Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Plot the moment around a specified axis
Like Tree1Likes
  • 1 Post By aleolsi
Old   March 21, 2018, 11:23
Default Plot the moment around a specified axis
regentropfen is on a distinguished road
Hi!
We are working on the wind turbine tutorial from CFDsupport (https://www.cfdsupport.com/download-...d-turbine.html).
In order to analyse the power of the wind turbine, we want to analyse the moment around the rotation axis of the turbine which is (0.993572 0 0.113203). However, forces doesn't seem to work in an appropriate way - it gives us components around x, y and z in the moment.dat instead of the moment around the desired axis.
As we did not find documentation about the coordinateRotation with type axisRotation that is used here, we are a little bit lost... We found something with pitchAxis but do not know how to use it appropriately.
I am sorry if this is a stupid question, we are new to openfoam...
Any help would be appreciated!
turbine-forces-and-moments
type forces;
functionObjectLibs ("libforces.so");
writeControl timeStep;
writeInterval 1;
log true;
patches (
blade1-pressureSide1
blade1-pressureSide2
blade1-suctionSide1
blade1-suctionSide2
blade1-cap
blade2-pressureSide1
blade2-pressureSide2
blade2-suctionSide1
blade2-suctionSide2
blade2-cap
blade3-pressureSide1
blade3-pressureSide2
blade3-suctionSide1
blade3-suctionSide2
blade3-cap
pName p;
UName U;
rho rhoInf;
rhoInf 1.2;
origin (1.510229221 0 1.672068885);
coordinateRotation
type axesRotation;
e1 (0.993572 0 0.113203);
e2 (0 1 0);
regentropfen is offline   Reply With Quote
Old   March 22, 2018, 03:47
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I think it should be possible, but it depends on what version you are using. Check source documentation (online):
version 1712, look at the local forces/moments.
version 5, seems similar but also look at the local forces/moments.
Hope this helps,
Tom
tomf is offline   Reply With Quote
Old   March 23, 2018, 04:46
Yes, it helped, I think we have the right moment now. Thanks a lot!
Old   November 26, 2018, 10:48
Alexandre Oliveira
aleolsi is on a distinguished road
How did you get the right results? Can you post the function with the right axis definition?
berne likes this.
aleolsi is offline   Reply With Quote
axis, forces, post processing
[swak4Foam] Foam warnings - related to swak4Foam Salam-H OpenFOAM Community Contributions 20 August 2, 2015 16:40
New sixDoFRigidBody BC working with laplaceFaceDecomposition Ya_Squall2010 OpenFOAM Running, Solving & CFD 13 April 17, 2013 03:04
Writing Moment coefficient for different walls at different rotational axis harishameed33 Main CFD Forum 0 April 27, 2010 13:17
Moment about the longitudenal axis of the aircraft momahadi30 FLUENT 0 January 29, 2010 07:16
UDF extern variable - mean time moment coefficient enry Fluent UDF and Scheme Programming 0 November 14, 2009 07:56
