Vikash Daga
Rep Power: 0 ![]() |
I was trying to convert Decimal to Binary, there is no error in the code but while executing I am getting blank, not showing anything. Could someone help me figure out where is the mistake
def decimalToBinary(ip_val): if ip_val= 1: # recursive function call decimalToBinary(ip_val // 2) # printing remainder from each function call print(ip_val % 2, end = '') # Driver Code if __name__ == '__main__': # decimal value ip_val = 24 # Calling special function decimalToBinary(ip_val) |
Rep Power: 14 ![]() |
As a start, line 2:
if ip_val= 1: Code:
if ip_val >= 1: |
python |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
