Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
BACKWARD FACING STEP - postProcessing
Like Tree1Likes
  • 1 Post By yambanshee
Old   March 23, 2019, 11:20
Default BACKWARD FACING STEP - postProcessing
gu1
Guilherme
gu1 is on a distinguished road
I've attached an image below and unfortunately do not know how to create it in OpenFOAM (...distribute velocity profiles, TKS profile... throughout the geometry), could anyone share their experiences?
** OpenFOAM 5.0;
gu1 is offline   Reply With Quote
Old   April 23, 2019, 12:43
Zander Meiring
yambanshee is on a distinguished road
I quickly had a go at doing something like this. This is what I came up with:
Use the calculator tool to extract a vector that you are interested. For example, if you want the axial direction velocity (x direction) type the following in the calculator:
(U_X*iHat)+(0*jHat)+(0*kHat)
Make a slice where you want to view your contour line
Use the filter "wrap by vector" on that slice and chose the vector you created in the calculator. It might be necessary to play with the scale
edit: If you are searching for filters, press cntrl+space and type the filter name. Also attached is my trial run to see if it works.
gu1 likes this.
yambanshee is offline   Reply With Quote
backward facing step, openfoam 5.0, post processing
Backward facing step; x/H; U/U0; diemsionless analysis; paraview idrama OpenFOAM 1 December 3, 2013 18:10
backward facing step simple with no particle saeed115 Mesh Generation & Pre-Processing 0 March 5, 2013 18:41
How to do analysis at backward facing step warlocklw CFX 5 December 21, 2011 07:50
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
backward facing step problem Yung-Ming Chen Main CFD Forum 3 May 11, 1999 23:04
