April 5, 2019, 10:13 |
post-pressing .foam file in CFD-post
Ye Wang
Hi, dear foamers! I'm new to OpenFOAM.
One of the beginning difficulties I met lies on the post-processing using paraView, while I'm much more familiar with CFD-post. Thus, in this slide I'd like to summary the method of post-process a ".foam" file in CFD-post. I will be very happy if it can help some new foamers like me. The discussions in "FoamDataToFluent" really helps a lot, and I'd like to summary the steps more clearly. 1) edit system/controlDict startFrom latestTime; 2) build file system/foamDataFluentDict one of the foamDataFluentDict examples can be found in "tutorials/incompressible/icoFoam/elbow/system/foamDataToFluentDict" 3) run foamMeshToFluent 4) run foamDataToFluent Then, a "fluentInterface" folder is built in your test folder 5) go to software Fluent (in windows for me) read ".msh" file in "fluentInterface" folder then, read the last step ".dat" file in "fluentInterface" folder 6) write case&data in Fluent then the ".cas" file can be read in CFD-post But, I'm confused that the test0.dat and test100.dat show totally the same result in CFD-post, I'm not sure if it is right and the reason of the similarity (0 and 100 are the time step). Any suggestion&quick answer is appreciated! Thanks in advance! |
April 23, 2019, 11:48 |
Can't load multiple timesteps
Rep Power: 8 |
Hello !
I am new to openfoam as well and wish to view my results in CFD-post. I followed exactly the procedure described above, but when I load the .dat file in post, only one timestep is loaded in the timestep selector. Do I need to open each timestep in fluent individually and save it again as a .dat ? Thanks in advance ! |
April 24, 2019, 02:19 |
#3 | |
Ye Wang
Moreover, I think it is a better choice for one to study paraView if possible. Because some people said the simulation with heat transfer may meet unexpected problem in changing to CFD-POST (for more information you can search in CFD-Online, I saw it before). And the transform of OpenFAOM result to Fluent result may cost some time if one have lots of time step results. Anyway, best wishes to your research! |
cfd - post, fluent, post procesing |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
