Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
bug for wallHeatFlux OF5.x-dev?
Like Tree5Likes
  • 1 Post By student666
  • 1 Post By atulkjoy
  • 1 Post By wyldckat
Old   September 1, 2017, 17:17
Default bug for wallHeatFlux OF5.x-dev?
M. C.
student666 is on a distinguished road
I ran a case with two solid regions, If at the end of the simulation I run
chtMultiRegionSimpleFoam -postProcess -func wallHeatFlux -region solid1
I got this error
Build  : dev-540796ea3aaf
Exec   : chtMultiRegionSimpleFoam -postProcess -func wallHeatFlux -region solid1
Date   : Sep 01 2017
Time   : 22:16:11
Host   : "michele-N552VW"
PID    : 6559
I/O    : uncollated
Case   : /home/michele/OpenFOAM/michele-dev/run/chtProva/finale
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create solid mesh for region solid1 for time = 0
Create solid mesh for region solid2 for time = 0
--> FOAM FATAL ERROR:
No fluid meshes present
    From function chtMultiRegionSimpleFoam
    in file ../createMeshesPostProcess.H at line 5.
FOAM exiting
To reproduce the error just run the ./run bash
Is this a bug I should report?
Thanks
atulkjoy likes this.
student666 is offline   Reply With Quote
Old   September 2, 2017, 03:31
Default Wall Heat Flux
Atul Kumar
Location: National Centre for Combustion Research and Development
atulkjoy is on a distinguished road
Use this utility I compiled through 4.x, dev, and plus version I hope this will work with 5.x too just in make/option chane $(WM_PROJECT_USER_DIR)/src to $(LIB_SRC) and compile.
Saeng Kinley likes this.
atulkjoy is offline   Reply With Quote
Old   September 2, 2017, 07:25
M. C.
Hi thank you for support, but I think I can't use your files so easily
You changed all options by defining new thermoModels as MythermoModels e.g.
Old   September 2, 2017, 12:21
Retired Super Moderator
Bruno Santos
Greetings to all!
@student666: I've tested this and it was in fact a bug or at least a missing feature. I've submitted a patch for it here: https://bugs.openfoam.org/view.php?id=2684
Which installation instructions have you followed?
Best regards,
Bruno
Old   September 2, 2017, 13:44
M. C.
Hi Bruno,
my actual installation is as by the following thread
Problem for OF-dev on linuxMint 18.2 Sonya
so the link is:
https://openfoam.org/download/dev-ubuntu/
Old   September 3, 2017, 08:15
Atul Kumar
You can change it to $(LIB_SRC)/thermophysicalModel/what ever u want
Or there is old.option file rename it as option it will work
Sent from my Lenovo K50a40 using CFD Online Forum mobile app
student666 likes this.
Old   September 3, 2017, 11:02
Bruno Santos
Hi Bruno,
so the link is:
Quick answer:
  1. You can either wait for OpenFOAM-dev to be updated sometime tomorrow, which hopefully will already include this bug fixed in it.
  2. Or you can try running the following commands for updating the build:
    cd $FOAM_SOLVERS/heatTransfer/chtMultiRegionFoam
    sudo wget "https://bugs.openfoam.org/file_download.php?file_id=2203&type=bug" -O createMeshesPostProcess.H
    sudo -s
    source /opt/openfoam-dev/etc/bashrc
    wmake -j all
    wclean all
    exit
M. C.
Thank you both
Sent from my ASUS_X008D using CFD Online Forum mobile app
Old   September 8, 2017, 17:38
Atul Kumar
please follow the link to find bug in openfoam 5.x version
Wall Heat Flux utulity
Bug in Workbench CFX Pierre1 CFX 6 August 2, 2017 01:18
SU2_MSH: Periodic boundary conditions bug Zef SU2 1 February 18, 2015 14:28
dieselEngineFoam bug - OpenFOAM-1.6-ext novakm OpenFOAM Bugs 1 December 5, 2013 14:18
Serious bug in LES interface fs82 OpenFOAM Bugs 21 November 16, 2009 09:15
Bug reports Mattijs Janssens (Mattijs) OpenFOAM 0 January 10, 2005 11:05
