Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
reconstructPar error message "No times selected"
Like Tree1Likes
  • 1 Post By wyldckat
Old   October 18, 2017, 06:12
Lightbulb reconstructPar error message "No times selected"
gemxx
gemxx is on a distinguished road
Hi all,
I get the following error while trying to run reconstructPar.
I put the DecomposeParDict, controlDict, fwhControl, commonSettings files as below.
I've studied on this for days but I couldn't find the reason of this error.
Can someone please tell me how to correct this?
Thank you very much.
gemxx
reconstructPar
Build  : 4.1
Exec   : reconstructPar -latestTime
Date   : Oct 18 2017
Time   : 11:46:08
Host   : "Kale"
PID    : 4601
Case   : /home/kale/OpenFOAM/kale-4.1/cylinder2D_FWH_Degistirilmis
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM FATAL ERROR:
No times selected
    From function int main(int, char**)
    in file reconstructPar.C at line 225.
FOAM exiting
DecomposeParDict
|  \\    /   O peration     | Version:  3.0.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      decomposeParDict;
numberOfSubdomains 1;
method          scotch;
simpleCoeffs
    n               (2 1 1);
    delta           0.001;
hierarchicalCoeffs
    n               (2 1 1);
    delta           0.001;
    order           xyz;
manualCoeffs
    dataFile        "";
distributed     no;
roots           ( );
controlDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     pisoFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         0.2;
deltaT          1e-6;
writeControl    timeStep;
writeInterval   1000;
purgeWrite      5;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
     include "fwhControl"
     include "probeControl"
fwhControl
monopole2DFwhTest
        type            FfowcsWilliamsHawkings;
        #include        "commonSettings";
        patches ("cylinder");
        interpolationScheme cell;
        formulationType Farassat1AFormulation;
        cleanFreq       100;
        fixedResponseDelay true;
        responseDelay   1e-3;
        surfaces
                cylinder
                    type            patch;
                    interpolate     false;
        nonUniformSurfaceMotion false;
        Ufwh        (.0 .0 .0);
commonSettings
functionObjectLibs ("libAcoustics.so");
        log             true;
        probeFrequency  1;
        timeStart       0;//0.0001;
        timeEnd         1;
        c0              100;
        dRef            0.1;
        pName           p;
        pInf            101325;
        rho             rho;
        rhoInf          14.1964771;
        CofR (0 0 0);
        observers
                R-A
                    position    (0 0 1.0);
                    pRef        2.0e-5;
                    fftFreq        1024;
                R-B
                    position    (0 0 2.0);
                    pRef        2.0e-5;
                    fftFreq        1024;
                R-C
                    position    (0 0 3.0);
                    pRef        2.0e-5;
                    fftFreq        1024;
                R-D
                    position    (0 0 4.0);
                    pRef        2.0e-5;
                    fftFreq        1024;
                R-E
                    position    (0 0 5.0);
                        pRef        2.0e-5;
                    fftFreq        1024;
                R-F
                    position    (0 0 10.0);
                    pRef        2.0e-5;
                    fftFreq        1024;
Last edited by wyldckat; January 1, 2018 at 18:11. Reason: Added [CODE][/CODE] markers
gemxx is offline   Reply With Quote
Old   January 1, 2018, 18:13
Retired Super Moderator
Bruno Santos
Quick answer: I don't know if you have solved this issue or not, but the error message seems to indicate that there no time folders inside the folders "cylinder2D_FWH_Degistirilmis/processor*".
When in doubt, run:
ls -l processor*/
which should show you the list of files and folders inside the folders starting with the name "processor".
XJ_Wang likes this.
Old   April 26, 2018, 11:55
Default The same prpblem of " No processor* directories found' even if the time folder exist!
Ali Noaman Ibrahim
alinuman15 is on a distinguished road
When in doubt, run:
ls -l processor*/
Hi Bruno:-
I would like to report that I have faced the same problem with OF5, Where I have got:-
in file reconstructPar.C at line 217.
FOAM exiting
Then, when checked the time folders in my prrocessorsfolder, I found all of them are available. for ex.
processor6/:
total 28
drwxr-xr-x 3 ali ali 4096 Apr 18 07:34 0.00401
drwxr-xr-x 3 ali ali 4096 Apr 18 22:04 0.00801
drwxr-xr-x 3 ali ali 4096 Apr 19 15:01 0.01201
drwxr-xr-x 3 ali ali 4096 Apr 20 10:29 0.01601
drwxr-xr-x 3 ali ali 4096 Apr 21 09:57 0.02001
drwxr-xr-x 3 ali ali 4096 Apr 23 08:45 0.02401
drwxr-xr-x 3 ali ali 4096 Apr 17 05:19 1e-05
Morever, even if I run :-
reconstructPar -time 0.00401:0.02401
the same error still persists!
Any clue ?
Thanks!
alinuman15 is offline   Reply With Quote
Old   April 26, 2018, 12:54
Bobby
babakflame is on a distinguished road
Ali
Do you do decomposePar at the beginning of your simulation?
Is it possible to share you subfile (bashscript) to see what you have submitted?
Moreover, can I see your controlDict and the last lines of your log file (in case of existence)?
Thanks
babakflame is offline   Reply With Quote
Old   April 27, 2018, 07:40
Ali Noaman Ibrahim
Originally Posted by babakflame View Post
Ali
Thanks
Thanks Babak for your interest.
Yes, I have decomposed them at the beginning.
For bash script, I run this code on my PC which is 8 processors so there is no bash script for job scheduling.
Finally, I have inserted my controlDict file. Please, if you need more information, let me know.
Thanks again!
https://drive.google.com/open?id=1rL...QTO-1E2eEpknUC
Old   April 27, 2018, 19:09
Bobby
Ali
In the subfile that you sent me there was no decomposePar command.
Two factors might cause this issue:
1) you have not saved any time steps in your processors
2) there is sth wrong with decomposePar process (could be a grid problem).
Do this command and post the results:
  decomposePar > decompose.log 2>&1
Old   April 27, 2018, 23:02
Ali Noaman Ibrahim
Ali
Dear Babak:-
The subfile you are talking about is related to my job at the university where I did the decomposing before submitting my job. But what I am talking about here is related to my running on PC. I have splittedthe job on my 8 processors and it is running well. Howevere, when I stop the running and trying to extract the time, I get the error inserted in the previous post, although the time folders are available at the decomposed processors!
Thanks!
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs Pier84 OpenFOAM Installation 4 June 18, 2016 17:22
reconstructPar nor working Priya Somasundaran OpenFOAM Post-Processing 2 January 28, 2016 15:37
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
reconstructPar -time NOT giving the desired times aerospain OpenFOAM 4 July 19, 2012 06:07
Computation Times for reconstructPar sega OpenFOAM Running, Solving & CFD 1 March 24, 2009 07:57
