Calculating Peclet Number in laminar flow when using icoFoam |
January 29, 2019, 09:51 |
Dear Foamers,
I'm struggling to complete a simple task (I think): calculating the Peclet number filed on the results of an icoFoam simulation. When I run Code:
postProcess -noZero -func PecletNo I'm currently running OpenFOAM 4.0 I hope I'm not missing something really obvious/simple. Cheers |
June 24, 2019, 03:31 |
MD SHADAB
Rep Power: 7 |
To write the surface scalar field of Peclet Number (Pe), we need to run the post process utility with solver name.
an example of the command is given below with simpleFoam solver. Hope this will solve your problem!!! Regards, Shadab Code:
simpleFoam -postProcess -func PecletNo |
icofoam, peclet, pecletno |
[Other] Equal decomposition of cylindrical fluid domain | Sean95 | OpenFOAM Meshing & Mesh Conversion | 3 | February 12, 2019 03:34 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Confuse about Nu Number in Laminar Flow | mariam.sara | FLUENT | 20 | November 23, 2015 14:36 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
at what Reynolds number for non-Newtonian fluids flow that the laminar region end ?? | the best future | Main CFD Forum | 4 | May 22, 2012 06:56 |
