Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to get the wall heat flux using bouyantBossinesqSimpleFoam on OpenFOAM v2006
Like Tree1Likes
  • 1 Post By Yann
Old   July 19, 2021, 22:15
Unhappy How to get the wall heat flux using bouyantBossinesqSimpleFoam on OpenFOAM v2006
Óscar
oscar0522 is on a distinguished road
I'm doing a simulation using bouyantBossinesqSimpleFoam and I'm triying to get the wall heat flux but it shows me an error and this one says "Unable to find compressible turbulence model" so the question is how do I get the wall heat flux on a incompressible simulation using OpenFOAM v2006.
Thank you.
oscar0522 is offline   Reply With Quote
Old   July 20, 2021, 04:09
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hi Oscar,
I have another question for you: what is the command giving you the error you have posted?
Yann
Yann is offline   Reply With Quote
Old   July 20, 2021, 09:46
Óscar
Originally Posted by Yann View Post
Hi Oscar,
Yann
I'm trying to do the postprocess. The command is "buoyantBoussinesqSimpleFoam -postProcess -func wallHeatFlux".
This is the code that I have on controlDict.
functions
wallHeatFlux1
// Mandatory entries (unmodifiable)
type wallHeatFlux;
libs (fieldFunctionObjects);
// Optional entries (runtime modifiable)
patches (bottom); // (wall1 "(wall2|wall3)");
qr qr;
// Optional (inherited) entries
The exact error is:
--> FOAM FATAL ERROR:
Unable to find compressible turbulence model in the database
From virtual bool Foam::functionObjects::wallHeatFlux::execute()
in file wallHeatFlux/wallHeatFlux.C at line 241.
FOAM exiting
Old   July 21, 2021, 05:05
Yann
Hi Oscar,
Sorry, I read your initial post too fast and missed the fact your were using an incompressible solver. The wallHeatFlux function works only with compressible solvers and this is why it doesn't work with buoyantBoussinesq solvers.
You need to use buoyantSimpleFoam to be able to use the wallHeatFlux function. You should be able to select "Boussinesq" as the equation of state in the thermophysicalProperties file in order to run something equivalent to buoyantBoussinesqSimpleFoam.
Another way around is to use a modified version of the wallHeatFlux function in order to make it compatible with incompressible solvers. I know wyldckat made it long time ago but I am not sure it will be compatible with OpenFOAM-v2006.
Have a look here:
https://openfoamwiki.net/index.php/C...Incompressible
postProcess -func wallHeatFlux in openFoam 6
I hope this helps,
Yann
kusamanda likes this.
incompressible flow, wall heat flux
[snappyHexMesh] How to draw a 3D-Drawing for Meshing Kahnbein.Kai OpenFOAM Meshing & Mesh Conversion 4 June 15, 2021 13:16
Nonsensical results with wall heat flux boundary condition jtipton2 OpenFOAM Running, Solving & CFD 2 December 22, 2019 14:43
using heat flux BC on wall in openFOAM 6 ravik21 OpenFOAM Running, Solving & CFD 3 January 14, 2019 22:21
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
