Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Missing pointProcAddressing
Like Tree3Likes
  • 1 Post By quarkz
  • 1 Post By quarkz
  • 1 Post By Amosx
Old   April 23, 2021, 04:58
Unhappy Missing pointProcAddressing
Rebeca is on a distinguished road
Hi everyone!
I'm trying to run the rhoSimpleFoam/gasMixing/injectorPipe tutotial's case with little lucky.
After solving the case, I haven't been able to see the results. If I use the command "reconstructPar", the next error appears:
--> FOAM FATAL ERROR: (openfoam-2012)
cannot find file "/media/sf_OpenFoam/run/tutorials/compressible/rhoSimpleFoam/gasMixing/injectorPipe/processor0/constant/polyMesh/pointProcAddressing"
    From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
    in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 547.
FOAM exiting
And If I try with "reconstructParMesh", it seems to do nothing:
|  \\    /   O peration     | Version:  2012                                  |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
Build  : 79e353b8-20201222 OPENFOAM=2012
Arch   : "LSB;label=32;scalar=64"
Exec   : reconstructParMesh -mergeTol 1e-06
Date   : Apr 23 2021
Time   : 09:16:22
Host   : rebeca-VirtualBox
PID    : 16906
I/O    : uncollated
Case   : /media/sf_OpenFoam/run/tutorials/compressible/rhoSimpleFoam/gasMixing/injectorPipe
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Overriding OptimisationSwitches according to controlDict
    writeNowSignal  12;
sigWriteNow : Enabling writing upon signal 12
This is an experimental tool which tries to merge individual processor
meshes back into one master mesh. Use it if the original master mesh has
been deleted or if the processor meshes have been modified (topology change).
This tool will write the resulting mesh to a new time step and construct
xxxxProcAddressing files in the processor meshes so reconstructPar can be
used to regenerate the fields on the master mesh.
Not well tested & use at your own risk!
Merge tolerance : 1e-06
Write tolerance : 1e-06
Doing geometric matching on correct procBoundaries only.
This assumes a correct decomposition.
Found 8 processor directories
Reading database "injectorPipe/processor0"
    writeNowSignal  12;
Reading database "injectorPipe/processor1"
    writeNowSignal  12;
Reading database "injectorPipe/processor2"
    writeNowSignal  12;
Reading database "injectorPipe/processor3"
    writeNowSignal  12;
Reading database "injectorPipe/processor4"
    writeNowSignal  12;
Reading database "injectorPipe/processor5"
    writeNowSignal  12;
Reading database "injectorPipe/processor6"
    writeNowSignal  12;
Reading database "injectorPipe/processor7"
    writeNowSignal  12;
Time = 100
No mesh.
Time = 200
No mesh.
Time = 300
No mesh.
Time = 400
No mesh.
Time = 500
No mesh.
Time = 600
No mesh.
Time = 700
No mesh.
Time = 800
No mesh.
Time = 900
No mesh.
Time = 1000
No mesh.
Time = 1100
No mesh.
Time = 1200
No mesh.
End
I have been trying to solve this problems for days and I don't know what else to do.
I hope you can help me!
Thanks in advance,
Rebeca
Rebeca is offline   Reply With Quote
Old   December 25, 2021, 20:03
Aps
apoorv121 is on a distinguished road
Hello Rebeca,
It seems like you have a processor*/constant/polyMesh folder structure. reconstructParMesh works when there is only polyMesh folder under each processor* folder. Once all the mesh is reconstructed then you can use the reconstructPar to get all the variable data in single file/time slot.
Also sometimes paraview crashes when loading this type of data. You can use foamToVTK to convert this data since each time folder might have a different mesh due to DyM refinement or topology changes.
Hope it works for you.
apoorv121 is offline   Reply With Quote
Old   March 27, 2023, 01:29
TWB
quarkz is on a distinguished road
For me, I have got this error:
Create time
Reconstructing fields
region=region0
--> FOAM FATAL ERROR: (openfoam-2206)
cannot find file "/home//tsl/scratch/agile_flight/OpenFOAM/model_black_UAV_2.5e-5_5.59M_6dof_moi1_SST/processor0/2e-05/polyMesh/pointProcAddressing"
From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 540.
FOAM exiting
Hence, I wrote a "of_copy_ProcAddressing_loop.sh" script:
#!/bin/bash
for ((i = 0; i < $1; i++ )); do
    echo "$i"
    cp processor$i/constant/polyMesh/*ProcAddressing processor$i/$2/polyMesh/
done
Usage:
of_copy_ProcAddressing_loop.sh a b
where:
a = no of processors
b = time saved
e.g.
of_copy_ProcAddressing_loop.sh a b 512 0.1
Hope it helps.
Adamwambert likes this.
quarkz is offline   Reply With Quote
Old   January 8, 2024, 16:28
ZsoltDraga
dragazsolt is on a distinguished road
Hi quarkz,
Iam have a same issue in case of AMI and Openfoam2306 and 2212.
I tried your scipt it does not work for me properly.
syntax :
sh of_copyProcAddressing_loop.sh 128 0.05
Error is bad for loop variables?
Do you have ideas to fix reconstructPar error?
Thanks,
Zsolt
dragazsolt is offline   Reply With Quote
Old   January 10, 2024, 09:53
TWB
Hi dragazsolt, there's no need for sh in front, just run it like:
./of_copy.sh 512 0.1 if the file is in the same dir.
hope it works.
deepakvil likes this.
Old   February 2, 2024, 02:30
Unhappy does anyone have solution for this problem
Amos
Amosx is on a distinguished road
hello everyone I'm facing the same problem, i managed to run the tutorial but i cannot view the results.
Amosx is offline   Reply With Quote
Old   February 2, 2024, 02:45
Default found how to view the results
Amos
1. create a .foam file using touch command ex. touch case.foam
2.open case.foam using paraview
3.in paraview properties - case type change it to decomposed case.
thank you
Old   July 29, 2024, 15:32
Joern Beilke
JBeilke is on a distinguished road
you have to run:
reconstructParMesh
reconstructPar
JBeilke is offline   Reply With Quote
error, injectorpipe, openfoam, pointprocaddressing
[OpenFOAM.org] RHEL 7.8 Issues installing ParaView - Third Party install not creating OpenMPI browny OpenFOAM Installation 2 April 24, 2021 06:18
[ANSYS Meshing] missing internal faces and uncovered faces after redifining parts containing surface. grv ANSYS Meshing & Geometry 2 December 9, 2016 05:38
what is syntax error : missing ')' before ';' aleisia Fluent UDF and Scheme Programming 8 March 10, 2015 16:42
[OpenFOAM] Xlib: extension "GLX" missing on display goldbeard ParaView 5 March 24, 2013 14:12
errors when installing openfoam2.1 on ubuntu12.o4 hewei OpenFOAM Installation 5 May 29, 2012 08:43
