Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
OpenFoam-Paraview "Cell array" problem
Like Tree4Likes
  • 4 Post By simrego
Old   January 11, 2020, 08:45
Default OpenFoam-Paraview "Cell array" problem
Márk Csete
Cobus is on a distinguished road
Dear Foamers,
I am pretty new here, and I would like to ask for your help about a problem of mine. I am doing the tutorials of OF, and there is the multiphase problem to be solved.
After creating everything in damBreak (0, constant, system files), I created a foam.foam to open the paraview on it. My problem is even I am in the right folder, when paraview opens, there is no "Cell Arrays" appearing. So I cannot start to visualize the simulations. (I also checked and followed József Nagy's videos on Youtube)
I attached picture about the situation.
Thank you so much!
Cobus
P.S: I do not know if the picture is there, so I will link it here: https://imgur.com/ibvX3fU
Cobus is offline   Reply With Quote
Old   January 12, 2020, 04:11
anonymous
simrego is on a distinguished road
Hi!
Have you started the solver, or you just wanna see the initial field? If you have no times other than 0, you should uncheck the "skip zero time" box. Also make sure if you run your case in parallel, you have to choose "decomposed case" instead of "reconstructed case" if you did not reconstructed your case. (Actually you shouldn't reconstruct since you just eat the space on your disk for no reason.)
simrego is offline   Reply With Quote
Old   January 13, 2020, 07:20
Márk Csete
Originally Posted by simrego View Post
Hi!
Simrego,
Thank you for your help. It turned out to be, my solver was not functioning as it should have been. I need to correct some data and folders.
Also, thank you for the good advises!
Old   November 3, 2021, 17:24
Santhosh
Santhosh91 is on a distinguished road
Originally Posted by Cobus View Post
Simrego,
Hello Cobus,
I am currently facing the same issue, I wanted to know what kind of manipulation did you do to make it works
Thank you for your time !
Santhosh
Santhosh91 is offline   Reply With Quote
Old   March 30, 2022, 15:08
Thomas de Lange
ThomasdeLange is on a distinguished road
Hi all,
Same problem here. The "Cell Arrays" box is just empty while it should display p, U and T. Anyone found a solution yet?
Thomas
ThomasdeLange is offline   Reply With Quote
Old   November 19, 2024, 04:36
AA
kkaptan is on a distinguished road
Hi ThomasdeLange,
I faced same problem and i could solve this problem with converting data to a .vtk format using foamToVTK and reloading it. I hope it'll solve your problem
kkaptan is offline   Reply With Quote
cell array, openfoam, paraview, problem
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 03:28
Yet another Paraview problem gascortado OpenFOAM 5 February 21, 2010 07:39
[OpenFOAM] Some problem with paraview thermo ParaView 10 December 25, 2005 14:20
