What's the meaning of "prime2Mean" in fieldAverage function of OpenFOAM |
August 23, 2017, 04:42 |
Abiy Melaku
Rep Power: 10 |
Hello Guys,
Does anybody know the meaning of "prime2Mean" option that's specified when we want to calculate average of the a field. Please look the following code. Thank you very much! Code:
functions { fieldAverage1 { type fieldAverage; libs ("libfieldFunctionObjects.so"); writeControl writeTime; fields ( U { mean on; prime2Mean on; base time; } ); } } |
August 23, 2017, 12:23 |
Agustín Villa
Rep Power: 15 |
Hello
it means that you get the average of the product of the fluctuations of the variable. For instances, in your case you have U. It means that you get UPrime2Mean, it is , so you get the symmTensor where you have the Reynolds stresses. For a scalar T, you get , the time average of the squared fluctuations. |
September 1, 2017, 18:27 |
Atul Kumar
Location: National Centre for Combustion Research and Development
Rep Power: 11 |
Hi ,
If I use Umean = U - squrt(Uprime2mean) will it be the right thing to find mean value. As mean is instantaneous - fluctuating field. |
March 18, 2018, 10:18 |
Qi Xueyu
Rep Power: 8 |
I don't think so. I have caculated it. the equation is not correct. you can see the case /tutorials/incompressible/pimpleFoam/LES/channel395; And you remove the functions{...} ,then get the result to compare with the result without remove the functions. you can find the U and U_0 are same. but you cann't connect the relationship between U and UMeasure and UPrime2Mean. I'm confused with it too!
March 18, 2018, 10:24 |
#5 | |
Santiago Lopez Castano
Rep Power: 16 |
March 18, 2018, 10:36 |
#6 | |
Qi Xueyu
Rep Power: 8 |
I'am caculating the result.the case 40s, first point. U_0=(0.00631659 -9.16861e-07 -0.0020712);//i don't understand the varible's mean... U=(0.00625804 4.31012e-06 -0.00207582); UMean=(0.00956163 5.37524e-05 -0.00152819); UX=0.00625804;UMeanx=0.00956163; Uprime2Mean=(6.34187e-06 2.28789e-08 -1.65954e-07 1.92607e-08 1.25591e-07 1.12799e-05); U'=UX-UMean; but the equation Uprime2Mean !=sqrt(U'*U'); this is my confused! |
March 18, 2018, 10:43 |
Rep Power: 16 |
Because thats not how you calculate the standard deviation!
You calculate it like follows: // variance S = mean(U U) - mean(U)mean(U) // std. Dev S = sqrt(S) |
March 18, 2018, 11:40 |
#8 | |
Qi Xueyu
Rep Power: 8 |
mean(UxUx)=UMeanx*UMeanx+Uprime2Mean(1,1); mean(UyUy)=UMeany*UMeany+Uprime2Mean(2,2); mean(UzUz)=UMeanz*UMeanz+Uprime2Mean(3,3); For instance : mean(uxux)=0.00956163^2+6.34187e-06=0.0000977666382569; mean(uyuy)=5.37524e-05^2+1.92607e-08=2.215002050576E-08 mean(uzuz)=-0.00152819^2+1.12799e-05=0.0000136152646761 mean(uxux)=1/t*integral(uxux)dt;y and z are same. but how to calculate the ux , uy , uz ? |
March 21, 2019, 06:08 |
#9 |
hi!
which mean do you mean? you are mixing Ux and ux so it is hard to understand what are you looking for. Time averaged mean velocity one already have in UMean array.
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
March 21, 2019, 06:36 |
#10 |
the only official description I found is here:
https://cpp.openfoam.org/v3/a00751.html#details But I found it is confusing as most of OpenFOAM documentations. Instead of I would raver write Otherwise you cannot get a tensor for a vector field for example. Or at least some special multiplication operator should be used instead of power 2.
March 21, 2019, 06:50 |
#11 | |
Rep Power: 16 |
Both forms are correct, it's just a matter of taste! The first form (vector notation) assumes x to be a vector, and as such, the outer product can be perfectly written as |
March 21, 2019, 06:53 |
#12 |
wouldn't it give a scalar for the vector? outer product is actually (a*a^T) to give a tensor, for example in N-S the convective term is not U^2 but U U^T
March 21, 2019, 07:16 |
#13 | |
Agustín Villa
Rep Power: 15 |
if you look into the programmers' guide (link), there you can see in Section 1.3.4 how OpenFOAM deals with the outer product. Then, in Section 1.3.6: Quote:
I hope it helps to answer your question. |
March 21, 2019, 07:18 |
#14 |
Rep Power: 16 |
an outer product is an outer product, irrespective of notation! Meaning that an outer product between two euclidean vectors return a tensor. The definition given by you is more natural in Linear Algebra, and real analysis, whereas the tensor algebra intended in OF follows more the notation common in some books of functional analysis
March 21, 2019, 07:19 |
#15 | |
Thank you Agustin! if that means the outer product, it is fine)))
Cheers! Quote:
March 21, 2019, 07:20 |
#16 | |
Dear Santiago, for me aa or a^2 is a dot product, that is why I find it confusing. But if they accept it as an outer product I agree
March 21, 2019, 07:42 |
#17 |
the last thing I dont like at
https://cpp.openfoam.org/v3/a00751.html#details is that the ^2 operator is out of the averaging since to find Reynolds-like stress we average the product of the fluctuating part, but not multiply the the average of the fluctuations, which are actually zero in the ideal case. So it should be:
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 11:20 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 07:27 |
