Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
probe Locations error in the dynamicMesh foam extend 4.0
Like Tree2Likes
  • 1 Post By vahidreza lotfi
Old   July 14, 2018, 05:35
Default probe Locations error in the dynamicMesh foam extend 4.0
vahidreza lotfi
vahidreza lotfi is on a distinguished road
I`m run sloshingtank3d in foamextend 4.0 , interDyMFoam gives the following errors when the point probe is on the wall:
Searching for probe point locations
--> FOAM Warning :
From function probes::read()
in file probes/probes.C at line 73
Did not find location (0 9.95 19.77) in any cell. Skipping location.
--> FOAM Warning :
Did not find location (0 -9.95 19.77) in any cell. Skipping location.
Time = 0.07
based on the referenced error message, it appears that the probe remains static and dose not move with the mesh.
I created a new solver in foam extend 4.0, and I have to use probe Location to validation results my work. now that the foam extend does not support the probe location in dynamicMesh, what should I do?
yoser likes this.
vahidreza lotfi is offline   Reply With Quote
Old   August 22, 2018, 10:45
Retired Super Moderator
Bruno Santos
Greetings vahidreza lotfi,
Sorry for the late reply, but I only now did I manage to take a quick look into this.
The problem is that the probes in foam-extend 4 do not yet have the ability to move with the mesh.
You will have to build the branch "nextRelease" on the foam-extend 4 repository, in order to access this feature.
Unfortunately I don't see an easy way to simply use the sampling library from this release on foam-extend 4.0, due to several core changes having been done on it.
Best regards,
Bruno
Old   August 22, 2018, 11:30
vahidreza lotfi
Hi bruno
Thanks so much for your reply.
I went to Paraview to solve this problem.And I got the right answers from Paraview.
Best regards,
Vahid
wyldckat likes this.
dynamicmesh, foam extend 4.0, probe location
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 03:21
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
