Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Accessing View factors of a patch for postprocessing
Like Tree1Likes
  • 1 Post By keitaro7_14
Old   February 14, 2019, 06:00
Default Accessing View factors of a patch for postprocessing
Sudarshan Padubidre
pss47 is on a distinguished road
I am performing steady-state passenger cabin simulation using OpenFOAM 6 including radiation load using view factor model.
I want to calculate Mean Radiant temperature for the mannequin after running the simulation.
M R T = T _ { 1 } F _ { p - 1 } + T _ { 2 } F _ { p - 2 } + \ldots + T _ { n } F _ { p - n }
where:
M R T is Mean Radiant Temperature
T _ { n } is the temperature of surface "n", in Kelvin
F _ { p - n } is the angle factor between a person and surface "n".
My questions are
  1. How can i access view factors of a patch to create custom function objects?
  2. Is there any other approach I can try to calculate the mean radiant temperature directly?
Thank you
Sudarshan
pss47 is offline   Reply With Quote
Old   December 12, 2019, 21:29
Jairo A. Gutiérrez S
jairoandres is on a distinguished road
Hi, could you finally solve that problem? I was reading a PhD thesis and they did it externally through the analytical procedure. Were you able of doing it directly in OpenFOAM?
jairoandres is offline   Reply With Quote
Old   December 15, 2019, 06:12
Sudarshan Padubidre
Hey,
I couldn't do it directly in the OpenFOAM. It would be great if you post me a link of the paper for my future reference.
Thanks
Old   December 19, 2019, 11:28
Sure, it's
Indoor Thermal Comfort Modeling and Simulation Using Computational Fluid Dynamics. Authors: Krzysztof Arendt & Marek Krzaczek
I am going to use the correlations given by "Angle Factor Calculation for the Thermal Radiation Environment of the Human Body". How did you resolve the problem?
Old   January 7, 2020, 04:46
Sudarshan Padubidre
Sure, it's
Since I had limited time to finish my master thesis, I gave up on calculating MRT.
Old   June 8, 2020, 11:53
JuanMi
keitaro7_14 is on a distinguished road
You can access to the viewfactor by means of the the dictionary viewFactorsDict.
You must write : debug 1; inside the dictionary to show the view factors when viewFactorsGen is executed.
Jay22kar likes this.
keitaro7_14 is offline   Reply With Quote
custom defined function, function objects, openfoam-6, post procesing, view factors
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
mapField error rvl565 OpenFOAM Pre-Processing 1 September 6, 2018 17:13
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
