Laurent Fieschi
Rep Power: 8 ![]() |
I am running the tutorial aeroFoil in /incompressible/overSimpleFoam. The simulation seems to run correctly but when I use paraview I ve got this zoneID’s visualisation : figure1_aeroFoil_zoneID.png I don’t understand why there are stripes in the overset bloc. However, in a threshold with zoneID=0 and zoneID=1 I have this : figure3_aeroFoil_zoneID.png figure2_aeroFoil_zoneID.png so topoSet and setFields seem to run correctly. I think it’s a paraview problem but I am not sure. Thank you in advance |
Hi!
You should have also the variables cellType. range 0 till 2 With setting a Threshold filter you can filter out the inactive (hole) cells. Best regards Flo |
#3 | |
Laurent Fieschi
But with a threshold filter (cellTypes=0) I have the same stripes on paraview cellTypes_Threshold.jpg Best regards |
i also have stripes, when i look from a random view. but when you look perpendicular to your xy-plane, the stripes should be gone....
Yann
Rep Power: 26 ![]() |
Isn't it just a graphical glitch?
In this area there are 2 overlaying meshes so I think what you see is just the 2 meshes. Same thing happens on the overset case i've run so far, and as Flo-Ha, it usually gets better when using a view normal to the plane. |
Laurent Fieschi
Thanks to both of you for your help
Yes I think it's a graphical glitch. To have a correct paraview picture I just have to superpose 2 different Thresholds. For example one Threshold with zoneID=0 and an other one with zoneID=1 : Superposition_Thresholds.jpg |
Omid
Rep Power: 10 ![]() |
Where can I find this tutorial? Thanks. |
#8 | |
Omid
Thank you |
#9 |
Yann
#10 | |
Omid
I have updated to the latest OpenFOAM version and I am trying to run an overset case. In the pimpleDyMFoam folder, I run the blockMesh for the "cylinder and background" case and after that I tried to run the case by typing overPimpleDyMFoam. But it does not work. Do you know the reason? Thank you |
#11 |
Yann
Hi Omid,
About tutorials, generally speaking, the best way is to run the Allrun scripts (if present), then read the script(s) and logs to see what steps you need to perform to run the case. For overset cases, it's not as straightforward as running blockMesh + solver. You need to create 2 separate meshes, merge the meshes together and perform few additional steps before running overPimpleDyMFoam. But again, you'll find these information in the README.txt file and the Allrun scripts in the overPimpleDymFoam/cylinder tutorial. If you're new to overset in OpenFOAM, I suggest you to read the openFOAM-v1706 release notes about the initial overset implementation in OpenFOAM. It might help you to understand how the solver works : https://www.openfoam.com/releases/op...merics-overset |
#12 | |
Omid
Thank you for mentioning Allrun.pre, it was helpful for following the step by stem process. I could do everything mentioned there, execpt for "restore0Dir". What does this mean? Thanks in advance! |
#13 |
Mark
It copies the content from 0.org directory to 0 directory
[Tutorials] New Dakota - OpenFOAM Coupling Tutorial | Tobi | OpenFOAM Community Contributions | 0 | October 9, 2016 17:19 |
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 14, 2016 10:19 |
OpenFOAM Aerofoil Simulation | Puglin | OpenFOAM | 3 | August 19, 2014 06:36 |
pitching naca64a010 aerofoil euler tutorial | pranav | SU2 | 1 | July 17, 2014 10:02 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
