Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
TotalIncompressiblePressure evaluation
Like Tree3Likes
  • 1 Post By akidess
  • 2 Post By jcw
Old   October 26, 2018, 10:21
Default TotalIncompressiblePressure evaluation
jcw
Christian Wolf
jcw is on a distinguished road
Hello!
I am using OF4.1. I am struggeling with the evaluation of total pressure at patches named "IN" and "OUT". I was able to calculate the total pressure field. But I have no idea how to extract the mass-flow weighted total pressure at my boundary patches.
Solver: simpleFoam
controlDict:
runTimeModifiable true;
functions
#includeFunc flowRatePatch(name=IN)
#includeFunc flowRatePatch(name=OUT)
#includeFunc residuals
pressure1
type pressure;
libs ("libfieldFunctionObjects.so");
patches (IN);
writeControl timeStep;
writeInterval 1;
log on;
pRef 1;
// Calculate the total pressure
calcTotal yes; // yes | no
// Calculate the (total) pressure coefficient
calcCoeff no; // yes | no
BTW:
The flowRatePatches evaluation work perfect. And I would like to have total pressure value each for "IN" and "OUT".
Thanks for support!
jcw is offline   Reply With Quote
Old   November 5, 2018, 04:53
jcw
Christian Wolf
No ideas? Are there information missing?
Old   November 5, 2018, 08:44
akidess's Avatar
Anton Kidess
This works with OF-5.0:
pIN
        type            surfaceFieldValue;
        functionObjectLibs ("libfieldFunctionObjects.so");
        writeFields     false;
        writeInterval   1;
        // Output to log&file (true) or to file only
        log             true;
        valueOutput     true;
        source          patch;
        sourceName      "IN";
        regionType      patch;
        name            "IN";
        surfaceFormat   ensight;
        // Operation: areaAverage/sum/weightedAverage ...
        operation       areaAverage;
        fields
            p
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   November 5, 2018, 09:09
jcw
Christian Wolf
Thanks! I works. I had to change 'type surfaceFieldValue' -> 'type surfaceRegion'. Then it can be used for OP4.1.
How can I evaluate the total pressure at patch called 'IN'? Changing the 'fields' to total(p) is not working:
pIN
type surfaceRegion;
writeFields false;
writeInterval 1;
log true;
valueOutput true;
source patch;
sourceName "IN";
regionType patch;
name "IN";
fields
total(p)
gives the following error:
Time = 1
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0903489, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0335626, No Iterations 3
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.0335636, No Iterations 3
GAMG: Solving for p, Initial residual = 1, Final residual = 0.0331327, No Iterations 7
time step continuity errors : sum local = 0.00124111, global = 0.000336422, cumulative = 0.000336422
smoothSolver: Solving for omega, Initial residual = 0.158845, Final residual = 0.00888191, No Iterations 2
smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0486494, No Iterations 2
ExecutionTime = 7.84 s ClockTime = 8 s
surfaceRegion pIN write:
--> FOAM Warning :
From function virtual bool Foam::functionObjects::fieldValues::surfaceRegion: :write()
in file fieldValues/surfaceRegion/surfaceRegion.C at line 780
Requested field total(p) not found in database and not processed
And also important: Where can I find information on how to use the post-processing tools?
Old   November 5, 2018, 10:13
akidess's Avatar
Anton Kidess
You can't do in-situ postprocessing of the total pressure, because it is not available by default. Easiest solution is to compute the total pressure and the samples in post after the simulation has completed.
Your first stop for information on how to use the postprocessing tools is the openfoam manual.
TeddyL likes this.
Old   November 7, 2018, 07:19
jcw
Christian Wolf
Here is my ./system/controlDict file to get relevant data during simulation. Maybe it helps other users with same problem.
It works well for OF4.1 and simpleFoam.
 functions
        #includeFunc totalPressureIncompressible
    #includeFunc pressureDifferencePatch
    #includeFunc singleGraph
    #includeFunc surfaces
    #includeFunc streamlines
yPlus1
    type    yPlus;
    result WALL;
    executeControl    writeTime;
    writeControl    writeTime;
pressureTools1
        type                pressure;
        functionObjectLibs ("libutilityFunctionObjects.so");
        enabled             yes;
        //region              0;
        calcTotal           yes;
        calcCoeff           no;
        timeStart           1;
        timeEnd             100000;
        writeControl        outputTime;
        writeInterval       1;
    pRef            0;
        rhoInf              1.17663;
        pInf                101325;
        UInf                (0 0 0);
reloadPcalc
        type        readFields;
        //region          0;
        enabled         yes;
        timeStart       1;
        timeEnd         10000;
        writeInterval    1;
        outputInterval 1; // 5000;
        fields
        total(p)
        p
outlet_avg_p
        type            surfaceRegion;
    enabled         true;
        log             true;
    valueOutput     false;
        timeStart       1;
        writeInterval    1;
        writeFields     off;
        regionType      patch;
        name            OUT;
    surfaceFormat   none;
        fields
           // total(p)
    p
outlet_avg_ptot
        type            surfaceRegion;
        enabled         true;
        log             true;
        valueOutput     false;
                   timeStart    1;
                writeInterval   1;
        writeFields     off;
        regionType    patch;
        name            OUT;
        surfaceFormat   none;
        fields
        total(p)
        //p
inlet_avg_p
         type            surfaceRegion;
        enabled         true;
        log             true;
        valueOutput     false;
                timeStart    1;
                writeInterval   1;
        writeFields     off;
        regionType    patch;
        name            IN;
        surfaceFormat   none;
        fields
           // total(p)
        p
inlet_avg_ptot
        type            surfaceRegion;
        enabled         true;
        log             true;
        valueOutput     false;
                timeStart    1;
                   writeInterval   1;
        writeFields     off;
        regionType      patch;
        name            IN;
        surfaceFormat   none;
        fields
        total(p)
        //p
Files needed in ./system directory:
controlDict
decomposeParDict
fvSolution
topoSetDict
fvSchemes
residuals
singleGraph
streamlines
surfaces
 yPlus
Regards.
akidess and TeddyL like this.
post-processing pressure, pressure tools, simplefoam, total pressure
Tecplot 360 2011 R2 preview with OpenFOAM data loader available for evaluation scott_rumage OpenFOAM Post-Processing 50 January 23, 2017 03:49
Use of K-Epsilon Model for Hotspot Evaluation nomi.tahir Main CFD Forum 0 May 9, 2016 14:06
Evaluation of "diffusive flux" of Compressible Navier-Stoke in the corner tranhophu Main CFD Forum 5 January 19, 2016 10:30
yPlusRAS evaluation in OpenFOAM 2.2x MaLa OpenFOAM Post-Processing 1 December 10, 2013 10:34
Evaluation method for design improvement of bioreactor to prevent biofouling/biofilm kevinlipps FLUENT 0 March 8, 2012 10:53
