Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to find the values of pressure and velocity into each cell?
Like Tree1Likes
  • 1 Post By peterhess
Old   September 21, 2018, 21:14
Post How to find the values of pressure and velocity into each cell?
Leandra
LeaIna is on a distinguished road
Hi, guys!
I'm new in OpenFoam and my university professor wants a graph whit the U and P. However, it requires the values of each cell and the graph will be generated at the gnuplot.
I need values each cell of the mesh. How to find ?
( I can't to find through of modification of the file, it has to be manual)
can someone help me ?
thank you !
LeaIna is offline   Reply With Quote
Old   September 22, 2018, 19:52
Peter Hess
peterhess is on a distinguished road
If I understood the topic right way, I could suggest the following solution using paraView:
- Open paraView and import the data
- At the right side of the screen choose Split Horizontal
- From the list choose the last one namely SpreadSheet View
- From Attribute choose Cell Data instead of Point Data
- (optionally) At the right screen side choose Export SpreadSheet
done
Regards
Peter
rocknrolltr likes this.
peterhess is offline   Reply With Quote
Old   September 23, 2018, 21:06
Leandra
Peter, thank you so much. You helped me a lot!
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 11:34
Velocity values are normal but pressure values are too big rv82 OpenFOAM Running, Solving & CFD 4 April 13, 2015 04:59
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
