September 14, 2018, 16:32 |
rhoSimpleFoam yPlus
Thomas M
Rep Power: 8 |
Hi all,
I just ran into something very strange to me. I'm solving a compressible flow using rhoSimpleFoam, and am confused as to how the yPlus function works. It looks like the yPlus function gave me a calculation for each results set I have. Furthermore, looking at the values, they are different between iterations. There's no reason for y+ to be changing, right? I'm using a mesh I made in Salome, not moving or anything. y+ is a geometric parameter, based on my mesh - so why does it change with each iteration? Code:
... Time = 1900 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi pressureControl pMax 1.28091e+06 pMin 64045.4 Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; decayControl false; kInf 0; omegaInf 0; } No MRF models present yPlus yPlus write: writing field yPlus patch walls y+ : min = 14.6179, max = 1200.02, average = 452.317 Time = 2000 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Reading field U Reading/calculating face flux field phi pressureControl pMax 1.28091e+06 pMin 64045.4 Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; decayControl false; kInf 0; omegaInf 0; } No MRF models present yPlus yPlus write: writing field yPlus patch walls y+ : min = 4.23512, max = 906.382, average = 453.212 End |
September 16, 2018, 15:53 |
anonymous
Rep Power: 14 |
Hi!
Yes, it is calculated for every timestep since yPlus is NOT a fully geometric parameter. Check this: https://www.cfd-online.com/Wiki/Dime...tance_(y_plus) yPlus is also depending on the friction velocity. If you are running a steady state calculation, you can call the utility with the switch "-latestTime", so it will calculate the yPlus value only in the last timestep. |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
yPlus twoPhaseEulerFoam | Andrea_85 | OpenFOAM Post-Processing | 4 | January 11, 2021 05:01 |
OF 4.0 multiregion case calculate yPlus | pbnuclex | OpenFOAM Post-Processing | 6 | July 16, 2020 04:27 |
yplus value openfoam turbulent analysis | massakimi | Main CFD Forum | 20 | January 6, 2018 16:08 |
heat transfer coefficients with "bad" yplus | Andrew | Main CFD Forum | 4 | April 8, 1999 04:43 |
