Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
of4 Can't pimpleFoam -postProcess -func forcesCoeffsIncompressible
Like Tree5Likes
  • 5 Post By Danubi
Old   June 23, 2017, 14:36
Default of4 Can't pimpleFoam -postProcess -func forcesCoeffsIncompressible
Dan
Danubi is on a distinguished road
Hi all,
I am writing because I have tried everything and the moment to ask for help has arrived.
I am trying to obtain Cd and Cl drag and lift coefficients of an already run simulation using the wonderful capability of postProcessing.
when I use the following:
pimpleFoam -postProcess -func forceCoeffsIncompressible
I obtain:
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
forces forceCoeffsIncompressible:
--> FOAM Warning :
    From function Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const
    in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 794
    Cannot find any patch or group names matching patch1
--> FOAM Warning :
    Cannot find any patch or group names matching patch2
    Not including porosity effects
forceCoeffs forceCoeffsIncompressible:
--> FOAM Warning :
--> FOAM Warning :
Time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
No MRF models present
When I don't have any 'patch1' nor 'patch2' ...
I have tried to run it with the function included in the controlDict and it worked fine but the problem is that the simulation took weeks to get here so I can't rerun it again.
Please if any can take a look to the case I attach in the message the case folder. It only needs to:
bash ./AllMesh
pimpleFoam
This is OF4. Please run some timesteps and when you already have several time folders try to get the forceCoeffs from the written folders with postProcess.
Thanks a lot in advance
Danubi is offline   Reply With Quote
Old   June 27, 2017, 12:26
PLD
parthiv1991 is on a distinguished road
I am having the same problem. I am trying to find out the force coefficients for flow around a cylinder using OpenFoam 4.1, and the post-processing is not working somehow.
parthiv1991 is offline   Reply With Quote
Old   July 16, 2017, 08:12
Dan
I can't believe it is so weird that nobody is encountering the same problem. I am trying now to postProcess some probes and I am having similar problems. It is like it never reaches to read dictionaries specifying details of the call.
It looks to me that this -postProcess CLI approach is useful when everything can be specified on the command line, like patchAverage, where there is only a need for specifying U and the patch name. Otherwise, when it needs to read a dictionary, it fails... well... at least I can't do it.
Regards
Old   July 27, 2017, 13:47
Dan
Hello parthiv1991 and whoever stucks in the same stone,
He it goes:
This post explains some of the needed info:
bullmut threat
Also the user guide:
usedGuide
But! Important:
Go to $FOAM_ETC, then to etc/caseDicts/postProcessing/forces
Later copy whatever file with the title of the function you need (the non *.cfg file) to your system directory.
Do no add NOTHING to the controlDict 'functions' library.
And later execute the CLI command:
pimpleFoam -postProcess -func 'forceCoeffsIncompressible' -latestTime
Important: the function that has been specified between ' ' has to have the same name as the file that had been copied to system/ folder....
Thanks to the people in the other thread!
forces and force coeff., function, postprocess
postProcess Utility: icoFoam -noFunctionObjects Why?How? TeresaT OpenFOAM Post-Processing 8 July 26, 2023 03:41
postProcess -func sampleDict does not create output folder tmr2044 OpenFOAM Post-Processing 7 April 27, 2021 15:33
simpleFoam -postProcess -func R kaaja OpenFOAM Post-Processing 4 March 29, 2018 18:48
postProcess functionality in openFOAM 4 bullmut OpenFOAM Post-Processing 23 July 21, 2017 10:11
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
