Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculation of thrust and torque for propeller
Like Tree1Likes
  • 1 Post By aeksberde
Old   April 27, 2017, 09:47
Exclamation Calculation of thrust and torque for propeller
aeksberde is on a distinguished road
Dear all,
I calculated the flow through an Propeller usining MRF and AMI-Patches.
Now i want to compare my thrust and torque to experimental values. To do so I calculate both values in paraview. For thrust see Picture 1 and for torque Picture 2.
If Integrate now both values (see Picture 3) my torque nearly exactly agrees with my experimental value (about 256000 Nm) while my thrust ist about 50% too small (410000 N).
My Question now: Am I using the wrong value for the thurst and i have to calculate something additional with my Forces? Or what is the Explanation for the wrong thrust value and the correct torque value?
I am thankful for every help.
greetings
hirota likes this.
aeksberde is offline   Reply With Quote
Old   May 4, 2017, 11:17
Martin
mahtin360 is on a distinguished road
I am currently trying to do something very similar here, have compared my thrust values to experiment and get a similar thrust coefficient following your method in Paraview.
I am trying to get the same for torque, however i am not exactly sure how to compute that in paraview and unfortunately i cant read that line on the calculator shown in the screenshot. could you explain what exactly you specified there ?
many thanks
mahtin360 is offline   Reply With Quote
Old   October 28, 2019, 06:23
Kmeti Rao
Krao is on a distinguished road
Hi Martin,
many thanks
Did you figure out how to find the moments using paraview? I have calculated the forces but unable to find the moments. It would be great if you can shed some light on this problem.
Thank you
Krao is offline   Reply With Quote
thrust and torque coefficient in rotating frame tsevine SU2 3 March 30, 2022 02:15
calculate the thrust and torque of a propeller in open water condition. Alex song STAR-CCM+ 14 August 3, 2016 12:54
Thrust and torque of a propeller Alex H FLUENT 3 July 1, 2016 18:00
Propeller thrust analysis euclid ANSYS 0 June 24, 2015 10:39
Propeller torque Alex H FLUENT 1 November 1, 2006 07:18
