Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Total liquid volume fraction vs Time
Like Tree11Likes
  • 1 Post By Pavithra
  • 2 Post By anon_q
  • 2 Post By anon_q
  • 2 Post By anon_q
Old   August 4, 2019, 08:24
Default Total liquid volume fraction vs Time
Pavithra is on a distinguished road
Hello Everyone,
I am simulating melting process by modifying buoyantBoussinesqPimpleFoam. I have calculated the total liquid volume fraction as follows:
dimensionedScalar tlf = (sum(mesh.V()*lf))/(sum(mesh.V()));
where,
lf is the local liquid volume fraction.
Now, I want to write a dat/xy file to plot tlf vs time. Kindly, please guide me to achieve this.
Thank You.
Svetlana likes this.
Pavithra is offline   Reply With Quote
Old   August 4, 2019, 19:01
anon_q is on a distinguished road
You can store your data tlf values in an array and save it to a file.
//Before entering the time loop decalre the hashTable
HashTable<scalar, word> tlfValues;
//Inside the time loop
word t = runTime.timeName();
tlfValues.insert(t, sum(mesh.V()*lf))/(sum(mesh.V()));
// Outside the time loop, save the hash table to a file
OFstream myfile("./tlfvalues");
myfile() << tlfValues;
Svetlana and Pavithra like this.
anon_q is offline   Reply With Quote
Old   August 4, 2019, 23:13
Respected Mam,
Thank you so much for your kind help. I tried the code you provided. But, I am unable to compile after adding the code.
My solver.C file is as follows:
#include "fvCFD.H"
#include "fvOptions.H"
#include "pimpleControl.H"
int main(int argc, char *argv[])
    #include "postProcess.H"
    #include "setRootCaseLists.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "createControl.H"
    #include "createFields.H"
    #include "createTimeControls.H"
    #include "CourantNo.H"
    #include "setInitialDeltaT.H"
    #include "initContinuityErrs.H"
    Info<< "\nStarting time loop\n" << endl;
        while (runTime.run())
            #include "readTimeControls.H"
            #include "setDeltaT.H"
            runTime++;
            Info<< "Time = " << runTime.timeName() << nl << endl;
        //update the latent heat content after inner each loop
        volScalarField DHnew = DH;
            // --- Pressure-velocity PIMPLE corrector loop
            while (pimple.loop())
                        #include "UEqn.H"
                        // --- Pressure corrector loop
                        while (pimple.correct())
                               #include "pEqn.H"
                    #include "TEqn.H"
                    tlfValues.insert(t, (sum(mesh.V()*lf))/(sum(mesh.V())));
        //calculate the total liquid fraction
        runTime.write();
            Info<< nl << endl;
        //print the total liquid fraction
            Info<< "Total Liquid Fraction = " << tlf.value() << endl;
            Info<< nl << endl;
        //print the execution time
            Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s";
        Info<< nl << endl;
        //print the clock time
            Info<< "  ClockTime = " << runTime.elapsedClockTime() << " s";
        Info<< nl << endl;
        Info<< "End\n" << endl;
        return 0;
The error message is as follows:
meltFoam.C: In function 'int main(int, char**)':
meltFoam.C:105:63: error: no matching function for call to 'Foam::HashTable<double, Foam::word>::insert(Foam::word&, Foam::dimensioned<double>)'
In file included from /opt/openfoam6/src/OpenFOAM/lnInclude/HashTable.H:560:0,
                 from /opt/openfoam6/src/OpenFOAM/lnInclude/runTimeSelectionTables.H:41,
                 from /opt/openfoam6/src/OpenFOAM/lnInclude/token.H:49,
                 from /opt/openfoam6/src/OpenFOAM/lnInclude/UListIO.C:28,
                 from /opt/openfoam6/src/OpenFOAM/lnInclude/UList.C:233,
                 from /opt/openfoam6/src/OpenFOAM/lnInclude/UList.H:484,
                 from /opt/openfoam6/src/OpenFOAM/lnInclude/List.H:43,
                 from /opt/openfoam6/src/OpenFOAM/lnInclude/labelList.H:48,
                 from /opt/openfoam6/src/OpenFOAM/lnInclude/UPstream.H:42,
                 from /opt/openfoam6/src/OpenFOAM/lnInclude/Pstream.H:42,
                 from /opt/openfoam6/src/OpenFOAM/lnInclude/parRun.H:35,
                 from /opt/openfoam6/src/finiteVolume/lnInclude/fvCFD.H:4,
                 from meltFoam.C:48:
/opt/openfoam6/src/OpenFOAM/lnInclude/HashTableI.H:79:13: note: candidate: bool Foam::HashTable<T, Key, Hash>::insert(const Key&, const T&) [with T = double; Key = Foam::word; Hash = Foam::string::hash]
 inline bool Foam::HashTable<T, Key, Hash>::insert
/opt/openfoam6/src/OpenFOAM/lnInclude/HashTableI.H:79:13: note:   no known conversion for argument 2 from 'Foam::dimensioned<double>' to 'const double&'
/opt/openfoam6/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/meltFoam.o' failed
make: *** [Make/linux64GccDPInt32Opt/meltFoam.o] Error 1
Kindly, please help me.
Thank You.
Old   August 5, 2019, 08:26
Sorry, I forgot to call the value() method of dimensionedScalar variable tlf.
#include "fvCFD.H"
            runTime++;
                        #include "UEqn.H"
                               #include "pEqn.H"
                    #include "TEqn.H"
	// These lines must be outside the pimple loop
	dimensionedScalar tlf = sum(mesh.V()*lf))/(sum(mesh.V());
        tlfValues.insert(t, tlf.value());
        runTime.write();
            Info<< nl << endl;
            Info<< nl << endl;
        Info<< nl << endl;
        Info<< nl << endl;
    myFile() << "time\t" << "tlf" << endl;
    // Write the tlfValues to the file sorted by time
    for (word ti : tlfValues.sortedToc())
         myfile() << ti << "\t" << tlfValues[ti] << endl;
        return 0;
I haven't tested that, but you can just try to compile it.
Old   August 5, 2019, 22:52
Good morning mam,
Thank you so much. It worked perfect.
Thank You.
With Thanks,
Pavithra.
Old   August 6, 2019, 12:22
Just to solve the issue of sorting, we have to change the key to scalar (double) instead of word (string).
#include "fvCFD.H"
    HashTable<scalar, scalar, Hash<scalar>> tlfValues;
            runTime++;
                        #include "UEqn.H"
                               #include "pEqn.H"
                    #include "TEqn.H"
	scalar t = runTime.value();
        runTime.write();
            Info<< nl << endl;
            Info<< nl << endl;
        Info<< nl << endl;
        Info<< nl << endl;
    for (scalar ti : tlfValues.sortedToc())
        return 0;
Old   August 6, 2019, 22:25
Thank you so much mam. It works perfect.
Old   August 7, 2019, 08:06
Hi Everyone,
I have attached the solver which I was trying to make.
The solver is based on buoyantBoussinesqPimpleFoam. The enthalpy-porosity method proposed by Voller & Brent has been employed.
This solver can be used for isothermal and non-isothermal melting.
The solvers perform adequately well for Gallium melting case and 1-D Stefan problem.
The solver is compiled and tested in OF v6.
Any advice or suggestions for improvements are welcome.
Also, please give me a direction to make this solver work in parallel. At present, this solver works well in single core but, crashes while using mpirun.
Thank You.
- Pavithra
Kummi likes this.
Old   August 8, 2019, 05:40
Hi Everyone,
I am attaching the results of some validation cases, herewith.
I have attached the solver, cases and results. Any suggestions for improvements are welcome.
Thank You.
- Pavithra
Old   October 3, 2024, 16:31
Default parallel simulation
Adarsh Thakur
adarsh_CFD is on a distinguished road
Originally Posted by Pavithra View Post
Hi Everyone,
Thank You.
- Pavithra
Hii, have you resolve the issue of crashing using mpirun. If yes please let me know,
Thank You
Adarsh
adarsh_CFD is offline   Reply With Quote
global variable vs time, openfoam, postprocessing
[IHFOAM] The IHFOAM Thread Phicau OpenFOAM Community Contributions 392 September 8, 2023 19:10
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 04:41
Error in run Batch file saba1366 CFX 4 February 10, 2013 02:15
interDyMFoam - change in volume fraction gopala OpenFOAM Running, Solving & CFD 0 April 27, 2009 11:46
