Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
openfoam - monitor flow value on internal surface
Like Tree6Likes
  • 6 Post By ufocfd
Old   August 7, 2019, 11:36
Default openfoam - monitor flow value on internal surface
Giles Richardson
ufocfd is on a distinguished road
Im posting this because it took me a while to set up correctly, so maybe it will be useful to others. It monitors the flow and logs the results.
I needed to monitor the average velocity at a plane within the mesh (not a patch or boundary condition), so I was able to use an STL file to specify the plane location (just a flat plate), using sampledTriSurfaceMesh.
I used the code below which is added to the controlDict file - you can change the operation to average, areaAverage,min,max etc. Note the STL file need to be completely within the mesh domain, or you will get warning messages.
surfaceFieldValue1
name midradsurf;
type surfaceFieldValue;
libs ("libfieldFunctionObjects.so");
writeControl timeStep;
writeInterval 1;
writeFields false;
log true;
operation average; //areaAverage, average, max, min
fields (U);
regionType sampledSurface;
surfaceFormat stl;
sampledSurfaceDict
type sampledTriSurfaceMesh;
surface midradsurf.stl; // <<<<<<< stl file
source cells;
interpolate true;
ufocfd is offline   Reply With Quote
Old   November 19, 2020, 12:15
giovanni
gian93 is on a distinguished road
it seems not to work with field phi .. it generates a warning like this :
HTML Code:
surfaceFieldValue massFlowatTurbinlet write:
--> FOAM Warning :
    From function Foam::label Foam::functionObjects::fieldValues::surfaceFieldValue::writeAll(const vectorField&, const Foam::Field<Type>&, const Foam::meshedSurf&) [with WeightType = double; Foam::label = int; Foam::vectorField = Foam::Field<Foam::Vector<double> >]
    in file fieldValues/surfaceFieldValue/surfaceFieldValueTemplates.C at line 358
    Requested field phi not found in database and not processed
why?
>> solution: sampledSurface not available for surface fields
Last edited by gian93; November 19, 2020 at 12:41. Reason: solution: not available for surface fields
gian93 is offline   Reply With Quote
Old   October 10, 2022, 15:54
Default monitor flow value on internal surface
Didu is on a distinguished road
Dear foamers,
I came across this thread and it's exactly what I'm looking for, my case is a simple pipe with a constant cross-section and I need to analyze the mass flow in the middle, I tried some solutions presented in this topic, however, none resulted in success, does anyone know why? I have noticed that the command change in version 2112...
Mainly, I have to analyze the flow behaviour (mass flow rate) in the middle of the total pipe length, my initial idea was to generate a plane, create a patch and run the following command "postProcess -func" flowRatePatch(name=middle)" however, this resulted in a big challenge.
Didu is offline   Reply With Quote
Old   October 11, 2022, 23:34
Tatsuya Shimizu
LongGe is on a distinguished road
Hi ALL,
There is a very good example in OpenFOAM tutorials as "OpenFOAM/OpenFOAM-v2012/tutorials/compressible/rhoSimpleFoam/squareBend". This tutorial describes how to sample various cross sections. Of course, examples of flow rate sampling are also provided.
Our Work: https://www.idaj.co.jp/product/ennovacfd/openfoam_gui/
Powered by Ennova : https://ennova-cfd.com/
Ennova's Channel Partners : http://www.wolfdynamics.com/
LongGe is offline   Reply With Quote
sampledsurface, sampledtrisurfacemesh, simplefoam
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
[Commercial meshers] Fluent Mesh to OpenFoam: Internal Surface has to be a wall sebastian OpenFOAM Meshing & Mesh Conversion 6 October 21, 2010 05:36
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
