gnuplot stopped working: unable to find shared library |
Franco Marra
Rep Power: 17 ![]() |
Dear All,
I need help to solve a strange issue occurred after a normal update. Gnuplot does not work anymore with the following message: Code:
gnuplot: error while loading shared libraries: .5: cannot open shared object file: No such file or directory My system is a Ubuntu version (xenial) running under Qlustar (a distribution specific for cluster management). All other applications work fine (including the graphical paraFoam and Veusz). The output of command ldd /usr/bin/gnuplot reads: Code:
/usr/bin/gnuplot: /usr/lib/x86_64-linux-gnu/libtiff.so.5: unsupported version 16 of Verdef record /usr/bin/gnuplot: /usr/lib/x86_64-linux-gnu/libtiff.so.5: unsupported version 16 of Verdef record Inconsistency detected by ld.so: dl-version.c: 224: _dl_check_map_versions: Assertion `needed != NULL' failed! Yours sincerely, Franco |
Robert Crane
Rep Power: 6 ![]() |
did you get this working? I am having the same problem.
Rob |
Robert Crane
In my case, I had to run the following command:
sudo strip --remove-section=.note.ABI-tag /usr/lib/x86_64-linux-gnu/libQt5Core.so.5 Gnuplot now runs properly for me. https://superuser.com/questions/1347...eing-installed |
gnuplot, system environment |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 07:53 |
OpenFOAM141dev linking error on IBM AIX 52 | matthias | OpenFOAM Installation | 24 | April 28, 2008 15:49 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
