Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
yPlus twoPhaseEulerFoam
Like Tree1Likes
  • 1 Post By Andrea_85
Old   September 27, 2017, 10:08
Default yPlus twoPhaseEulerFoam
Andrea Ferrari
Andrea_85 is on a distinguished road
Hello Foamers,
i am trying to output yPlus using the solver post-processing as indicated here:
https://cfd.direct/openfoam/user-gui...rocessing-cli/
I am simulating the bubbleColumn tutorial of twoPhaseEulerFoam (all the setting are left as in the tutorial, so turbulence model is mixtureKEpsilon for both phases). I added the following lines to the control dict
functions
   yPlus
    type            yPlus;
    libs            ("libfieldFunctionObjects.so")
However when i execute
twoPhaseEulerFoam -postProcess
i got the following warning and yPlus is not calculated
--> FOAM Warning :
    From function virtual bool Foam::functionObjects::yPlus::execute()
    in file yPlus/yPlus.C at line 178
    Unable to find turbulence model in the database: yPlus will not be calculated
yPlus yPlus write:
    writing field yPlus
    patch walls y+ : min = 0, max = 0, average = 0
If i calculate yPlus during the run or change the turbulence model nothing changes.
Any idea?
Best,
Andrea
lourencosm likes this.
Andrea_85 is offline   Reply With Quote
Old   December 27, 2020, 12:23
Gabriel de Souza Berestinas
gberestinas is on a distinguished road
Please, have you already solved this issue? I am facing the same problem with DPMDyMFoam. I appreciate it if you can help.
gberestinas is offline   Reply With Quote
Old   December 28, 2020, 10:49
atul1018 is on a distinguished road
I am facing same problem to calculate yPlus in particle-lade backward facing step. Solver I used is DPMFoam in OpenFoam-v-1912.
If you managed to solve the issue, let me know.
Best Regards
Atul
atul1018 is offline   Reply With Quote
Old   January 9, 2021, 10:28
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Could you please open a bug ticket in https://develop.openfoam.com/?
Many thanks!
HPE is offline   Reply With Quote
Old   January 11, 2021, 06:01
Hi HPE
as suggested, I have reported the issue here: https://develop.openfoam.com/Develop.../-/issues/1978
Best Regards
Atul
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
OF 4.0 multiregion case calculate yPlus pbnuclex OpenFOAM Post-Processing 6 July 16, 2020 05:27
Yplus adapt rafash2 FLUENT 0 June 12, 2016 08:25
which yplus (SST) sanchezz CFX 17 January 11, 2010 05:45
heat transfer coefficients with "bad" yplus Andrew Main CFD Forum 4 April 8, 1999 05:43
