Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
OF2006 Surface sampling problem : VTP to VTK format
Like Tree2Likes
  • 1 Post By olesen
  • 1 Post By frantov
Old   January 20, 2021, 12:34
Smile OF2006 Surface sampling problem : VTP to VTK format
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
Hello ,
I am using OF2006 release and I want to sample surface data for post-porcessing. Here is my file:
|  \\    /   O peration     | Version:  v2006                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
surfaces
    type        surfaces;
    libs        (sampling);
    writeControl    timeStep;
    writeInterval    10;
    surfaceFormat    vtk;
    fields       (p U T k epsilon);
    surfaces
        zNormal
            type    cuttingPlane;
            planeType    pointAndNormal;
            pointAndNormalDict
                point    (0 0.126 0); // Overrides default basePoint (0 0 0)
                normal       (0 0 1);      // $z: macro for (0 0 1)
                interpolate        true;
Somehow while running the case, the surface files are saved as .vtp and not as .vtk. When I open paraview, I can't read these files. (Also the time doesn't seem to be included). Does anyone know how to overcome this?
alainislas is offline   Reply With Quote
Old   February 9, 2021, 15:39
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by alainislas View Post
Hello ,
surfaces
    type        surfaces;
    libs        (sampling);
    writeInterval    10;
    surfaceFormat    vtk;
    surfaces
        zNormal
            type    cuttingPlane;
            pointAndNormalDict
                interpolate        true;
This is a feature, not a bug. What you are looking for are the additional format options. Eg,
formatOptions
    vtk
        legacy true;
        // format ascii;
Kraneberger likes this.
olesen is offline   Reply With Quote
Old   February 9, 2021, 15:40
Mark Olesen
If they still cannot be read, it could actually be a bug. Would be useful to know if it is broken in v2012.
Old   March 2, 2022, 02:27
Francisco T
frantov is on a distinguished road
You can also type in the terminal (or save it on an AllRun file)
foamToVTK -legacy
this will save it as vtk instead of vtp
alainislas likes this.
frantov is offline   Reply With Quote
paraview 4.2, vtk files
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 08:58
OpenFOAM error Vinay Kumar V Main CFD Forum 0 February 20, 2020 10:17
[General] Paraview data format conversion from vtk to parallel prog data format. odho ParaView 0 September 20, 2016 08:01
Problem with surface monitor position jf90cl FLUENT 0 April 28, 2016 12:41
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 02:10
