockmesh file for the tutorials>heatTransfer>buoyantPimpleFoam>hotRoomBo ussinesq. Introduced a cubical block with a hot wall (673K) on the left side and a cold wall (193K) on the right side wall. when i ran the case through openFoam for 10000 iterations it is not writing a folder at 100 interval mark which i gace in the controlDict and also no heat transfer is seen between the hot and cold wall. WHAT AM I DOING WRONG ..... Pls Help |
April 7, 2022, 03:18 |
Yann
Rep Power: 27 |
Hi Amal,
Does the solver run properly? Can you post the log files here please? Thanks, Yann |
April 7, 2022, 05:54 |
log files
Amal Chummar
Rep Power: 5 |
these are the log files...... I blocked the log.setFields file from being written.
the other two log files are here log.blockMesh /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-1ff648926f77 Exec : blockMesh Date : Apr 07 2022 Time : 11:13:08 Host : "chummar-GL553VE" PID : 4186 I/O : uncollated Case : /home/chummar/OpenFOAM/chummar-7/run/realone/turbtrial nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/chummar/OpenFOAM/chummar-7/run/realone/turbtrial/system/blockMeshDict" Creating block edges No non-planar block faces defined Creating topology blocks Creating topology patches Creating block mesh topology Check topology Basic statistics Number of internal faces : 0 Number of boundary faces : 6 Number of defined boundary faces : 6 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating polyMesh from blockMesh Creating patches Creating cells Creating points with scale 1 Block 0 cell size : i : 0.5 j : 1 k : 0.5 Writing polyMesh ---------------- Mesh Information ---------------- boundingBox: (0 0 0) (10 10 10) nPoints: 4851 nCells: 4000 nFaces: 12800 nInternalFaces: 11200 ---------------- Patches ---------------- patch 0 (start: 11200 size: 400) name: floor patch 1 (start: 11600 size: 400) name: ceiling patch 2 (start: 12000 size: 200) name: hotwall patch 3 (start: 12200 size: 200) name: coldwall patch 4 (start: 12400 size: 400) name: fixedWalls End log.bouyantPimpleFoam /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-1ff648926f77 Exec : buoyantPimpleFoam Date : Apr 07 2022 Time : 11:13:09 Host : "chummar-GL553VE" PID : 4187 I/O : uncollated Case : /home/chummar/OpenFOAM/chummar-7/run/realone/turbtrial nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 --> FOAM FATAL IO ERROR: keyword PIMPLE is undefined in dictionary "/home/chummar/OpenFOAM/chummar-7/run/realone/turbtrial/system/fvSolution" file: /home/chummar/OpenFOAM/chummar-7/run/realone/turbtrial/system/fvSolution from line 22 to line 65. From function const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&) const in file db/dictionary/dictionary.C at line 708. FOAM exiting THANKS |
April 7, 2022, 06:19 |
Yann
Rep Power: 27 |
Thank you Amal,
Have a look at your buoyantPimpleFoam log file. The solver did not run because it misses the PIMPLE dictionary in the fvSolution file. You have to fix this error. Yann |
April 7, 2022, 06:32 |
fvSolution and fvSchemes
Amal Chummar
Rep Power: 5 |
in the controlDict bouyantPimpleFoam is called but
fvSolution /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p_rgh { solver PCG; preconditioner DIC; tolerance 1e-08; relTol 0.01; } "(U|e|k|epsilon)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-05; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { p_rgh 1e-2; U 1e-4; e 1e-2; // possibly check turbulence fields "(k|epsilon|omega)" 1e-3; } } relaxationFactors { fields { p_rgh 0.7; } equations { U 0.3; e 0.5; "(k|epsilon|R)" 0.7; } } // ************************************************** *********************** // fvSchemes /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div(phi,e) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(phi,Ekp) bounded Gauss linear; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } // ************************************************** *********************** // Is this cause of mentioning simple in fvSolution instead of pimple |
April 7, 2022, 07:52 |
Yann
Rep Power: 27 |
Yes, you are probably using a fvSolution file from a steady case (like buoyantSimpleFoam).
If your case is based on the hotRoomBoussinesq tutorial (tutorials>heatTransfer>buoyantPimpleFoam>hotRoomB oussinesq), try to replace your fvSolution file by the one from the tutorial. Yann |
heat transfer, k omega, turbulent |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
Shadow Wall and temperature | norger | FLUENT | 10 | September 28, 2019 11:43 |
Obtaining negative temperature sonicFoam | chelucupar | OpenFOAM Running, Solving & CFD | 3 | July 17, 2019 15:04 |
outlet temperature | jigneshrohit99 | FLUENT | 1 | March 25, 2016 13:26 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 06:08 |
