Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Probing data with internalProbes
Like Tree4Likes
  • 1 Post By smokbel
  • 3 Post By Yanagi
Old   August 27, 2020, 03:02
Default Probing data with internalProbes
smokbel
smokbel is on a distinguished road
Hello all,
I am trying to sample data using internalProbes and I am getting an unfixable error:
--> FOAM FATAL IO ERROR:
keyword ordered is undefined in dictionary "controlDict.functions.internalProbes.sets"
file: controlDict.functions.internalProbes.sets from line 19 to line 17.
My internalProbes file looks like this:
fields (p U);
points
   // lots of points here
libs            ("libsampling.so");
type            probes;
interpolationScheme cellPoint;
setFormat   raw;
writeControl    writeTime;
#includeEtc "caseDicts/postProcessing/probes/internalProbes.cfg"
Does anyone know how to solve this? I am not sure what the error even means, and cannot find any "ordered" keyword in the OpenFOAM code.
shanz likes this.
smokbel is offline   Reply With Quote
Old   October 14, 2020, 04:21
Default I am facing the same issue
Shantanu
shanz is on a distinguished road
I am using internalProbes and having the following error:
    From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 573.
My internalProbes file looks like the following:
#includeEtc "caseDicts/postProcessing/graphs/sampleDict.cfg"
fields (p U);
points
    (0 0 0)
Please let me know if you know solution to this.
shanz is offline   Reply With Quote
Old   October 29, 2020, 05:59
Smile
taka
takahisa is on a distinguished road
fields (p U);
points
    (0 0 0)
Please try to add "ordered;" in sets sub-dictionary.
takahisa is offline   Reply With Quote
Old   June 2, 2022, 12:50
Tomii Kobayashi
Yanagi is on a distinguished road
I had the same problem using internalProbes. I know this thread has been frozen for almost a year, however, for further reference I would like to report one solution to this. I am using openfoam6.
first I use
foamGet internalProbes
and import both internalProbes and internalProbes.cfg
and then I edit internalProbes as:
fields (p U);
points
         $your probe points
setFormat       raw;
#includeETC "$yourcasedirectory/system/internalProbes.cfg"
Next, edit internalProbes.cfg as:
type            sets;
executeControl  writeTime;
sets
    points
        type    points;
        axis    xyz;
        points  $points;
        ordered 1;
Finally, in your controlDict, edit functions dictionary as:
functions
   #includeFunc "internalProbes"
$Rest of post processing...
Run your openfoam program, you will get this function into postProcessing directory.
Credits to https://qiita.com/takaf05/items/4d56e95924f8ad1c1cfd.
caduqued, ucantosbaa and picpic like this.
Yanagi is offline   Reply With Quote
post processing, probes, sampling
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
[OpenFOAM] Paraview doesn't seem to be picking up data generated by icofoam MikeHersee ParaView 2 January 6, 2015 09:27
Data Produced From Fine Marine Cant Match with The Experimental Data PeiSan Fidelity CFD 4 August 23, 2014 06:33
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
