Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Lift, Drag and Moment forces for airfoil study
Like Tree2Likes
  • 2 Post By Bazinga
Old   August 3, 2017, 17:20
Default Lift, Drag and Moment forces for airfoil study
LucaDeVivo
ldevivo is on a distinguished road
Hi
I am running a simulation using OpenFOAM from within Grasshopper(Rhino3D).
I am interested in the aerodynamics of airplane wings. I want to obtain the Lift and Drag forces acting on the structure so I can then run a shape optimization using parametric design.
So far I have managed to run a simulation and obtain the pressure and velocity distribution. Now I want to compute the Forces acting on the surface of the wing so I can get L/D ratios.
I have seen that OpenFOAM has a comand that calculates the forces but I am wondering how to implement it in this case.
Thanks
ldevivo is offline   Reply With Quote
Old   August 6, 2017, 05:02
Bazinga is on a distinguished road
Calculating the forces is defined in the controlDict file. Just look up the code in a tutorial or somewhere here in the forum. If you have any specific questions after that, let us know.
edit: I made a small video. The volume is rather low but I hope it still help: https://www.youtube.com/watch?v=YOT62t2IiDE
student666 and caio.df like this.
Bazinga is offline   Reply With Quote
Old   November 27, 2018, 19:07
M. C.
student666 is on a distinguished road
Is it "a standard" to consider the chord length as reference length for anything on an airfoil calculation? Reynolds, lift drag, force dict, ecc...
student666 is offline   Reply With Quote
Old   November 29, 2018, 02:57
Zander Meiring
yambanshee is on a distinguished road
Originally Posted by student666 View Post
generally, yes
yambanshee is offline   Reply With Quote
Old   December 1, 2018, 19:03
M. C.
How can I compare the results from a CFD to some experimental data? where can I find references?
thx
Old   December 7, 2018, 04:23
Zander Meiring
thx
X-Foil is often used as reference data for 2d airfoil calculations. It's not always exact itself, but will give a very good ballpark figure with minimal effort.
Else: google. There's plenty of experimental data for airfoils
lift, drag, moment coefficients using forceCoeffs Mike_star OpenFOAM Running, Solving & CFD 4 September 30, 2022 07:24
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Mesh Grid Study - Result Tolerance - Lift, Drag, Moment. Wingman Main CFD Forum 4 November 14, 2016 17:50
lift, drag and moment coefficients using forceCoeffs Mike_star OpenFOAM Pre-Processing 0 April 1, 2016 15:52
lift, drag and moment of airfoil dennis0131 Main CFD Forum 10 April 27, 2010 13:12
