Summation in Function Object for Multiple Processors |
October 10, 2020, 16:09 |
Emily
Rep Power: 8 |
This is my first time writing my own function object for OpenFOAM and am struggling to get it to work with mpirun. There are three quantities I want to calculate and write to a file in the postprocessing directory:
- Total volume of my mesh sum(mesh_.V())- Total volume of my liquid (this is multiphase) sum(mesh_.V()*alpha.internalField())- Sum of the position of the cell times the volume times the volume fraction (this should output a vector, not a scalar) sum(mesh_.V()*mesh_.C().internalField()*alpha.inte rnalField())My code seems to work perfectly when I just run interFoam, but gets hung on the summation part with I try to use it with mpirun. To test where it's getting hung, I separated out each of the calculation steps. It made it through until it hit the summation. Please see the code below which has both these test lines and, below that, the lines with correctly write the info to a file when run on a single processor. I have tried both sum and gSum because it sounds like gSum is what should be used for multiple processors. Other forum posts have mentioned having good luck with gSum, but I can't figure out what I'm doing differently/incorrectly. Links to these posts are below. I'm also concerned that even if I can get the summation to work, that it might only sum over the master processor, not all. Does anyone have any recommendations for how to get gSum to work in function objects with mpirun? gSum( ) vs sum() How to sum up a volScalarField Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Copyright (C) 2020 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. \*---------------------------------------------------------------------------*/ #include "CM.H" #include "Time.H" #include "fvMesh.H" #include "addToRunTimeSelectionTable.H" #include "fvCFD.H" #include "OSspecific.H" #include <iostream> // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * // namespace Foam { namespace functionObjects { defineTypeNameAndDebug(CM, 0); addToRunTimeSelectionTable(functionObject, CM, dictionary); } } // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // Foam::functionObjects::CM::CM ( const word& name, const Time& runTime, const dictionary& dict ) : fvMeshFunctionObject(name, runTime, dict), logFiles(obr_, name)//, { read(dict); resetName(name); } // * * * * * * * * * * * * * * * * Destructor * * * * * * * * * * * * * * * // Foam::functionObjects::CM::~CM() {} // * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * // void Foam::functionObjects::CM::writeFileHeader(const label i) { } bool Foam::functionObjects::CM::read(const dictionary& dict) { return true; } bool Foam::functionObjects::CM::execute() { return true; } bool Foam::functionObjects::CM::end() { return true; } bool Foam::functionObjects::CM::write() { if (Pstream::master()) { #include "volFields.H" #include "uniformDimensionedFields.H" const volScalarField& alpha = mesh_.lookupObject<volScalarField>("alpha.water"); auto& runTime = fileObr_.time(); logFiles::write(); //This section just tests where the code is getting hung up. w, x, and y make it through fine. z is where it gets stuck when run in parallel auto w = alpha.internalField(); auto x = alpha.internalField()*mesh_.V(); auto y = mesh_.V()*mesh_.C().internalField()*alpha.internalField(); auto z = gSum(mesh_.V()); //This is where it gets stuck //This prints out the results to a file- works on one processor, but not with mpirun file() << runTime.timeName() << " " << gSum(mesh_.V()) << " " << gSum(mesh_.V()*alpha.internalField()) << " " << gSum(mesh_.V()*mesh_.C().internalField()*alpha.internalField()) << endl; } return true; } // ************************************************************************* // |
October 12, 2020, 18:17 |
Joachim Herb
Rep Power: 22 |
Just a guess: what happens if you use explicit OpenFOAM types, e.g. scalar for z?
October 12, 2020, 18:54 |
#3 | |
Emily
Rep Power: 8 |
CM.C:121:30: error: cannot convert ‘Foam::dimensioned<double>’ to ‘Foam::scalar {aka double}’ in initialization scalar z = sum(mesh_.V()); Code:
CM.C:121:26: error: ‘const class Foam::DimensionedField<double, Foam::volMesh>’ has no member named ‘value’ |
October 12, 2020, 20:39 |
Emily
Rep Power: 8 |
So I guess adding .value() after sum is what it needs to be a double. I no longer get the error during wmake when specifying that it should be a double/scalar. However, interFoam still gets hung on calculating z.
October 13, 2020, 11:59 |
Emily
Rep Power: 8 |
Alright, I have it figured out. I actually needed to do some calculations before moving to the master processor. Right now I have it set up to calculate each of my needed quantities on individual processors, gather lists, and then write the result on the master processor. I'm not actually convinced that it's even necessary to gather the list, so I'll post an update if I have a simplified code. But either way, this code works for what I wanted even if it isn't the prettiest.
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Copyright (C) 2020 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. \*---------------------------------------------------------------------------*/ #include "CM.H" #include "Time.H" #include "fvMesh.H" #include "addToRunTimeSelectionTable.H" #include "fvCFD.H" #include "OSspecific.H" #include <iostream> // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * // namespace Foam { namespace functionObjects { defineTypeNameAndDebug(CM, 0); addToRunTimeSelectionTable(functionObject, CM, dictionary); } } // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // Foam::functionObjects::CM::CM ( const word& name, const Time& runTime, const dictionary& dict ) : fvMeshFunctionObject(name, runTime, dict), logFiles(obr_, name) { read(dict); resetName(name); } // * * * * * * * * * * * * * * * * Destructor * * * * * * * * * * * * * * * // Foam::functionObjects::CM::~CM() {} // * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * // void Foam::functionObjects::CM::writeFileHeader(const label i) { //Print out a file header with what each number is file() << "Time(s)" << " " << "totalVol" << " " << "waterVol" << " " << "CMx" << " " << "CMy" << " " << "CMz" << endl; } bool Foam::functionObjects::CM::read(const dictionary& dict) { return true; } bool Foam::functionObjects::CM::execute() { return true; } bool Foam::functionObjects::CM::end() { return true; } bool Foam::functionObjects::CM::write() { #include "volFields.H" #include "uniformDimensionedFields.H" //Assign names to the quantities we want auto volume = mesh_.V(); //Volume of each cell in the mesh const volScalarField& alpha = mesh_.lookupObject<volScalarField>("alpha.water"); //Volume fraction of each cell in the mesh auto position = mesh_.C(); //Position of each cell in the mesh //Calculate the values we want on each processor double volsum = sum(volume).value(); //Volume of the mesh double watervol = sum(volume*alpha.internalField()).value(); //Volume of water auto waterposit = sum(volume*alpha.internalField()*position).value(); //Sum of the volume*volume_fraction*cell_position double waterpositX = waterposit.component(0); //Extract x component of sum of the volume*volume_fraction*cell_position double waterpositY = waterposit.component(1); //Extract y component of sum of the volume*volume_fraction*cell_position double waterpositZ = waterposit.component(2); //Extract z component of sum of the volume*volume_fraction*cell_position //Create a variable proci which is the number of the current processor const label proci=Pstream::myProcNo(); //Create lists which have the length equal to the number of processors List<double>volList(Pstream::nProcs()); List<double>watervolList(Pstream::nProcs()); List<double>waterXList(Pstream::nProcs()); List<double>waterYList(Pstream::nProcs()); List<double>waterZList(Pstream::nProcs()); //Assign each variable a different position in the list based on their processor volList[proci]=volsum; watervolList[proci]=watervol; waterXList[proci]=waterpositX; waterYList[proci]=waterpositY; waterZList[proci]=waterpositZ; //Collapse the lists onto one processor Pstream::gatherList(volList); Pstream::gatherList(watervolList); Pstream::gatherList(waterXList); Pstream::gatherList(waterYList); Pstream::gatherList(waterZList); //On the master processor if (Pstream::master()) { //Assign a name to the time step value auto& runTime = fileObr_.time(); logFiles::write(); //Calculate the sum of each value over all of the processors double totalVol = sum(volList)/(Pstream::nProcs()); double waterVol = sum(watervolList)/(Pstream::nProcs()); double volX = sum(waterXList)/(Pstream::nProcs()); double volY = sum(waterYList)/(Pstream::nProcs()); double volZ = sum(waterZList)/(Pstream::nProcs()); //Center of mass is the sum(volume*position*volume_fraction)/sum(volume*volume_fraction) double CMx = volX/waterVol; double CMy = volY/waterVol; double CMz = volZ/waterVol; //Write the variables we want to the postprocessing log file file() << runTime.timeName() << " " << totalVol << " " << waterVol << " " << CMx << " " << CMy << " " << CMz << endl; } return true; } // ************************************************************************* // |
December 5, 2020, 17:06 |
Center of Mass Function Object
Emily
Rep Power: 8 |
In case anyone could benefit from it, I've attached the complete center of mass function object directory. You should be able to just run wmake in the attached directory, then include it in your controlDict using something like the following:
center { type CM; libs ("libCMFunctionObject.so") } |
December 6, 2020, 04:13 |
#7 | |||
Mark Olesen
Rep Power: 40 |
I saw this one a bit late. There are a number of things that are either more work that you need, or too inefficient. Here are some, with inline comments.
const auto& volume = mesh_.V(); const auto& position = mesh_.C(); Quote:
You were right to doubt the need for all of those awkward processor lists. Instead of more comments, here are some simple tips Code:
scalar someVal =...; // processor local value reduce(someVal, sumOp<scalar>()); // global sum // or scalar localVal =...; scalar globalVal = returnReduce(localVal, sumOp<scalar>()); // working with primitive fields scalarField localField =... ; scalar localSum = sum(localField); scalar globSum1 = returnReduce(localSum, sumOp<scalar>()); // same thing scalar globSum2 = gSum(localField); If you start using these functions, you will be writing a lot less code, more quickly and easier to understand and maintain. Quote:
// obvious filled directly elsewhere // with your volX, volY, volZ vector volDirs(...) ; vector CMass = volDirs/waterVol; |
December 6, 2020, 04:23 |
#8 | |
Mark Olesen
Rep Power: 40 |
Is this a cut and paste error? Or have you actually transferred your code copyrights to the OpenFOAM Foundation Ltd.? |
December 10, 2020, 15:16 |
#9 |
Emily
Rep Power: 8 |
Thank you so much for your feedback! It looks like you've got some excellent suggestions, so I'll go through them all as soon as I have the time!
Yes, the header is a copy and paste error. I used the OpenFOAM provided template, and was too worried about getting the code to work that I didn't check the header. It may be a week or two before I'm able to get back to this, but I'll post a new code when I can. |
function objects, gsum(), mpirun, postprocess function, sum() |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
How to create a function object in OpenFoam that runs properly ? | mkhm | OpenFOAM Programming & Development | 1 | October 20, 2018 17:16 |
[snappyHexMesh] Problem with parallel run of snappyHexMesh | Lorenzo92 | OpenFOAM Meshing & Mesh Conversion | 5 | April 15, 2016 05:12 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
