Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Total Pressure Incompressible
Like Tree2Likes
  • 2 Post By SvenBent
Old   February 5, 2019, 16:32
Default Total Pressure Incompressible
WaterHammer1985 is on a distinguished road
I want to use the totalPressureIncompressible (postProcess -func totalPressureIncompressible) but keep getting the following error message:
Error Message
[69] --> FOAM FATAL ERROR:
    request for volScalarField rhoInf from objectRegistry region0 failed
    available objects of type volScalarField are
17
interfaceProperties:K
nut
epsilon_0
alpha.water
rho
k
p_rgh
(0.5*magSqr(U))
nu
gh
nu1
p
rho_0
nu2
alpha.air
k_0
epsilon
In the system/controlDict, I have:
functions
pressure
        type            pressure;
        functionObjectLibs ("libfieldFunctionObjects.so");
        writeControl    outputTime;
        rhoInf  1000;
        rho     rhoInf;
        pRef    0;
        calcTotal   yes;
        calcCoeff   no;
How do I get this to work properly? I'm using interIsoFoam for the solver but don't think that should matter...
WaterHammer1985 is offline   Reply With Quote
Old   February 11, 2019, 02:12
Zander Meiring
yambanshee is on a distinguished road
try this:
functions
    totalPressure
        #includeEtc "caseDicts/postProcessing/pressure/totalPressureIncompressible.cfg"
        pRef    0.0;
        rhoInf  1000;
If you go to openfoam/ect/caseDicts/postProcessing/pressure you can see that the file included here eventually leads down to a similar function call to what you are requesting here
yambanshee is offline   Reply With Quote
Old   February 12, 2019, 18:54
Default .
Thanks for the suggestion. I just tried it but am still getting same error. I looked through the files you point to and agree that it leads to similar function call. I've tried adding "rhoInf 1000;" to those files also (throw it on the wall and see what sticks technique) but still get the same error. Any other ideas on how I can get it hooked up?
~/system/controlDict
functions
    totalPressure
        pRef    0.0;
        rhoInf  1000;
#includeEtc "caseDicts/postProcessing/pressure/pressure.cfg"
calcTotal     yes;
calcCoeff     no;
rho           rhoInf;
pressure.cfg
type            pressure;
libs            ("libfieldFunctionObjects.so");
executeControl  writeTime;
writeControl    writeTime;
log             false;
Old   February 27, 2019, 07:09
Mathias Poulsen
SvenBent is on a distinguished road
I think the solver "acts" as compressible solver, and use the density in the NS-equations. Therefore, the rhoInf functionality is not available. If you look at the error message, you can see that rho and rho_0 are available from the objectRegistry.
17
nut
epsilon_0
alpha.water
rho
k
p_rgh
(0.5*magSqr(U))
nu
gh
nu1
p
rho_0
nu2
alpha.air
k_0
epsilon
I would guess that you can get the total pressure from each phase, say rho is the density of water, you would get the totalPressure field for the water phase and vice versa.
Try running the function below:
functions
pressure
        type            pressure;
        rho     rho;
        pRef    0;
        calcTotal   yes;
        calcCoeff   no;
Best regards
Mathias
amolrajan and WaterHammer1985 like this.
SvenBent is offline   Reply With Quote
Old   February 27, 2019, 14:39
Default .
Thanks for the advice, that worked!
total pressure
Total pressure in rel frame and total pressure Salut CFX 14 May 8, 2023 03:29
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
Error in run Batch file saba1366 CFX 4 February 10, 2013 02:15
Total pressure in CFX famarcfd CFX 0 June 17, 2011 11:33
